    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.7m Views 202 Watching
      @ethesaunde said:
      I just installed it for the first time and I am getting a "Free trial expired on March 25" error.
      Did you first install the current version of the Sketchucation ExtensionStore tool?
      • E Offline
        ethesaunde
        Yes, I did install v4.2.9
        • E Offline
          ethesaunde
            rv1974
            Fredo, any chance to fix this 14 y.o. critical bug? even staying away from the borders the result is distressing
            Maybe, as alternative, FredoSpline could work on surface? Especially 'Convert' command
              chrissfcs
              Love the tools on surface tool, used it for years but have been getting this error in the attached image when sketch up opens. the menus do not show up the next time sketchup loads.
                leall
                Olá,
                Eu estou com problemas para ativar o plugin comprado. Segui todas os passos indicados por vocÊs, mas mesmo assim não deu certo.
                Na aba "global status of plugins" não aparece minha licença.
                Como eu poderia prosseguir? Obrigada
                  Trnaslated by Google:
                  @leall said:
                  Olá,
                  I'm having trouble activating the purchased plugin. I followed all the steps indicated by you, but it still didn't work.
                  In the "global status of plugins" tab, my license does not appear.
                  How could I proceed? Thanks
                  Do you have the current version of LibFredo6 and the Sketchucation Tool installed? Have you restarted SketchUp? What version of SketchUp are you actually using? Your profile says 2021 Free/Make but there is no such version.
                  • fredo6F Offline
                    Você poderia ser mais explícito sobre qual é o problema? Você recebe uma mensagem?
                      O que você fez com seus arquivos de licença?
                      Você os armazenou em seu computador e os 'validou' para a extensão relacionada usando o item de menu relevante?
                      Mais informações são necessárias para estabelecer seu problema exato...
                      What have you done with your license files ?
                      Have you stored them on your computer and then 'validated' them for the related extension using the relevant menu item ?
                      More info is needed to establish your exact problem...
                        aiden
                        When I draw a line on even a very simple surface, Tools on surface takes an enormous amount of time to complete the task. I'm running on a very powerful workstation with lots of ram, and the last test I ran had only two faces. Any idea what causes this behavior?
                          @aiden said:
                          I'm running on a very powerful workstation with lots of ram ...
                          Still SketchUp 2018? What graphics card? Can you share you simple model?
                            aiden
                            Hi Dave - thanks for your response - Here's more specific info:
                            Sketchup Pro 2021, 21.1.299 (classic perpetual license)
                            Intel Core i9 10900K, 3.7GHz, 64GB ram,
                            Windows 10 Pro. RTX 3090, (528.02 driver)
                            LibFredo6 13.9a, Tools on Surface 2.5a. Fresh install.
                            The plugin works fine on my workstation in a model with very little geometry.
                            It also works fine on the somewhat less powerful workstation of my coworker,
                            who is working on an identical copy of the file I am working on. (???)
                            He is using a slightly older copy of Sketchup Pro 21.0.391. (Subscription plan)
                              Please update your profile.
                              What graphics card?
                              That leads me to the graphics card. What graphics card does your coworker's computer have?
                                aiden
                                My Coworker is using 2 GTX 1080 cards, running on driver version 528.49
                                  aiden
                                  I am now downloading the latest drivers. Will let you know if it helps.
                                    A solid graphics card with good OpenGL support. The Nvidia GeForce and GTX-series graphics cards have always been recommended for SketchUp. Integrated GPUs such as the ones you are using have never been recommended because they historically have poor OpenGL support and because they are using CPU RAM instead of dedicated RAM for graphics processing.Based on the GPUs your coworker's computer would be a better choice for SketchUp.
                                      aiden
                                      Just a note - if by "integrated GPU" you mean an on-board GPU, my RTX card is a dedicated separate unit like my coworker's GPU, using a PCI Express slot on the motherboard. The RTX 3090 is a fairly powerful unit with 24GB dedicated ram.
                                      Did I rightly understand what you meant by "Integrated GPU"?
                                      Second note - updated to newest driver (Studio) and still have very poor performance - but in fairness to Tools On Surface - my performance is slower in every aspect than my coworker's machine.
                                      Perhaps the RTX cards have an issue here? I appreciate your time looking into this with me Dave.
                                      • panixiaP Offline
                                        panixia
                                        @dave r said:
                                        By no means Nvidia rtx3090 is an integrated gpu.
                                        It's an high-end discrete gpu and it's actually waaaay more modern and powerful than the 1080.
                                        • panixiaP Offline
                                          panixia
                                          I would suggest to check into the Nvidia control panel (you can find in the context menu if you right click on an empty space in your Windows desktop bakcground), go to application specific settings, scroll the drop down menu to select Sketchup 2021 and make sure that's using the 3090 and NOT the integrated gpu.
                                            @aiden said:
                                            Just a note - if by "integrated GPU" you mean an on-board GPU, my RTX card...
                                            Sorry. I missed your RTX card and I was working with someone else at the same time who has an integrated GPU.
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 31 / 32
