    Rayscaper Alpha Version Available
    114 Posts 14 Posters 19.7k Views 14 Watching
      @jo-ke said:
      Is there a tutorial for glass and emitter materials?
      It has a Glass shader in the Material Type dropdown[1]
      https://i.imgur.com/fijdO8c.png
      and for the Disney shader you can enable Emmission for geometry[2]
      • jo-keJ
        jo-ke
        Thank you: glas, is solved.
        emitter not. with "blackbody emission" I don't get the submenu
        also hidden layers are rendered. how can I avoid this?
        http://www.zz7.de
        • pixelcruncherP
          You should be able to to open the submenu by clicking the chevron or text (1). You can expand everything by clicking the plus button (2):
          Hidden objects / tags / layers isn't supported yet in the alpha version. It will be there for the 1.0 version.
          Cheers,
          Thomas
          • jo-keJ
            jo-ke
            thank you. I didn't see this. solutions are so simple....
            next problems:
            is it possible to do an emitter with textures? like in my example the sign of the tramway?
            why can't I get rid of the blue textures? they are textured in SU and all faces are frontfaces
            http://www.zz7.de
            • pixelcruncherP
              This is also planned for one of the upcoming releases but it's not there yet.
              Hmm, this usually means that the face doesn't have a material assigned to it. Or the image textures couldn't be found.
              Can you select the material in the Rayscaper viewport with the material picker?
              Once, selected can you try to reload the material via the reload button? This will refresh the material, resetting it to the latest changes made in SketchUp.
              If all that fails, can you send me the scene? You can zip up the scene with all Rayscaper settings and textures using the following button on the Rayscaper toolbar:
              You can either send me a private message or send it to thomas@rayscaper.com.
              I appreciate your patience!
              Cheers,
              Thomas
              • jo-keJ
                jo-ke
                I installed your app at my notebook at home.
                unfortunately sketchup is crashing after using your plugin...
                maybe my notebook is to old...
                everytime i load a file worked with your app sketchup crushes.
                I removed your plugin and fortunately sketchup works again.
                so I have to ry tomorrow in the office.
                http://www.zz7.de
                • pixelcruncherP
                  Yikes, that's not good! Sorry about that.
                  • Rayscaper creates a log file under your home directory named SUEX_Rayscaper.log (e.g., C:/Users/Thomas Loockx/SUEX_Rayscaper.log). Do you mind getting me that file?
                  • What version of SU are you using?
                  • jo-keJ
                    jo-ke
                    I am using 23.1.340 64 bits
                    arguments; SUEX_Rayscaper
                    Current dir; C;\ProgramData\SketchUp\SketchUp 2023\SketchUp
                    File verbosity level; 0
                    date       time         ( uptime  ) [ thread name/id ]                   file;line     v|
                    2024-01-04 20;15;43.430 (   0.034s) [main thread     ]             loguru.cpp;770   INFO| Logging to 'C;\Users\Kehlj/SUEX_Rayscaper.log', mode; 'w', verbosity; 0
                    2024-01-04 20;15;43.613 (   0.218s) [main thread     ]      AppController.cpp;73    INFO| Running Rayscaper version 0.7.3
                    2024-01-04 20;15;43.614 (   0.218s) [main thread     ]      AppController.cpp;74    INFO| System info; Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz (4 cores), 31 GB ram
                    2024-01-04 20;15;43.614 (   0.218s) [main thread     ]      AppController.cpp;75    INFO| OS info; Windows 10 (64-bit)
                    2024-01-04 20;15;43.614 (   0.219s) [main thread     ]      AppController.cpp;80    INFO| Host app; SketchUp Pro, 23.1.340
                    2024-01-04 20;15;43.614 (   0.219s) [main thread     ]SketchupWindowFloater.c;28    INFO| Found SketchUp window handle (title; SketchUp); 0000000000511A04
                    2024-01-04 20;15;43.629 (   0.233s) [main thread     ]       Orchestrator.cpp;90    INFO| All workers stopped
                    2024-01-04 20;17;31.214 ( 107.818s) [main thread     ]       Orchestrator.cpp;90    INFO| All workers stopped
                    2024-01-04 20;17;32.864 ( 109.468s) [main thread     ]             loguru.cpp;485   INFO| atexit
                    http://www.zz7.de
                    • pixelcruncherP
                      Thanks for sharing the log!
                      Based on the PC specs I see in the log, Rayscaper should just work fine for your laptop. Also from the logs it looks like the application runs fine for 109 seconds and then just exits, so no crash (note: I'm not disputing it's not crashing on your laptop, just that it seems like it didn't crash based on this log file).
                      A couple of questions:
                      • Does SU crash for you immediately if you start up, or if you load a specific file, or if you start rendering that file?
                      • Does it work for any other files, or for the default empty scene?
                      • Do you mind reproducing the crash again and sending me another log file?
