    [Plugin] FullScreen v5.1.3 (25 April 2024)
    285 Posts 79 Posters 451.4k Views 80 Watching
      Anton_S
      @joerg said:
      Bug: If you skip to the next scene with a shortcut, than its skipping 2 scenes in one step. Same thing backwards. (SU 2021 pro)
      Interesting find. Does that occur with the menu bar hidden or even with the menu bar visible?
      Edit: I can reproduce the bug with the menu bar hidden. Working on a fix.
        joerg
        Hi Anton,
        Thanks for your quick reply! As you suspected, the error only happens when the menu bar is hidden.
        A fix would be great! Thank you for the effort.
        • fredo6F Offline
          If te menu bar is truly hidden (at Windows level), then NO custom shortcut will work.
          What I do in LOTT is to increase the size of the Sketchup window so that the menu bar is outside the screen.
            Anton_S
            In fullscreen, I read all the sketchup shortcut and have my own keyboard WM_KEY_DOWN message handler which triggers the associated commands when the menubar is hidden.
            As an alternative, with regards to moving the window above, I believe you can get the height of the menubar and then use SetWindowPos with start position to be negative menubar height and and height to be screenheight + menubar height.
            To get menubar height: https://docs.microsoft.com/en-us/windows/win32/api/winuser/nf-winuser-getmenubarinfo?redirectedfrom=MSDN
              Anton_S
              @joerg said:
              Hi Anton,
              Updated!
                LeoHominis
                Essa extensão é uma das melhores que eu já baixei, colocando atalhos de teclado nela fica uma delicia o ambiente. Muito obrigado e parabéns por tornar o SketchUp MELHOR. 👊 👊 😎
                • designerbursaD Offline
                  designerbursa
                  c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/ams_windowsettings/imagesui.png
                    Anton_S
                    Why am I getting this error in ruby console?
                    It's a console log. Forgot to remove. Not an error.
                      rv1974
                      Anton could your tool apply dark theme to SU's UI elements? I'm so tired of this white\light grey
                      Thank you
                        Anton_S
                        Thank you
                        Sorry. Don't want to waste my time on this. This is something SketchUp should do on their end.
                          rv1974
                          @anton_s said:
                          Thank you
                          Too bad 😞 We'll soon celebrate 25 years with this pesky white.
                          not funny
                            Anton_S
                            Well you gotta appreciate the light and bright sometimes 😛
                              rv1974
                              Yeah with this white I can illuminate the room at night without turning the light on. Good for bills
                                Anton_S
                                You should tell that to Sketchup lol. They could definitely win a lot more users if they go green energy
                                  designerbursa
                                  I am using sketchup version 2021 and the error still persists...
                                  an image not in the plugin folder and the user path "%appdata%"
                                    maximumselfish
                                    Добрый день.
                                    Ожидается поддержка SU 2023?
                                      joerg
                                      Hi Anton,
                                      thanks once again for your very helpfull extension!
                                      I have a problem when the menu bar is hidden. Shortcuts are working, but one shortcut freezes the following shortcuts: Functions/Interact (I`m using your extension in presentations with dynamic components).
                                      Same problem on WIN10 and WIN11 Pro with SU2021Pro.
                                      Thanks for your help!
                                      Joerg
                                        Apollo Tuan
                                        After I installed it, I found it was not complete and only showed some of the features
                                        • shake1S Offline
                                          shake1
                                          Anton, please adapt for 2023. This is the head of all plugins.
                                            sarkarshomit
                                            So the plugin is still awaiting update for Sketchup 2023?
                                            I use this plugin a lot in Skup2021, but completely migrating to SU23, is not getting possible due to incompatible FS plugin
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 14 / 15
