    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.2k Posts 583 Posters 9.0m Views 585 Watching
    • Y
      yles858026
      I have installed the plug in through the extention manager, but why Id don't see any tool bar? I have only the settings under the window menu... can anyone help?
      • fredo6F
        LibFredo6 is just a code library shared by my plugins.
        You now need to install each plugin.
        • E
          erwinz
          Hi Fredo,
          I have upgraded LibFredo6 to v13.7b and simultaneously upgraded Joint Push Pull Interactive to v4.6a. And now after re-starting the Sketchup, the Joint Push Pull toolbar appears but no response when clicking any buttons, and on the window menu > LibFreddo6 Settings...also nothing happens when clicking most of the menus - both are nothing works.
          Thank you
            @erwinz said:
            Hi Fredo,
            Your profile indicates you are using SketchUp 2015. For that version you need to be using the older legacy versions of the the extension and LibFredo6 files.
            Edit: Thank you for updating your profile.
            Did you also update to the latest version of the Sketchucation tool?
            • fredo6F
              Could you open the Ruby console for possible error messages before you click on the command icon.
              • fredo6F
                NEW RELEASE: LibFredo6 v13.8a - 04 Feb 23
                LibFredo6 13.8a includes:
                • Bug fixing related to licensing of ThruPaint
                • Support for future compatibility
                It is strongly advised to upgrade to this version if you use ThruPaint
                  sakepaint Newcomers
                  Thank!
                    mmdkabir Newcomers
                    Dear developers or sketchUcation management,
                    We do not have paypal access from Turkey. I would like you to inform us about how to buy fredo plugins.
                      mmdkabir Newcomers
                      dear developers or sketchUcation management,
                      • fredo6F
                        NEW RELEASE: LibFredo6 v13.9a - 20 Feb 23
                        LibFredo6 13.9a includes:
                        • Bug fixing related to SU2023 in some circumstances
                        • I
                          Isarescu
                          Afterupdating to 13.9a nothing works anymore. I see the extensions in the toolbar, I can press the buttons, but nithing happens: Fredo Tools, Joint Push Pull, Fredo Scale, Curviloft, Round Corner.
                          • fredo6F
                            @isarescu said:
                            After updating to 13.9a nothing works anymore. I see the extensions in the toolbar, I can press the buttons, but nothing happens: Fredo Tools, Joint Push Pull, Fredo Scale, Curviloft, Round Corner.
                            Later: after activating again all the licenses, Curviloft and RoudCorner works. Fredo Tools, Curvizard, JointPushPull and FredoScale still don`t work.
                            Could you open the Ruby console to see if there are errors.
                            Normally you do not need to activate again the license when you upgrade LibFredo6.
                            • zivotinjaZ
                              zivotinja
                              HI Fredo, I cannot use the sketchucation 4.3 plugin it crashes all my SK2021-23. How can I install it using the regular installation process as other plugins? I have paid for ROund Corner and your bundle ~70USD However it does not work.
                              • I
                                Isarescu
                                "Error: #<NoMethodError: undefined method wdlg_from_key' for Traductor::Wdlg:Class> c:/users/patrudoizero/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6webwdlg.rbe:37:in check_instance_displayed'
                                c:/users/patrudoizero/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6quicklauncher.rbe:42:in invoke' c:/users/patrudoizero/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_fredotools/fredotools.rbe:233:in invoke_quick_launcher'
                                c:/users/patrudoizero/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_fredotools/fredotools.rbe:268:in block in startup' c:/users/patrudoizero/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1469:in command_invoke'
                                c:/users/patrudoizero/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1449:in block (2 levels) in build_config_commands' c:/users/patrudoizero/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1385:in block in add_command'
                                c:/users/patrudoizero/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6quicklauncher.rbe:42:in invoke' c:/users/patrudoizero/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_jointpushpull/bootstrap_jointpushpull.rbe:147:in invoke_quick_launcher'
                                c:/users/patrudoizero/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_jointpushpull/bootstrap_jointpushpull.rbe:121:in block in startup' c:/users/patrudoizero/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1469:in command_invoke'
                                c:/users/patrudoizero/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6quicklauncher.rbe:42:in invoke' c:/users/patrudoizero/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_fredoscale/bootstrap_fredoscale.rbe:445:in invoke_quick_launcher'
                                c:/users/patrudoizero/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_fredoscale/bootstrap_fredoscale.rbe:291:in block in configure' c:/users/patrudoizero/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1469:in command_invoke'
                                  dllukac
                                  Hello
                                  I just migrated to SU 2023. I have a problem with LibFredo6. I downloaded and installed the latest release, but SketchUp keeps showing an error message:
                                  "You must install LibFredo6 to run ..."
                                  I tried to uninstall a reinstall LibFredo, reboot Sketchup, reboot the computer - but an error message pop`s up on SketchUp start.
                                  No one of the installed Fredo6 plugins are working.
                                  Thanks for your help.
                                  • C
                                    carpinteriaymodulosvalencia
                                    hola, gracias a todos por permitirnos con sus logros de hacer mas fácil el uso de estas herramientas para un mejor desempeño y en menor tiempo. también quisiera obtener por licencia permanente el plugins fredo scale pero no cuento con ninguna de las formas de pago que mencionan. solo hay una forma de pago con la que cuento y es por medio de la entidad o corresponsal EFECTY
                                    • P
                                      PATISTAN
                                      bastant bueno
                                      • fredo6F
                                        What is the message? Could you include a screenshot. Thanks
                                        • Y
                                          Yago Brown Newcomers
                                          Error launching Sketchup Pro 2022. Crashes.
                                          "Curviloft: This plugin requires a LibFredo6 version greater than 124. The current version is 67"
                                          How to solve it?
                                            How to solve it?
                                            Update Curviloft, LibFredo6, and the Sketchucation ExtensionStore tool to their current versions.
                                            • 94
                                            • 95
                                            • 96
                                            • 97
                                            • 98
                                            • 112
                                            • 113
                                            • 96 / 113
