    [Plugin] Helix along curve
    100 Posts 58 Posters 176.9k Views 58 Watching
    • K
      kapstuff
      A great tool. Tried a number of different helix plug-ins. This one best satisfied my needs, and much easier than many others.
      Would be handy if I could load the variables from a text file (or XLS). Have multiple helixes to create.
      • C
        chaster
        3dAlbertsoft, this is one of my FAVORITE plugins. Thank you so much for making and publishing it!
        By chance, would it be possible to modify the plugin so that it takes a second curve to define the radius of the helix? This feature would help me on a project greatly. πŸ˜„
        Regardless, WONDERFUL work! Thanks again for making it available to everyone!
        Eric
        • G
          gripple
          This is a great plugin, I have been using it in Sketchup 2017, however it doesn't seem to work/install in Sketchup 2018!
          Anyone else got it to work in Sketchup 2018?
          Thanks,
          Jez.
          • G
            gripple
            UPDATE!
            This does work in Sketchup 2018.
            Cheers,
            Jez.
              Ahmed0007
              @gripple said:
              UPDATE!
              Cheers,
              Jez.
              it's work fine for me on SU18 Windows
                Jami123
                Is it possible to find input on a helix I already drew? Or to match properties? Once I move on to another curve or experiment with scaling the helix I'm not able to find details on my previous input.
                • O
                  oyercab
                  This is working in Sketchup Pro 2020 (on Mac). Thank you!
                  • W
                    WhyDoesItMatter Newcomers
                    it seems the download link is not working. Is this discontinued by any chance?
                      The PluginStore entry downloads just fine...
                      https://sketchucation.com/pluginstore?pln=helix_along_curve
                      • P
                        paoloelia Newcomers
                        hi, thank u for ur work, but i wonder if i need to install your signature(idk if it's the right word) , the one that autenticates you are the one who created the plugin, in order to use, cause sketchup
                          @paoloelia said:
                          ... but i wonder if i need to install your signature(idk if it's the right word) , the one that autenticates you are the one who created the plugin, in order to use, cause sketchup
                          To what are you referring? This extension installs and works fine in all versions of SketchUp.
                          Please correct your forum profile. There is no Free/Make version of SketchUp 2022 as you pit in your profile.
                            Aurora2017SRL Newcomers
                            Hello !
                            Using Sketchup 2024 on MacOS, I have a very small problem with the plugin, which is that I can't find a way to not let the plugin show when the project starts up, ( I mean the floating shortcut not the shortcut in the pref bar )
                            Thank you!
                            Dave RD TIGT 2 Replies Last reply
                              Dave R @Aurora2017SRL
                              @Aurora2017SRL what do you mean by "floating shortcut"? Are you referring to the panel where you enter the values?
                                TIG Moderator @Aurora2017SRL
                                @Aurora2017SRL
                                This extension [actually a plugin] is well over a decade old !
                                It's also encrypted in the old RBS format.
                                It's unlikely to get updated.
                                Luckily the toolbar's code is in the editable RB file...
                                Find the file in Plugins, it's named Helix-along-curve-tool-0.9.rb
                                Edit it with a plain text editor [Notepad++ or on MAC bbedit || wrangler ?]
                                Find the line
                                helixD_bar.show
                                and edit it, adding extra text to read
                                helixD_bar.show if helixD_bar.get_last_state.abs == 1 # TB_VISIBLE/NEVER
                                Save the changes and restart SketchUp.
                                Now the toolbar's status will be remembered across sessions - i.e. either visible or off
                                • 5 / 5