                      Appreciate your help!
                      Cheers,
                      Thomas
                      • jo-keJ
                        jo-ke
                        I am back in my office and have the same issue.
                        I can not open again the file of the tramway, that I saved with the render settings a day before.
                        When I open an empty skp file it works, when I open the tramwayfile su imidiatly crashs.
                        I'll send you my file via email, to inspect.
                        here is the protocol:
                        2024-01-05 09;16;43.616 (   0.026s) [main thread     ]             loguru.cpp;770   INFO| Logging to 'C;\Users\KehlJ/SUEX_Rayscaper.log', mode; 'w', verbosity; 0
                        2024-01-05 09;16;43.778 (   0.188s) [main thread     ]      AppController.cpp;73    INFO| Running Rayscaper version 0.7.3
                        2024-01-05 09;16;43.779 (   0.189s) [main thread     ]      AppController.cpp;74    INFO| System info; Intel(R) Core(TM) i7-7700 CPU @ 3.60GHz (4 cores), 15 GB ram
                        2024-01-05 09;16;43.779 (   0.189s) [main thread     ]      AppController.cpp;75    INFO| OS info; Windows 10 (64-bit)
                        2024-01-05 09;16;43.779 (   0.189s) [main thread     ]      AppController.cpp;80    INFO| Host app; SketchUp Pro, 23.1.340
                        2024-01-05 09;16;43.779 (   0.189s) [main thread     ]SketchupWindowFloater.c;28    INFO| Found SketchUp window handle (title; SketchUp); 0000000000030BF2
                        2024-01-05 09;16;43.788 (   0.198s) [main thread     ]       Orchestrator.cpp;90    INFO| All workers stopped
                        2024-01-05 09;16;44.019 (   0.428s) [                ]   AssLibController.cpp;74    INFO| Loaded 1133 assets in 248.82 millis
                        http://www.zz7.de
                        • jo-keJ
                          jo-ke
                          I created a new scene, imported the same model, hit the refresh but some faces still remained blue.
                          I've sent you the file to review what's wrong.
                          http://www.zz7.de
                          • jo-keJ
                            jo-ke
                            next problems:
                            I created a scene, that I ususally use for my customers.
                            1: the drawer is not visible in render
                            2: the renderfile is not saved.
                            3: when I reopen the file SU again crushed
                            4: it is not possible to recover the skp file
                            really not a good start...
                            If you want, I can send you the Skp
                            http://www.zz7.de
                            • jo-keJ
                              jo-ke
                              fortunately it is possible to recover the file, when opening an empty one and importing the old one....
                              but the rayscaper- materialsettings of the model are lost
                              http://www.zz7.de
                              • majidM
                                majid
                                I am getting better at it.
                                  That's very nice Majid. DOF is perfect.
                                  • jo-keJ
                                    jo-ke
                                    thank you Thomas:
                                    one problem is solved:
                                    a 15 year old path with a "ü" inside was the problem.
                                    I have to rename it.
                                    I took the file to another folder and I can open it.
                                    interseting: more textures are blue now, I have to refresh each texture to get rid of the blue color.
                                    and the drawer is suddenly visible.
                                    The file was able to save and this is my first result:
                                    http://www.zz7.de
                                    • pixelcruncherP
                                      @jo-ke said:
                                      next problems:
                                      Do you mind sending the scene so I check why the drawer is not rendering?
                                      • pixelcruncherP
                                        @jo-ke said:
                                        thank you Thomas:
                                        Hmm, you shouldn't reload everything by hand, so that's another bug. One thing I found interesting is that there are a ton of texture load failures when peeking at the log file you sent me just now:
                                        Like for example:
                                        2024-01-05 14:00:39.847 ( 156.978s) [PreProcessWorker] ImageLoader.h:73 ERR| Image 'C:\Users\KehlJ\Downloads\Fencing_Diamond_Mesh.png' does not exist.
                                        2024-01-05 14:00:39.847 ( 156.978s) [PreProcessWorker] ImageLoader.h:73 ERR| Image 'C:\Users\KehlJ\Downloads\Translucent_Glass_Sky_Reflection_.jpg' does not exist.
                                        2024-01-05 14:00:39.847 ( 156.978s) [PreProcessWorker] ImageLoader.h:73 ERR| Image 'D:\Dropbox\su\texturen\holzboden\22. R3107L Wiÿnia Hamilton 130 x130 cm Pfleiderer.jpg' does not exist.
                                        So it looks like Rayscaper has issues loading those files.
                                        Regards,
                                        Thomas
                                        • pixelcruncherP
                                          Ooh very nice, always happy to see renders made with Rayscaper. Keep them coming!
                                          • jo-keJ
                                            jo-ke
                                            I've sent you the file with the cabinet, to inspect.
                                            http://www.zz7.de
                                            • 3 / 6
