    Generic 2500teu feeder container ship
    97 Posts 11 Posters 7.6k Views 11 Watching
    • Bryan KB Offline
      Impressive! πŸ‘
      • Gus RG Offline
        Gus R
        Looks great. Is this for work, pleasure or both?
        www.instagram.com/gusrobatto/
        www.facebook.com/gusrobatto
        • axeonaliasA Offline
          axeonalias
          Thanks guys! She will be used in both Vsng and Navismaster simulators ( Our own sim that we are developing )
          Attached is a sneak peak of her in Navismaster, and here is our current progress with of my other vessels, the Monterey clipper fishing boat
          You can join the progress here : https://discord.gg/gQEZfm9ukW
          https://sketchfab.com/Axeonalias
          • Bryan KB Offline
            That looks like it will be an amazing simulator!
              ^, it does indeed. He is a great advertisement for it too.
                axeonalias
                Thanks, we will have a playable alpha ready in the next few days!
                "A" Deck gets some attention, would love to do a full interior, hopefully in the future! especially since there`s a pool just below the poop deck on the starboard aft quarter
                • ntxdaveN Offline
                  ntxdave
                  Your level of detail blows my mind. πŸ˜„
                  Press F1...thank me later
                    axeonalias
                    Thanks Nxtdave! have to start slowing down on adding detail though, im already at 60k polys!
                    Here she is shown in a Maersk Livery :
                      axeonalias
                      Chain has been optimized, thats a 6k saving, mooring lines loaded into the drums and the cargo holds are complete. The rust will be coming soon. The watertight doors are modeled in detail and used to generate normal maps and diffuse textures to be used later
                      • majidM Offline
                        majid
                        Wow this is gonna be insane!
                        • Gus RG Offline
                          Gus R
                          Great work, axeonalias. I know I have to resist the temptation of adding detailed bolts everywhere but since they're components that can easily be changed. Another thing is splitting up symmetrical objects into separate components along an axis line so a bolt alone can be split into six components within the bolt component. If you're viewing an object from 100s of feet away you can't notice the threads or bolt details.
                          Speaking of bolts. I just discovered that Blender has a built in bolt and nut maker which allows you to create bolts of various types on the fly. I tested it and exported as a dxf and imported into Sketchup and they clean up well and it's even a perfect solid. I have to go back to my donuts lessons from last spring when I was starting to learn Blender. Anyone that needs bolts or nuts for Sketchup can easily use this since all it requires is some rather basic keystrokes.
                          • ntxdaveN Offline
                            ntxdave
                            Wow, that tool is awesome! Is Blender passing SU by?
                              axeonalias
                              Thanks Guys, Appreciate the comments!
                              Gus I cant imagine anything creating bolt heads quicker than SU! the slowest part is placing them, but the move-align-me tool makes that as quick as drag and drop, which is perfect for what I need, for this Lifeboat im going to try a high poly bake onto a low poly mesh, Diffuse and normal.
                              • Gus RG Offline
                                Gus R
                                Blender has a lot of features and you can't beat it for organic and complicated forms but it's too complicated to surpass Sketchup. I have yet to learn Blender but it's a lot easier to lay out and dimension buildings in Sketchup than it is in Blender. It's free which is great. I was considering Rhino at one point since it allow dimensioning similar to Autocad where in Blender it's somewhat of a mystery. I'd like to be able to use both.
                                  axeonalias
                                  Decided to find a shipyard for the renders, after much trial and error, there is a result. This is the mid detail mesh, still need to find a way to get the highest detail mesh to work, detail isnt good enough for close up renders at the moment
                                  • ntxdaveN Offline
                                    ntxdave
                                    Unbelievable! πŸ‘
                                      My inner five year old say's, "Wow". πŸ‘Š πŸ˜„
                                      • alvisA Offline
                                        alvis
                                        An engineering miracle πŸ‘
                                          axeonalias
                                          The bridge wing console is modeled, decals coming soon, not sure how im going to deal with the lid in vsng just yet, but in Navismaster it will be easy to animate and hinge as it should when clicking on it, this pretty much wraps up the exterior modeling for the ship, ill be doing final touch up`s and then proceed to the fun part...unwrapping
                                          • ntxdaveN Offline
                                            ntxdave
                                            The details and precision in your models blows me away. πŸ‘ πŸ‘
                                            You must use a lot of plugins to obtain this level of detail. πŸ‘
                                            • 3 / 5
