    [Plugin] FullScreen v5.1.3 (25 April 2024)
    285 Posts 79 Posters 463.0k Views 80 Watching
      Anton_S
      @gianlucaf said:
      @awadrummer said:
      I love the plugin, but I was wondering if it would be possible to have Sketchup save the toggle for floating toolbars. I have to hide the floating toolbars manually every time I restart Sketchup even though I use Fullscreen to hide them and click the save and check the "Apply Saved On Start" option.
      Thank you!
      Chris B.
      Apparently I have the same problem, or maybe I don't quite understand how it works.
      Still a great help.
      Please update to version 5.1.0, where floating toolbars and dialogs are shown/hidden along with saved state.
        joerg
        Bug: If you skip to the next scene with a shortcut, than its skipping 2 scenes in one step. Same thing backwards. (SU 2021 pro)
          Anton_S
          Interesting find. Does that occur with the menu bar hidden or even with the menu bar visible?
          Edit: I can reproduce the bug with the menu bar hidden. Working on a fix.
            joerg
            Hi Anton,
            Thanks for your quick reply! As you suspected, the error only happens when the menu bar is hidden.
            A fix would be great! Thank you for the effort.
            • fredo6F
              If te menu bar is truly hidden (at Windows level), then NO custom shortcut will work.
              What I do in LOTT is to increase the size of the Sketchup window so that the menu bar is outside the screen.
                Anton_S
                In fullscreen, I read all the sketchup shortcut and have my own keyboard WM_KEY_DOWN message handler which triggers the associated commands when the menubar is hidden.
                As an alternative, with regards to moving the window above, I believe you can get the height of the menubar and then use SetWindowPos with start position to be negative menubar height and and height to be screenheight + menubar height.
                To get menubar height: https://docs.microsoft.com/en-us/windows/win32/api/winuser/nf-winuser-getmenubarinfo?redirectedfrom=MSDN
                  Anton_S
                  @joerg said:
                  Hi Anton,
                  Updated!
                  • L
                    LeoHominis
                    Essa extensão é uma das melhores que eu já baixei, colocando atalhos de teclado nela fica uma delicia o ambiente. Muito obrigado e parabéns por tornar o SketchUp MELHOR. 👊 👊 😎
                    • designerbursaD
                      designerbursa
                      c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/ams_windowsettings/imagesui.png
                        Anton_S
                        Why am I getting this error in ruby console?
                        It's a console log. Forgot to remove. Not an error.
                          rv1974
                          Anton could your tool apply dark theme to SU's UI elements? I'm so tired of this white\light grey
                          Thank you
                            Anton_S
                            Thank you
                            Sorry. Don't want to waste my time on this. This is something SketchUp should do on their end.
                              rv1974
                              @anton_s said:
                              Thank you
                              Too bad 😞 We'll soon celebrate 25 years with this pesky white.
                              not funny
                                Anton_S
                                Well you gotta appreciate the light and bright sometimes 😛
                                  rv1974
                                  Yeah with this white I can illuminate the room at night without turning the light on. Good for bills
                                    Anton_S
                                    You should tell that to Sketchup lol. They could definitely win a lot more users if they go green energy
                                    • designerbursaD
                                      designerbursa
                                      I am using sketchup version 2021 and the error still persists...
                                      an image not in the plugin folder and the user path "%appdata%"
                                        maximumselfish
                                        Добрый день.
                                        Ожидается поддержка SU 2023?
                                          joerg
                                          Hi Anton,
                                          thanks once again for your very helpfull extension!
                                          I have a problem when the menu bar is hidden. Shortcuts are working, but one shortcut freezes the following shortcuts: Functions/Interact (I`m using your extension in presentations with dynamic components).
                                          Same problem on WIN10 and WIN11 Pro with SU2021Pro.
                                          Thanks for your help!
                                          Joerg
                                            Apollo Tuan
                                            After I installed it, I found it was not complete and only showed some of the features
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 14 / 15
