    2.3k Posts 515 Posters 2.8m Views 520 Watching
      @gm2013 said:
      I have a license for this plugin and I am attempting to use on a new computer and getting an error message "not licensed". When I attempt to validate i get a "Error in License validation. License seat exceeded" message."
      Please help
      You need to either release seats at your devices using seats or if those devices are running Sketchucation Tool 4.3.1 you can reease seats at https://sketchucation.com/webshop/my-licences.php
        aprjeesus
        Hi I use JointPushPull rb on two computers, but recently it doesn't work with messages like attachments.
        Check and answer please.
        • F
          francisquitof
          @Fredo I´m having a problem with joint push pull, I´ve activated it on two machines, but today, I dont know why?, a message appeared saying that the trial period has expired, I tried to activate it and it says that I have exceeded the seats. I wanted to release seats in my license manager account but this extension doesn´t allow me to do it, other extensions have a box to check it and release seats but joint push pull doesn't.
          • fredo6F
            I released all seats for JPP
              How can I controll my license. Check and answer please.
              Please run Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command and copy/paste text into reply
              • G
                ghibby
                Hi Fredo,
                Great set of plugins, I have an issue with one of my license on JointPushPull. I was unable to release a license due to hardware failure and have all seats taken (3 of 3) and unable to release on of the seats for this plugin - how can this be resolved without access to the computer it references? Thanks, Ben
                  aprjeesus
                  Here is text.
                  Fredo6 Plugins Information on 2023-08-03 21:29:36 +0900
                  • Platform: x64-mswin64_140 - Ruby: 2.7.7
                  • Sketchup: 23.0.419
                  • LibFredo6: v13.9a
                  • LibFredo6 Binary loaded
                  • Sketchucation ExtensionStore: 4.3.1
                  • SCFLicense: v6.1a - 72
                  • Fredo6 Plugins
                    FredoTools v4.2a
                    JointPushPull v4.6a
                    Signature File: 2023-03-21 10:21:15 +0900
                    Update Libfredo to 14.1a
                    Use Extensions > Sketchucation > ExtensionStore to launch dialog
                    Either Search or paste pln=libfredo to install latest version
                    https://i.imgur.com/xr6uEx7.png
                    Restart SketchUp
                    Download your license files from https://sketchucation.com/webshop/my-licences.php and use Tools > Fredo Collection > Joint PushPull > License... to activate the license file
                    Repeat for other extensions as needed
                      aprjeesus
                      Restart SketchUp
                      I did as you told me. but its not working yet.
                      This time I added a log too.
                        Please run Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command and copy/paste text into your reply
                          aprjeesus
                          here is
                          Fredo6 Plugins Information on 2023-08-04 21:53:58 +0900
                          • LibFredo6: v14.1a
                          • Fredo6 Plugins
                            FredoTools v4.2a
                            JointPushPull v4.6a
                            Close SketchUp
                            Download license files from https://sketchucation.com/webshop/my-licences.php to your Downloads folder
                            Go to C:\Users\SomeName\AppData\Local\SCF Licenses
                            Delete SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt file
                            Start SketchUp
                            Go to Tools > Fredo Collection > Joint PushPull > License...
                            Click Activate
                            Browse to Downloads folder and select license file and click Open
                            Does it activate?
                            • L
                              LucaJones Newcomers
                              The process for licensing extensions on Sketchucation seems straightforward. Purchasing the license and validating it within Sketchup can be done easily. It's great that a purchased license covers all past and future Sketchup versions and allows activation on multiple computers. The ability to release a license seat is a helpful feature. Overall, it appears to be a user friendly licensing system.
                                standupxx
                                Hello I purchased license. But evertime I try to activate it, It occurs an Error (ERROR_A04)
                                I tried to erased the Signature File that you adivsed but still same error happened.
                                I paid license twice so have two license, both of them have same problem
                                Please let me know how to fix this problem
                                  Can you update Sketchucation Tools to 4.3.1 and Libfredo to 14.1
                                  https://sketchucation.com/plugin/696-sketchucationtools
                                  https://sketchucation.com/pluginstore?pln=LibFredo6
                                    realanimationworks Newcomers
                                    Can you please share a link to buy this product as we use this kind of plugin a lot?
                                      Share a purchase link to something you already use? Sketchucation Tools is free
                                      Sketchucation Tools | SketchUcation
                                      (sketchucation.com)
                                      If you want to purchase a license for the extensions other sell here you can see them here...
                                      SketchUcation | List of Plugin Licences
                                      (sketchucation.com)
                                      • B
                                        brksnr
                                        I unfortunately formetted my laptop before I release th licenses and I cannot release them online due to versin being old I guess. I still have that pc but I don't know how can I release my licenses which I know the HWID's Is there any way you can help me out Dear Fredo ?
                                        • fredo6F
                                          You have 4 plugins with 3 seats each.
                                          I can release all seats, but you will need to revalidate on all your computers.
                                          • B
                                            brksnr
                                            I would be glad if you release all my licenses, I will relicense them afterwards.
                                            • 83
                                            • 84
                                            • 85
                                            • 86
                                            • 87
                                            • 115
                                            • 116
                                            • 85 / 116
