    [Plugin Library] LibFredo6 - v15.8b - 12 Jan 26
    2.2k Posts 571 Posters 4.1m Views 573 Watching
    • fredo6F Offline
      @hairman said:
      Hi Fredo6,
      I updated Libfredo6 yesterday because of your new FredoSketch extension. First tried with window-Libfredo settings-check for fredo6 plugin updates and was surprised that it said that everything was up to date. Libfredo6 version was 13.6..
      The mechanism for the CheckForUpdate is slightly different current. It relies on me setting the information on the server. So, there may a slight delay.
      • fredo6F Offline
        NEW RELEASE: LibFredo6 v13.7b - 20 Jan 23
        LibFredo6 13.7b includes:
        • Fix for FredoScale Radial Bend (wrong base direction of protractor)
        It is strongly advised to upgrade to this version
          amy5771 Newcomers
          I am not able to install the file on sketchup... Is there a problem with the file? Sketchup keeps showing the message ''load errors''... and I really need to use one of the fredo exptension today
            What load errors exactly?
              amy5771 Newcomers
              Hi. This is what I get on sketchup every time I install the new version.
              Erreur de chargement du fichier C:/Users/Amy/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/su_advancedcameratools/actloader.rbe
              Failed to read RBE/RBS file.
              Erreur de chargement du fichier C:/Users/Amy/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/su_dynamiccomponents/ruby/dcloader.rbe
              Erreur de chargement du fichier C:/Users/Amy/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/su_sandbox/sandboxmenus.rbe
              Erreur de chargement du fichier C:/Users/Amy/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/su_trimble_connect/boot.rbe
                These load errors are not directly relating to Fredo's extensions,they relate to the 'shipped' tools which come with the SketchUp installation, however, the root cause of these errors can affect many extensions to through load errors.
                It usually points to an incorrect installation of SketchUp on your Windows PC.
                It can be 'repaired' without adversely affecting your installed extensions...
                Follow these steps...
                Ensure SketchUp is closed.
                Find the SketchUp installer's exe file - usually in your Downloads folder.
                Select its icon, right-click > context-menu > "Run as administrator"
                In the dialog that opens choose 'Repair'.
                When it's completed try starting SketchUp again...
                Any better ?
                Double-clicking any installer's exe file to 'Run' it is not the same thing, even if you user-account has admin powers. Permissions can become skewed in unpredictable ways.
                It is possible that some 'temp' data files [usually Fredo's] which stored outside of the usual SketchUp paths might still be set up wrongly, and so they can throw up errors, if this occurs let us know and we can tell you which folder to delete, as it will get remade when SketchUp restarts, but this time with good permissions...
                • U Offline
                  uxcentricdarren
                  Sketchup error messageI've downloaded the 13.7b file and I think I've installed it, but the application refuses to acknowledge it and I keep getting an error. I've uninstalled the old version, installed the new version, quit SketchUp and rebooted the whole mac more than once and still the error message. Any help, please?!?!?
                    The latest version of FredoSPline, which is indicated as out of date in your case, is 2.4a. Based on the version number you mention, it sounds like you updated LibFredo6. How about updating FredoSpline to the current version and then see if the message goes away?
                    While you're updating, make sure you have the latest version of the Sketchucation tool installed, too.
                    • U Offline
                      uxcentricdarren
                      Thank you!!
                      • Y Offline
                        yles858026
                        I have installed the plug in through the extention manager, but why Id don't see any tool bar? I have only the settings under the window menu... can anyone help?
                        • fredo6F Offline
                          LibFredo6 is just a code library shared by my plugins.
                          You now need to install each plugin.
                          • E Offline
                            erwinz
                            Hi Fredo,
                            I have upgraded LibFredo6 to v13.7b and simultaneously upgraded Joint Push Pull Interactive to v4.6a. And now after re-starting the Sketchup, the Joint Push Pull toolbar appears but no response when clicking any buttons, and on the window menu > LibFreddo6 Settings...also nothing happens when clicking most of the menus - both are nothing works.
                            Thank you
                              @erwinz said:
                              Hi Fredo,
                              Your profile indicates you are using SketchUp 2015. For that version you need to be using the older legacy versions of the the extension and LibFredo6 files.
                              Edit: Thank you for updating your profile.
                              Did you also update to the latest version of the Sketchucation tool?
                              • fredo6F Offline
                                Could you open the Ruby console for possible error messages before you click on the command icon.
                                • fredo6F Offline
                                  NEW RELEASE: LibFredo6 v13.8a - 04 Feb 23
                                  LibFredo6 13.8a includes:
                                  • Bug fixing related to licensing of ThruPaint
                                  • Support for future compatibility
                                  It is strongly advised to upgrade to this version if you use ThruPaint
                                    sakepaint Newcomers
                                    Thank!
                                      mmdkabir Newcomers
                                      Dear developers or sketchUcation management,
                                      We do not have paypal access from Turkey. I would like you to inform us about how to buy fredo plugins.
                                        mmdkabir Newcomers
                                        dear developers or sketchUcation management,
                                        • fredo6F Offline
                                          NEW RELEASE: LibFredo6 v13.9a - 20 Feb 23
                                          LibFredo6 13.9a includes:
                                          • Bug fixing related to SU2023 in some circumstances
                                          • I Offline
                                            Isarescu
                                            Afterupdating to 13.9a nothing works anymore. I see the extensions in the toolbar, I can press the buttons, but nithing happens: Fredo Tools, Joint Push Pull, Fredo Scale, Curviloft, Round Corner.
                                            • 88
                                            • 89
                                            • 90
                                            • 91
                                            • 92
                                            • 108
                                            • 109
                                            • 90 / 109
