    Generic 2500teu feeder container ship
    97 Posts 11 Posters 13.4k Views 11 Watching
    • Bryan KB
      Wow. πŸ‘ πŸ‘
      • axeonaliasA
        axeonalias
        Foredeck & mast complete, liferaft and navlights will be done later when I do all the loose fittings, along with the anchors. Also made my first container, the textures are light balanced as they are rendered from a model so that I have control of the white balance and perspective
        Heres a 4k Overview
        https://live.staticflickr.com/65535/53159586601_72dbb7995e_o.jpg
        https://sketchfab.com/Axeonalias
        • axeonaliasA
          axeonalias
          Messing about with lights, will only be able to add a simple mesh light though for the lenses, no fancy cutting of the mesh for effects for me, going to try the alpha gradient trick but im not holding my hopes up that it will work
          • axeonaliasA
            axeonalias
            Superstructure mast is complete, nav lights coming soon, Cranes are also completed along with the spreader cages
            • axeonaliasA
              axeonalias
              Bridge exterior is complete, this is where I expect the ships master to spend most of his/her time, so ive hopefully added enough detail here to satisfy
                πŸ‘Š
                • Bryan KB
                  Impressive! πŸ‘
                  • Gus RG
                    Gus R
                    Looks great. Is this for work, pleasure or both?
                    www.instagram.com/gusrobatto/
                    www.facebook.com/gusrobatto
                    • axeonaliasA
                      axeonalias
                      Thanks guys! She will be used in both Vsng and Navismaster simulators ( Our own sim that we are developing )
                      Attached is a sneak peak of her in Navismaster, and here is our current progress with of my other vessels, the Monterey clipper fishing boat
                      You can join the progress here : https://discord.gg/gQEZfm9ukW
                      • Bryan KB
                        That looks like it will be an amazing simulator!
                          ^, it does indeed. He is a great advertisement for it too.
                          • axeonaliasA
                            axeonalias
                            Thanks, we will have a playable alpha ready in the next few days!
                            "A" Deck gets some attention, would love to do a full interior, hopefully in the future! especially since there`s a pool just below the poop deck on the starboard aft quarter
                            • ntxdaveN
                              ntxdave
                              Your level of detail blows my mind. πŸ˜„
                              Press F1...thank me later
                              • axeonaliasA
                                axeonalias
                                Thanks Nxtdave! have to start slowing down on adding detail though, im already at 60k polys!
                                Here she is shown in a Maersk Livery :
                                • axeonaliasA
                                  axeonalias
                                  Chain has been optimized, thats a 6k saving, mooring lines loaded into the drums and the cargo holds are complete. The rust will be coming soon. The watertight doors are modeled in detail and used to generate normal maps and diffuse textures to be used later
                                  • majidM
                                    majid
                                    Wow this is gonna be insane!
                                    • Gus RG
                                      Gus R
                                      Great work, axeonalias. I know I have to resist the temptation of adding detailed bolts everywhere but since they're components that can easily be changed. Another thing is splitting up symmetrical objects into separate components along an axis line so a bolt alone can be split into six components within the bolt component. If you're viewing an object from 100s of feet away you can't notice the threads or bolt details.
                                      Speaking of bolts. I just discovered that Blender has a built in bolt and nut maker which allows you to create bolts of various types on the fly. I tested it and exported as a dxf and imported into Sketchup and they clean up well and it's even a perfect solid. I have to go back to my donuts lessons from last spring when I was starting to learn Blender. Anyone that needs bolts or nuts for Sketchup can easily use this since all it requires is some rather basic keystrokes.
                                      • ntxdaveN
                                        ntxdave
                                        Wow, that tool is awesome! Is Blender passing SU by?
                                        • axeonaliasA
                                          axeonalias
                                          Thanks Guys, Appreciate the comments!
                                          Gus I cant imagine anything creating bolt heads quicker than SU! the slowest part is placing them, but the move-align-me tool makes that as quick as drag and drop, which is perfect for what I need, for this Lifeboat im going to try a high poly bake onto a low poly mesh, Diffuse and normal.
                                          • Gus RG
                                            Gus R
                                            Blender has a lot of features and you can't beat it for organic and complicated forms but it's too complicated to surpass Sketchup. I have yet to learn Blender but it's a lot easier to lay out and dimension buildings in Sketchup than it is in Blender. It's free which is great. I was considering Rhino at one point since it allow dimensioning similar to Autocad where in Blender it's somewhat of a mystery. I'd like to be able to use both.
                                            • 2 / 5
