    Generic 2500teu feeder container ship
    97 Posts 11 Posters 6.6k Views 11 Watching
    • Bryan KB Offline
      Just stunning. The speed and detail are just stunning. 😲
      • axeonaliasA Offline
        axeonalias
        Thanks Bryan, but a stomach bug caught up to me forcing me to rest for 2 days! good time to spend collecting reference though πŸ˜›
        Deck level gangway details complete, small details added here and there, next the foredeck needs its final touches, then I think the superstructure mast needs attention
        https://sketchfab.com/Axeonalias
        • Bryan KB Offline
          Wow. πŸ‘ πŸ‘
            axeonalias
            Foredeck & mast complete, liferaft and navlights will be done later when I do all the loose fittings, along with the anchors. Also made my first container, the textures are light balanced as they are rendered from a model so that I have control of the white balance and perspective
            Heres a 4k Overview
            https://live.staticflickr.com/65535/53159586601_72dbb7995e_o.jpg
              axeonalias
              Messing about with lights, will only be able to add a simple mesh light though for the lenses, no fancy cutting of the mesh for effects for me, going to try the alpha gradient trick but im not holding my hopes up that it will work
                axeonalias
                Superstructure mast is complete, nav lights coming soon, Cranes are also completed along with the spreader cages
                  axeonalias
                  Bridge exterior is complete, this is where I expect the ships master to spend most of his/her time, so ive hopefully added enough detail here to satisfy
                    πŸ‘Š
                    • Bryan KB Offline
                      Impressive! πŸ‘
                      • Gus RG Offline
                        Gus R
                        Looks great. Is this for work, pleasure or both?
                        www.instagram.com/gusrobatto/
                        www.facebook.com/gusrobatto
                          axeonalias
                          Thanks guys! She will be used in both Vsng and Navismaster simulators ( Our own sim that we are developing )
                          Attached is a sneak peak of her in Navismaster, and here is our current progress with of my other vessels, the Monterey clipper fishing boat
                          You can join the progress here : https://discord.gg/gQEZfm9ukW
                          • Bryan KB Offline
                            That looks like it will be an amazing simulator!
                              ^, it does indeed. He is a great advertisement for it too.
                                axeonalias
                                Thanks, we will have a playable alpha ready in the next few days!
                                "A" Deck gets some attention, would love to do a full interior, hopefully in the future! especially since there`s a pool just below the poop deck on the starboard aft quarter
                                • ntxdaveN Offline
                                  ntxdave
                                  Your level of detail blows my mind. πŸ˜„
                                  Press F1...thank me later
                                    axeonalias
                                    Thanks Nxtdave! have to start slowing down on adding detail though, im already at 60k polys!
                                    Here she is shown in a Maersk Livery :
                                      axeonalias
                                      Chain has been optimized, thats a 6k saving, mooring lines loaded into the drums and the cargo holds are complete. The rust will be coming soon. The watertight doors are modeled in detail and used to generate normal maps and diffuse textures to be used later
                                      • majidM Offline
                                        majid
                                        Wow this is gonna be insane!
                                        • Gus RG Offline
                                          Gus R
                                          Great work, axeonalias. I know I have to resist the temptation of adding detailed bolts everywhere but since they're components that can easily be changed. Another thing is splitting up symmetrical objects into separate components along an axis line so a bolt alone can be split into six components within the bolt component. If you're viewing an object from 100s of feet away you can't notice the threads or bolt details.
                                          Speaking of bolts. I just discovered that Blender has a built in bolt and nut maker which allows you to create bolts of various types on the fly. I tested it and exported as a dxf and imported into Sketchup and they clean up well and it's even a perfect solid. I have to go back to my donuts lessons from last spring when I was starting to learn Blender. Anyone that needs bolts or nuts for Sketchup can easily use this since all it requires is some rather basic keystrokes.
                                          • ntxdaveN Offline
                                            ntxdave
                                            Wow, that tool is awesome! Is Blender passing SU by?
                                            • 2 / 5
