    [Plugin][$] ThruPaint - v2.9a - 21 Apr 26
    195 Posts 55 Posters 90.1k Views 55 Watching
    • JQLJ
      JQL
      I got one but things were actually working:
      Error; #<TypeError; nil can't be coerced into Integer>
      c;/users/joao/appdata/roaming/sketchup/sketchup 2023/sketchup/plugins/fredo6_thrupaint/thrupainttool.rbe;1336;in `-'
      c;/users/joao/appdata/roaming/sketchup/sketchup 2023/sketchup/plugins/fredo6_thrupaint/thrupainttool.rbe;1336;in `handle_move'
      c;/users/joao/appdata/roaming/sketchup/sketchup 2023/sketchup/plugins/fredo6_thrupaint/thrupainttool.rbe;4200;in `onMouseMove'
      www.casca.pt
      Visit us on facebook!
      • JQLJ
        JQL
        Hi Fredo, I'd like that the axis, that show up when you want to repaint a texture, would appear as they used to be in Thrupaint 1. Many times it's really difficult to paint a face by making the mouse pointer close to the correct edge. It might be hidden or in a position where it's hard to get right and Thrupaint one was perfect in this regard.
        Do you think that would be possible to revert? Maybe give us the option again?
        www.casca.pt
        • fredo6F
          The No-Axis option allows painting with UV direction taken from model axes (as the Paint Bucket tool), which is not possible with the old ThruPaint.
          I can certainly introduce a Default Parameter setting to disable this behavior.
          However, I don't understand why you have difficulty getting close to edges.
          • JQLJ
            JQL
            It requires more accuracy and some times the edge is hidden. Before I would simply point to a face and when the gizmo was closer to a corner than the others the red and green axis immediately popped up. It was much faster and predictable.
            www.casca.pt
              jejo303
              @jkoll66 said:
              I'm having an issue where the Paint Face toolbar won't load. I've attached a screenshot and the console log. Thanks in advance for any help.
              Same problem for me. Any solution?
              • fredo6F
                Could you check that you have installed LibFredo6 v13.6.
                  jejo303
                  After rebooting it works! Thanks.
                    rajab0v
                    How to buy this plugin as im not able to use it now and I cant find the page for buying it
                      al2430 Newcomers
                      Hello,
                      i cant Purchase License, have anybody the same issue?
                      iam using the link in Sketchup while installed Thrupaint:
                      SketchUcation | Cart
                      (sketchucation.com)
                      thanks.
                        al2430 Newcomers
                        @rajab0v said:
                        How to buy this plugin as im not able to use it now and I can't find the page for buying it, when I go to obtain license, it says on page: ERROR: Unknown plugin identifyer.
                        I have the same issue. Please Help.
                        • fredo6F
                          ThruPaint is free for the time being. NO license needed.
                          However, make sure you upgrade to the latest version of LibFredo6.
                            al2430 Newcomers
                            i have upgradet LibFredo6 and Thrupaint. It seems that they changed it and now it cost money. Her a picture with the License. But however it doesnt work with Purchase License..
                            • fredo6F
                              Could you migrate to LibFredo6 v13.8a.
                              I normally fixed the problem.
                              Sorry for inconvenience.
                              • K
                                km1035
                                Hello
                                When I press the buy button, I get this link
                                is the link correct?
                                https://sketchucation.com/purchase-smart.php?plugin=ThruPaint
                                • fredo6F
                                  @km1035 said:
                                  Hello
                                  Could you upgrade to LibFredo6 v13.9a. This has been fixed.
                                    djo
                                    I need help quick. I need to purchase a thrupaint 2 license but I can't find where to purchase it! Can please point me out where. Thank you.
                                    • fredo6F
                                      Could you upgrade to LibFredo6 v13.9a. It should solve the problem (no need for a license of ThruPaint).
                                      • I
                                        igorassis
                                        Hello , i can't buy the license, the link provided doesn't work
                                        • fredo6F
                                          Please just read the message above and upgrade to LibFredo6 v13.9.
                                            matsuo_lano
                                            Fixed it, thanks.
                                            Also, when the plugin eventually will become paid, is it possible just to buy the single plugin (instead of a package of some sorts)?
                                            You try to rearrange me 'till I'm sane
                                            • 4 / 10
