    2.3k Posts 515 Posters 2.8m Views 520 Watching
    • X
      xyhcwu
      @rich o brien said:
      @xyhcwu said:
      Yes, it deactivates after a few days without internet access, I activated it again today and for some areas where I need to hook up a VPN it is awful.
      What's the issue? If you mask your IP through VPN and that software is not whitelisted to allow communication with a particular URL you will encounter problems.
      I'm not sure what frequency Fredo has set on his license check. That's under his control. But allowing your VPN to communicate is under your control.
      What I mean is that Sketchup cannot connect to the network without my VPN and the Fredo plugin cannot automatically verify the license, then after a while it asks to activate it again.
      Next I need to turn on the VPN to connect to the network to activate the license, as I don't use my VPN very often, so it causes this to be repeated over and over again.
      Wish it had a longer auto-verify time
        sged mash
        Hey, I have a license for the cloth work plugin with three seats. My old pc broke and crashed; how do I remove the seat occupied by a dead and inactive computer?
          Selenaveber
          bonjour,
          j'ai acheté la licence round corner et la licence fredocorner mais je n'arrive a intsaller aucune des deux. J'ai ce message d'erreur et quand jessais d'enlever le lien signature rien ne change...
            Your screenshot shows you have an old version of the licensing system installed.
            Please update to the newest versions of the SketchUcation toolset [for the newer licensing] and LibFredo6.
            After the installation restart SketchUp to sync everything...
            If you still have problems let us know...
            Votre capture d'écran montre que vous avez installé une ancienne version du système de licence.
            Veuillez mettre à jour les dernières versions de l'ensemble d'outils SketchUcation [pour la nouvelle licence] et LibFredo6.
            Après l'installation, redémarrez SketchUp pour tout synchroniser...
            Si vous avez encore des problèmes, faites-le nous savoir...
              Selenaveber
              malheureusement rien n'a changer... quand je supprime le fichier signature et que je revalide j'ai une fenetre avec B03 qui saffiche.
                Something has changed - it's now a B03 error message ! [I'm not even sure what that means because it's not listed... hopefully Fredo can explain it]
                Meanwhile can you provide a screenshot of the licensing dialog - so we can see the version now... the version of the SketchUcation toolset and LibFredo6...
                Quelque chose a changé - c'est maintenant un message d'erreur B03 ! [Je ne suis même pas sûr de ce que cela signifie parce que ce n'est pas répertorié... j'espère que Fredo pourra l'expliquer]
                En attendant, pouvez-vous fournir une capture d'écran de la boîte de dialogue de licence - afin que nous puissions voir la version maintenant... la version de l'ensemble d'outils SketchUcation et LibFredo6...
                  Selenaveber
                  la fenetre ne s'affiche pas correctement pour le moment je pense que ma photo ne va pas vous aider...
                    I'll get Fredo to become involved - it's his expertise...
                    Je vais demander à Fredo de s'impliquer - c'est son expertise...
                    • fredo6F
                      Did you upgrade both LibFredo6 and SketchucationStore?
                      If the dialog content does not display, can you try to slightly resize it.
                      Avez-vous mis à jour LibFredo6 et SketchucationStore ?
                      Si le contenu de la boîte de dialogue ne s'affiche pas, pouvez-vous essayer de la redimensionner légèrement.
                      • G
                        guess15
                        hello. i need help on whitelisting the sketchucation domain. im having the same problem about the licensing validation. kindly help ASAP
                        • G
                          guess15
                          kindly help with the roundcorner license validation issue please.
                            What version of SketchUp are you using? What operating system? Kindly update your forum profile ASAP.
                            Do you have the current version of LibFredo6 and the Sketchucation ExtensionStore installed?
                            Show any messages you are getting when you try to validate the RoundCorner license.
                            • fredo6F
                              Whitelisting a domain is not something related to Sketchup or the plugins. Just get help on the Internet for your platform.
                                Selenaveber
                                Oui tout est a jour mais ça ne fonctionne toujours pas...
                                  So everything is up to date...
                                  But the computer name is still incorrect...
                                  Have you tried deleting the signature-file as the error message says ?
                                  You need to restart SketchUp afterwards...
                                  Perhaps Fredo can comment... have you any non-ASCII characters in your computer name - e.g. accented letters ?
                                  Donc tout est à jour...
                                  Mais le nom de l'ordinateur est toujours incorrect...
                                  Avez-vous essayé de supprimer le fichier de signature comme le message d'erreur indique ?
                                  Vous devez ensuite redémarrer SketchUp...
                                  Peut-être que Fredo peut commenter... avez-vous des caractères non ASCII dans le nom de votre ordinateur - par ex. lettres accentuées ?
                                  • G
                                    guess15
                                    [/img]
                                    i have updated all the plugins you mentioned. and it seems it will work. but my licensed seats said it is maxed. can you clear everything on the seats so i will have it fresh. kindly response urgently. thank you so much.
                                      Selenaveber
                                      Pourquoi le nom de l'ordinateur est incorrect j'ai tout fait depuis cet ordinateur la...
                                      J'ai supprimer le fichier de signature comme le message d'erreur indique revalider et quand je revalide il y a une fenetre avec B03 qui s'affiche. Rien ne change quand je redemarre sketchup.
                                      Le nom du fichier est correct sans accent ni symbole.
                                      • fredo6F
                                        All seats cleared.
                                        • G
                                          guess15
                                          @fredo6 said:
                                          All seats cleared.
                                          thank you. appreciate you guys for being so so responsive. more power to you guys.
                                          • T
                                            Terrame
                                            How am I supposed to purchase your licence if I'm from a country where paypal isn't available?
                                            • 71
                                            • 72
                                            • 73
                                            • 74
                                            • 75
                                            • 115
                                            • 116
                                            • 73 / 116
