    2.2k Posts 482 Posters 854.1k Views 487 Watching
      cdfrank Newcomers
      PLEASE HELP!!!
      I'm trying to use the Curviloft extention in Sketchup 2023. I've never used and Fredo plugins and have limited experience with Sketchup. After watching some instructional videos, I thought I figured out how to install the extensions correctly, and I was under the impression that it was available for a 30 day free trial period. Well, I just installed everything about an hour ago, and the very first time I tried to use Curviloft, a message popped up saying my trial period had expired. I've never even used it before! Someone please tell me what I am doing wrong here!
      I have no problem paying for the extensions, but I want to try them out first to make sure I'll be able to do what I need to do with them.
        Did you install the rquired Sketchucation Extension Store tool? Did you install SketchUp 2023 correctly? That requires right clicking the installer file and selecting Run as adminstrator. Did you quit and restart SketchUp after installing the extensions?
          dmswn2147
          please help me!
          I clicked activate license
          However, the license does not apply and an error window appears
            Its either your network blocking communication or software, like an antivirus stopping.
              GM2013
              @fredo6 said:
              @gus r said:
              Fredo fixed it this morning.
              Yes I did. Thanks Gus for signaling.
              I have a license for this plugin and I am attempting to use on a new computer and getting an error message "not licensed". When I attempt to validate i get a "Error in License validation. License seat exceeded" message."
              Please help
                Please help
                You need to either release seats at your devices using seats or if those devices are running Sketchucation Tool 4.3.1 you can reease seats at https://sketchucation.com/webshop/my-licences.php
                  aprjeesus
                  Hi I use JointPushPull rb on two computers, but recently it doesn't work with messages like attachments.
                  Check and answer please.
                  • F Offline
                    francisquitof
                    @Fredo I´m having a problem with joint push pull, I´ve activated it on two machines, but today, I dont know why?, a message appeared saying that the trial period has expired, I tried to activate it and it says that I have exceeded the seats. I wanted to release seats in my license manager account but this extension doesn´t allow me to do it, other extensions have a box to check it and release seats but joint push pull doesn't.
                    • fredo6F Offline
                      I released all seats for JPP
                        How can I controll my license. Check and answer please.
                        Please run Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command and copy/paste text into reply
                          ghibby
                          Hi Fredo,
                          Great set of plugins, I have an issue with one of my license on JointPushPull. I was unable to release a license due to hardware failure and have all seats taken (3 of 3) and unable to release on of the seats for this plugin - how can this be resolved without access to the computer it references? Thanks, Ben
                            aprjeesus
                            Here is text.
                            Fredo6 Plugins Information on 2023-08-03 21:29:36 +0900
                            • Platform: x64-mswin64_140 - Ruby: 2.7.7
                            • Sketchup: 23.0.419
                            • LibFredo6: v13.9a
                            • LibFredo6 Binary loaded
                            • Sketchucation ExtensionStore: 4.3.1
                            • SCFLicense: v6.1a - 72
                            • Fredo6 Plugins
                              FredoTools v4.2a
                              JointPushPull v4.6a
                              Signature File: 2023-03-21 10:21:15 +0900
                              Update Libfredo to 14.1a
                              Use Extensions > Sketchucation > ExtensionStore to launch dialog
                              Either Search or paste pln=libfredo to install latest version
                              https://i.imgur.com/xr6uEx7.png
                              Restart SketchUp
                              Download your license files from https://sketchucation.com/webshop/my-licences.php and use Tools > Fredo Collection > Joint PushPull > License... to activate the license file
                              Repeat for other extensions as needed
                                aprjeesus
                                Restart SketchUp
                                I did as you told me. but its not working yet.
                                This time I added a log too.
                                  Please run Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command and copy/paste text into your reply
                                    aprjeesus
                                    here is
                                    Fredo6 Plugins Information on 2023-08-04 21:53:58 +0900
                                    • LibFredo6: v14.1a
                                    • Fredo6 Plugins
                                      FredoTools v4.2a
                                      JointPushPull v4.6a
                                      Close SketchUp
                                      Download license files from https://sketchucation.com/webshop/my-licences.php to your Downloads folder
                                      Go to C:\Users\SomeName\AppData\Local\SCF Licenses
                                      Delete SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt file
                                      Start SketchUp
                                      Go to Tools > Fredo Collection > Joint PushPull > License...
                                      Click Activate
                                      Browse to Downloads folder and select license file and click Open
                                      Does it activate?
                                        LucaJones Newcomers
                                        The process for licensing extensions on Sketchucation seems straightforward. Purchasing the license and validating it within Sketchup can be done easily. It's great that a purchased license covers all past and future Sketchup versions and allows activation on multiple computers. The ability to release a license seat is a helpful feature. Overall, it appears to be a user friendly licensing system.
                                          standupxx
                                          Hello I purchased license. But evertime I try to activate it, It occurs an Error (ERROR_A04)
                                          I tried to erased the Signature File that you adivsed but still same error happened.
                                          I paid license twice so have two license, both of them have same problem
                                          Please let me know how to fix this problem
                                            Can you update Sketchucation Tools to 4.3.1 and Libfredo to 14.1
                                            https://sketchucation.com/plugin/696-sketchucationtools
                                            https://sketchucation.com/pluginstore?pln=LibFredo6
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 109
                                            • 110
                                            • 14 / 110
