    [Plugin] FullScreen v5.1.3 (25 April 2024)
    285 Posts 79 Posters 463.0k Views 80 Watching
      Anton_S
      @fredo6 said:
      If te menu bar is truly hidden (at Windows level), then NO custom shortcut will work.
      What I do in LOTT is to increase the size of the Sketchup window so that the menu bar is outside the screen.
      In fullscreen, I read all the sketchup shortcut and have my own keyboard WM_KEY_DOWN message handler which triggers the associated commands when the menubar is hidden.
      As an alternative, with regards to moving the window above, I believe you can get the height of the menubar and then use SetWindowPos with start position to be negative menubar height and and height to be screenheight + menubar height.
      To get menubar height: https://docs.microsoft.com/en-us/windows/win32/api/winuser/nf-winuser-getmenubarinfo?redirectedfrom=MSDN
        Anton_S
        @joerg said:
        Hi Anton,
        Thanks for your quick reply! As you suspected, the error only happens when the menu bar is hidden.
        A fix would be great! Thank you for the effort.
        Updated!
        • L
          LeoHominis
          Essa extensão é uma das melhores que eu já baixei, colocando atalhos de teclado nela fica uma delicia o ambiente. Muito obrigado e parabéns por tornar o SketchUp MELHOR. 👊 👊 😎
          • designerbursaD
            designerbursa
            c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/ams_windowsettings/imagesui.png
              Anton_S
              Why am I getting this error in ruby console?
              It's a console log. Forgot to remove. Not an error.
                rv1974
                Anton could your tool apply dark theme to SU's UI elements? I'm so tired of this white\light grey
                Thank you
                  Anton_S
                  Thank you
                  Sorry. Don't want to waste my time on this. This is something SketchUp should do on their end.
                    rv1974
                    @anton_s said:
                    Thank you
                    Too bad 😞 We'll soon celebrate 25 years with this pesky white.
                    not funny
                      Anton_S
                      Well you gotta appreciate the light and bright sometimes 😛
                        rv1974
                        Yeah with this white I can illuminate the room at night without turning the light on. Good for bills
                          Anton_S
                          You should tell that to Sketchup lol. They could definitely win a lot more users if they go green energy
                          • designerbursaD
                            designerbursa
                            I am using sketchup version 2021 and the error still persists...
                            an image not in the plugin folder and the user path "%appdata%"
                              maximumselfish
                              Добрый день.
                              Ожидается поддержка SU 2023?
                                joerg
                                Hi Anton,
                                thanks once again for your very helpfull extension!
                                I have a problem when the menu bar is hidden. Shortcuts are working, but one shortcut freezes the following shortcuts: Functions/Interact (I`m using your extension in presentations with dynamic components).
                                Same problem on WIN10 and WIN11 Pro with SU2021Pro.
                                Thanks for your help!
                                Joerg
                                  Apollo Tuan
                                  After I installed it, I found it was not complete and only showed some of the features
                                  • shake1S
                                    shake1
                                    Anton, please adapt for 2023. This is the head of all plugins.
                                      sarkarshomit
                                      So the plugin is still awaiting update for Sketchup 2023?
                                      I use this plugin a lot in Skup2021, but completely migrating to SU23, is not getting possible due to incompatible FS plugin
                                        Anton_S
                                        Hello everyone! This should work with SU2023. The incomplete UI is because SU2023 has undergone a major internal framework change and I no longer have the capability to manipulate some of the elements. Things like full-screen, should still work though. Let me know if otherwise.
                                        S 1 Reply Last reply
                                        • kimgaK
                                          kimga
                                          HI Anton,
                                          I just installed the plugin. I have never used it, so not sure how it meant to work. I was looking for a way to fullscreen the working window to see the V-ray safe screen, unfortunately, I didn't manage this with your extension used with SketchUp 2023 running on Windows 11.
                                          Good day!
                                            sarkarshomit @Anton_S
                                            @Anton_S No sir, its still not working with Su2023 on win10.
                                            I so wish if u could give the plugin its much required overhaul.
                                            When i press the fullscreen button check box, it does go in fullscreen, but it does not hide floating and docked toolbars, which i really use a lot for taking screenshots of my works.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 14 / 15
