    Many projects
    345 Posts 19 Posters 149.5k Views 17 Watching
      Mill3rLuke
      @jo-ke said:
      another nice project
      Do you follow carpentry books to designs these or are you an ex carpenter?
      • jo-keJ
        jo-ke
        I do the design and take the meassures and my carpenter does the cabinet
        http://www.zz7.de
        • jo-keJ
          jo-ke
          quick test in sketchup diffusion.
          clay modus is great...
          http://www.zz7.de
          • jo-keJ
            jo-ke
            and a brand new video:
            http://www.zz7.de
            • jo-keJ
              jo-ke
              @l i am said:
              VERY nice work mate. Are you taking advantage of Lumen yet?
              Yes, this one is made with Lumen.
              http://www.zz7.de
              • L
                • jo-keJ
                  jo-ke
                  new project for my website:
                  Panoset: https://doerr-ma.de/pano/59/
                  http://www.zz7.de
                  • jo-keJ
                    jo-ke
                    new propject:
                    Pano:
                    (doerr.bplaced.net)
                    http://www.zz7.de
                    • jo-keJ
                      jo-ke
                      @l i am said:
                      @jo-ke said:
                      new propject:
                      Pano:
                      (doerr.bplaced.net)
                      Very nice work mate. Did you put together the mood board?
                      yes, these are the materials, I used in the render. The picture on the wall is made with Midjourney.
                      http://www.zz7.de
                      • jo-keJ
                        jo-ke
                        another small project:
                        http://www.zz7.de
                        • L
                          @jo-ke said:
                          new propject:
                          Pano:
                          (doerr.bplaced.net)
                            Right up there as you do consistently mate. πŸ‘ πŸ‘
                            • jo-keJ
                              jo-ke
                              quick test in rayscaper.
                              I modelled the typical fassade of a former german departmentstore.
                              Looks nice. But I am still struggeling with materialsettings in rayscaper
                              renderresult looks great. I hope for the beta update
                              second one ist twilightrender
                              third one is twinmotion
                              and a sketchup diffusion
                              http://www.zz7.de
                              • pixelcruncherP
                                Nice render! Can you elaborate on your struggles with Rayscaper or how we can improve the material settings? Is it a documentation thing or something that's not working out for you?
                                Thanks,
                                Thomas
                                • jo-keJ
                                  jo-ke
                                  when I try to use the materialsettings it is continously rendering and slowing down my machine.
                                  http://www.zz7.de
                                  • pixelcruncherP
                                    Gotcha, so it's a matter of interactivity. I'm not sure what your computer's specs are, but here are a couple of things you can try:
                                    You can decrease the number of render threads in the global settings. This will ensure Rayscaper is putting less load on your CPU. The downside is that this results in slower render times. You can configure the number of render threads in the application settings.
                                    You can disable material previews. Rendering the material previews also takes up CPU resources. Material previews are also configured via the application settings.
                                    Rayscaper application settings
                                    If you have a capable GPU, switch to GPU rendering. Then Rayscaper won't use your CPU at all. Switching to GPU rendering is done via the render settings.
                                    Switch between CPU/GPU
                                    • jo-keJ
                                      jo-ke
                                      I will try that.
                                      In this case I merged the rayscaper and the sketchup diffusion in Photoshop and got that nice weathered result:
                                      http://www.zz7.de
                                      • jo-keJ
                                        jo-ke
                                        rayscaper and sketchupdiffusion merging in Photoshop is a nice combination.
                                        weathering and organic forms are really the best in AI rendering.
                                        http://www.zz7.de
                                        • pixelcruncherP
                                          Very nice render, I like the gloomy look.
                                          Just thinking out loud, but it might be a good feature for Rayscaper to be able to do this out-of-the-box. Send the render to a diffusion model to create another image, then composite it with the original.
                                          As a side note, the HDRI looks pixelated. If you are using the ones that are available in Rayscaper you might want to increase the default resolution. Disclaimer, this will result in longer download times and a longer time to prep your scene for Rayscaper.
                                          PolyHaven configuration settings.
                                          • jo-keJ
                                            jo-ke
                                            a new panoset:
                                            (doerr.bplaced.net)
                                            http://www.zz7.de
                                            • 17
                                            • 18
                                            • 7 / 18
