    [Plugin] FullScreen v5.1.3 (25 April 2024)
    285 Posts 79 Posters 463.0k Views 80 Watching
      Anton_S
      @rv1974 said:
      Yeah with this white I can illuminate the room at night without turning the light on. Good for bills
      You should tell that to Sketchup lol. They could definitely win a lot more users if they go green energy
      • designerbursaD
        designerbursa
        c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/ams_windowsettings/imagesui.png
        Why am I getting this error in ruby console?
        I am using sketchup version 2021 and the error still persists...
        an image not in the plugin folder and the user path "%appdata%"
          maximumselfish
          Добрый день.
          Ожидается поддержка SU 2023?
            joerg
            Hi Anton,
            thanks once again for your very helpfull extension!
            I have a problem when the menu bar is hidden. Shortcuts are working, but one shortcut freezes the following shortcuts: Functions/Interact (I`m using your extension in presentations with dynamic components).
            Same problem on WIN10 and WIN11 Pro with SU2021Pro.
            Thanks for your help!
            Joerg
              Apollo Tuan
              After I installed it, I found it was not complete and only showed some of the features
              • shake1S
                shake1
                Anton, please adapt for 2023. This is the head of all plugins.
                  sarkarshomit
                  So the plugin is still awaiting update for Sketchup 2023?
                  I use this plugin a lot in Skup2021, but completely migrating to SU23, is not getting possible due to incompatible FS plugin
                    Anton_S
                    Hello everyone! This should work with SU2023. The incomplete UI is because SU2023 has undergone a major internal framework change and I no longer have the capability to manipulate some of the elements. Things like full-screen, should still work though. Let me know if otherwise.
                    S 1 Reply Last reply
                    • kimgaK
                      kimga
                      HI Anton,
                      I just installed the plugin. I have never used it, so not sure how it meant to work. I was looking for a way to fullscreen the working window to see the V-ray safe screen, unfortunately, I didn't manage this with your extension used with SketchUp 2023 running on Windows 11.
                      Good day!
                        sarkarshomit @Anton_S
                        @Anton_S No sir, its still not working with Su2023 on win10.
                        I so wish if u could give the plugin its much required overhaul.
                        When i press the fullscreen button check box, it does go in fullscreen, but it does not hide floating and docked toolbars, which i really use a lot for taking screenshots of my works.
                        • L
                          laughoutloud99
                          This plugin cannot load correctly in the su2024.
                          We used it to keep clean UI for years.
                          Please request a fix for it.
                          Thank you to anyone who can help.
                          • shake1S
                            shake1
                            The greatest value for me is to show/hide the toolbar or tray in one click.
                            The last time this worked was in SU 2022. This functionality is really missing.
                              Anton_S
                              Hi all, the plugin is now updated to work with the latest version of SU2023 and SU2024. Please note that the features in SU2023 and later are limited because SketchUp changed to a new, Qt-based framework, and I have not found a way to hack it.
                              D 1 Reply Last reply
                                Design_Dong @Anton_S
                                @Anton_S
                                @Anton_S said in [Plugin] FullScreen v5.1.3 (25 April 2024):
                                hope you can fix all functions in 2024
                                  joydeep70
                                  Fix it as early as possible. Study hard. God bless you.
                                  • 11
                                  • 12
                                  • 13
                                  • 14
                                  • 15
                                  • 14 / 15
