    [Plugin] FullScreen v5.1.3 (25 April 2024)
    285 Posts 79 Posters 463.0k Views 80 Watching
      joerg
      Bug: If you skip to the next scene with a shortcut, than its skipping 2 scenes in one step. Same thing backwards. (SU 2021 pro)
        Anton_S
        Interesting find. Does that occur with the menu bar hidden or even with the menu bar visible?
        Edit: I can reproduce the bug with the menu bar hidden. Working on a fix.
          joerg
          Hi Anton,
          Thanks for your quick reply! As you suspected, the error only happens when the menu bar is hidden.
          A fix would be great! Thank you for the effort.
          • fredo6F
            If te menu bar is truly hidden (at Windows level), then NO custom shortcut will work.
            What I do in LOTT is to increase the size of the Sketchup window so that the menu bar is outside the screen.
              Anton_S
              In fullscreen, I read all the sketchup shortcut and have my own keyboard WM_KEY_DOWN message handler which triggers the associated commands when the menubar is hidden.
              As an alternative, with regards to moving the window above, I believe you can get the height of the menubar and then use SetWindowPos with start position to be negative menubar height and and height to be screenheight + menubar height.
              To get menubar height: https://docs.microsoft.com/en-us/windows/win32/api/winuser/nf-winuser-getmenubarinfo?redirectedfrom=MSDN
                Anton_S
                @joerg said:
                Hi Anton,
                Updated!
                • L
                  LeoHominis
                  Essa extensão é uma das melhores que eu já baixei, colocando atalhos de teclado nela fica uma delicia o ambiente. Muito obrigado e parabéns por tornar o SketchUp MELHOR. 👊 👊 😎
                  • designerbursaD
                    designerbursa
                    c:/users/user/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/ams_windowsettings/imagesui.png
                      Anton_S
                      Why am I getting this error in ruby console?
                      It's a console log. Forgot to remove. Not an error.
                        rv1974
                        Anton could your tool apply dark theme to SU's UI elements? I'm so tired of this white\light grey
                        Thank you
                          Anton_S
                          Thank you
                          Sorry. Don't want to waste my time on this. This is something SketchUp should do on their end.
                            rv1974
                            @anton_s said:
                            Thank you
                            Too bad 😞 We'll soon celebrate 25 years with this pesky white.
                            not funny
                              Anton_S
                              Well you gotta appreciate the light and bright sometimes 😛
                                rv1974
                                Yeah with this white I can illuminate the room at night without turning the light on. Good for bills
                                  Anton_S
                                  You should tell that to Sketchup lol. They could definitely win a lot more users if they go green energy
                                  • designerbursaD
                                    designerbursa
                                    I am using sketchup version 2021 and the error still persists...
                                    an image not in the plugin folder and the user path "%appdata%"
                                      maximumselfish
                                      Добрый день.
                                      Ожидается поддержка SU 2023?
                                        joerg
                                        Hi Anton,
                                        thanks once again for your very helpfull extension!
                                        I have a problem when the menu bar is hidden. Shortcuts are working, but one shortcut freezes the following shortcuts: Functions/Interact (I`m using your extension in presentations with dynamic components).
                                        Same problem on WIN10 and WIN11 Pro with SU2021Pro.
                                        Thanks for your help!
                                        Joerg
                                          Apollo Tuan
                                          After I installed it, I found it was not complete and only showed some of the features
                                          • shake1S
                                            shake1
                                            Anton, please adapt for 2023. This is the head of all plugins.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 14 / 15
