    [Plugin] FullScreen v5.1.3 (25 April 2024)
    285 Posts 79 Posters 463.0k Views 80 Watching
    • designerbursaD
      designerbursa
      c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/ams_windowsettings/imagesui.png
        Anton_S
        Why am I getting this error in ruby console?
        It's a console log. Forgot to remove. Not an error.
          rv1974
          Anton could your tool apply dark theme to SU's UI elements? I'm so tired of this white\light grey
          Thank you
            Anton_S
            Thank you
            Sorry. Don't want to waste my time on this. This is something SketchUp should do on their end.
              rv1974
              @anton_s said:
              Thank you
              Too bad 😞 We'll soon celebrate 25 years with this pesky white.
              not funny
                Anton_S
                Well you gotta appreciate the light and bright sometimes 😛
                  rv1974
                  Yeah with this white I can illuminate the room at night without turning the light on. Good for bills
                    Anton_S
                    You should tell that to Sketchup lol. They could definitely win a lot more users if they go green energy
                    • designerbursaD
                      designerbursa
                      I am using sketchup version 2021 and the error still persists...
                      an image not in the plugin folder and the user path "%appdata%"
                        maximumselfish
                        Добрый день.
                        Ожидается поддержка SU 2023?
                          joerg
                          Hi Anton,
                          thanks once again for your very helpfull extension!
                          I have a problem when the menu bar is hidden. Shortcuts are working, but one shortcut freezes the following shortcuts: Functions/Interact (I`m using your extension in presentations with dynamic components).
                          Same problem on WIN10 and WIN11 Pro with SU2021Pro.
                          Thanks for your help!
                          Joerg
                            Apollo Tuan
                            After I installed it, I found it was not complete and only showed some of the features
                            • shake1S
                              shake1
                              Anton, please adapt for 2023. This is the head of all plugins.
                                sarkarshomit
                                So the plugin is still awaiting update for Sketchup 2023?
                                I use this plugin a lot in Skup2021, but completely migrating to SU23, is not getting possible due to incompatible FS plugin
                                  Anton_S
                                  Hello everyone! This should work with SU2023. The incomplete UI is because SU2023 has undergone a major internal framework change and I no longer have the capability to manipulate some of the elements. Things like full-screen, should still work though. Let me know if otherwise.
                                  S 1 Reply Last reply
                                  • kimgaK
                                    kimga
                                    HI Anton,
                                    I just installed the plugin. I have never used it, so not sure how it meant to work. I was looking for a way to fullscreen the working window to see the V-ray safe screen, unfortunately, I didn't manage this with your extension used with SketchUp 2023 running on Windows 11.
                                    Good day!
                                      sarkarshomit @Anton_S
                                      @Anton_S No sir, its still not working with Su2023 on win10.
                                      I so wish if u could give the plugin its much required overhaul.
                                      When i press the fullscreen button check box, it does go in fullscreen, but it does not hide floating and docked toolbars, which i really use a lot for taking screenshots of my works.
                                      • L
                                        laughoutloud99
                                        This plugin cannot load correctly in the su2024.
                                        We used it to keep clean UI for years.
                                        Please request a fix for it.
                                        Thank you to anyone who can help.
                                        • shake1S
                                          shake1
                                          The greatest value for me is to show/hide the toolbar or tray in one click.
                                          The last time this worked was in SU 2022. This functionality is really missing.
                                            Anton_S
                                            Hi all, the plugin is now updated to work with the latest version of SU2023 and SU2024. Please note that the features in SU2023 and later are limited because SketchUp changed to a new, Qt-based framework, and I have not found a way to hack it.
                                            D 1 Reply Last reply
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 14 / 15
