    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.2m Views 28 Watching
    • medeekM
      medeek
      Version 3.0.7 - 12.30.2022
      • Added error checking code into various HTML menus to detect non-existent custom materials used within wall, door and window presets.
      • Updated the Wall Stretch tool with an improved wireframe preview.
      • Changed the default value for the header extension parameter to zero for doors, windows and garage doors.
      http://design.medeek.com/resources/wallplugin/images4/wall_su678_800.jpg
      http://design.medeek.com/resources/wallplugin/images4/wall_su677_800.jpg
      The third item in this list was per customer request.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        I've had quite a few requests for ICF walls in the past few months. Apparently this method of construction has some popularity even though it may not be as common as traditional framing. I may consider adding this as an additional option for the Wall plugin.
        From a programming standpoint it really isn't too different from the CMU option, the only real complication may arise when dealing with t-intersections with other ICF walls, but I'm sure I can program my way around that one.
        https://pbs.twimg.com/media/E6LLxSMWQAEEETC.jpg
        The corner configurations are a bit more complicated than CMU or NO FRAMING however it is essentially the same from a coding and geometric standpoint.
        Doors and windows involve cutting through three solids (insul - conc - insul) instead of one.
        My only concern is whether or not to make the concrete and insulation thickness configurable at a global level or at a wall level. I supposed there could be situations where different ICF sizes could be used on a single project? Thoughts?
        design.medeek.com
        • gullfoG
          gullfo
          make it configurable at a wall level but based off a global set as a default. some CMU also have metalized surfaces as part of insulation or protection.so might be worthwhile to consider several levels in a given unit - again wall configurable but defaults to a global setting. then if there are specific products to be applied / supplied, modeling those should/would become simpler later on.
          Glenn
          http://www.runnel.com
          • medeekM
            medeek
            I think you are right, I will set it up in the global settings so the global defaults can be set but also allow the user to change these values on a per wall basis.
            Here is a preview of the global settings (Insulation tab) with the new parameters:
            https://global.discourse-cdn.com/sketchup/optimized/3X/6/b/6b4361824447a638029bb210739ee0d90b8e772d_2_690x483.jpeg
            design.medeek.com
            • gullfoG
              gullfo
              bearing in mind that most ICF use rigid insulation ๐Ÿ˜„
              Glenn
              • medeekM
                medeek
                Version 3.0.8 - 01.03.2023
                • Added ICF options in to the Insulation tab of the Global Settings.
                • Added an ICF wall framing option for all wall types.
                • Added four additional ICF parameters into the wall Draw and Edit menus.
                • Fixed a bug with the plan view auto-dimensioning module.
                • Enabled trim, ext. wainscoting and quoins for CMU Core and ICF wall types.
                http://design.medeek.com/resources/wallplugin/images4/wall_su680_800.jpg
                http://design.medeek.com/resources/wallplugin/images4/wall_su681_800.jpg
                ALERT! - CRITICAL BUG FIX
                The bug associated with the upgrade that brought you plan view dimensions will cause the plugin to abort during regeneration when installing garage doors into a wall. It is highly recommended that you install this latest update which addresses this bug and a couple more minor bugs with the plan view dimension feature.
                design.medeek.com
                • medeekM
                  medeek
                  Version 3.0.8b - 01.03.2023
                  • Added a "Concrete" layer to the Layers tab of the Global Settings.
                  design.medeek.com
                  • medeekM
                    medeek
                    Well this is interesting:
                    https://global.discourse-cdn.com/sketchup/original/3X/7/6/76f0a4f5824b52ca231af5d30b8d137076df899c.jpeg
                    These versions they have hacked are quite old so I'm not too worried but it is interesting that my plugins are useful enough to warrant hacking by someone.
                    design.medeek.com
                    • medeekM
                      medeek
                      Version 3.0.9 - 01.05.2023
                      • Enabled beam pockets (in-wall columns) for CMU, CMU Core and ICF walls.
                      • Fixed a bug within the plan view auto-dimensioning module having to do with in-wall columns.
                      • Fixed a minor typo in the Draw menu for in-wall columns.
                      http://design.medeek.com/resources/wallplugin/images5/wall_su683_800.jpg
                      design.medeek.com
                      • gullfoG
                        gullfo
                        any thoughts on exterior parging / waterproofing like a partial thin surface (stucco, poly, etc) added on the exterior side above grade and below grade contact? fancy would be terrain following (approximated) versus a set level per wall.
                        e.g.
                        https://www.amvicsystem.com/products/icf/waterproofing-and-parging/
                        https://www.parge.ca/services/
                        https://solidacon.com/parging-over-icf/
                        Glenn
                        • medeekM
                          medeek
                          Version 3.1.0 - 01.11.2023
                          • Enabled layer control integration with the Medeek Project extension.
                          • Moved the Medeek Estimating module to the Medeek Project extension.
                          • Moved the Medeek Documents module to the Medeek Project extension.
                          design.medeek.com
                          • medeekM
                            medeek
                            Version 3.1.1 - 01.19.2023
                            • Fixed a bug with ICF Walls.
                            • Fixed a type in the HTML of the General tab of the Global Settings.
                            Tutorial 32 - Auto-Dimensioning (9:31 min.)
                            Tutorial 33 - ICF Walls (5:51 min.)
                            design.medeek.com
                            • medeekM
                              medeek
                              Tutorial 34 - Modifying Openings (7:19 min.)
                              design.medeek.com
                              • medeekM
                                medeek
                                Version 3.1.2 - 02.05.2023
                                • Fixed a bug with metric templates that propagated from Version 3.0.8.
                                • Fixed a specific bug with auto-loading wall presets.
                                ! ATTENTION !
                                Critical bug fix, especially for metric templates. I highly recommend upgrading to Version 3.1.2 if you have installed Version 3.0.8 or later.
                                The auto-load bug has to do with enabling the auto-load preset option in the Global Settings and then subsequently deleting the preset that was selected as the default auto-load preset.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Version 3.1.2b - 02.07.2023
                                  • Fixed a minor bug with the Wall Selector Matrix (Gable, Shed and Hip walls).
                                  This bug was due to some consolidation and general house cleaning I did with the code a few cycles back. Even when a gable wall was selected it would automatically revert to a rectangular wall. I just noticed this yesterday but the bug probably has been around for at least a month.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Version 3.1.3 - 02.16.2023
                                    • Fixed a bug with door presets within the Edit Door menu.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Version 3.1.4 - 03.12.2023
                                      • Added the following door types: flat one panel (single and double).
                                      http://design.medeek.com/resources/wallplugin/images5/wall_su688_800.jpg
                                      http://design.medeek.com/resources/wallplugin/images5/wall_su689_800.jpg
                                      This update per customer request.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Version 3.1.5 - 03.17.2023
                                        • Added a fluting number parameter for classical columns.
                                        http://design.medeek.com/resources/wallplugin/images5/wall_su690_800.jpg
                                        Really wasn't wanting to dig into this right now but after a quick inspection of my code I realized it would only take me a few minutes to add in this additional parameter so that one could fine tune the look of the fluting of classical columns.
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          I thought I would circle back to inclined walls since I had some questions on shed dormers over the weekend.
                                          Iโ€™ve updated the wall menus to include these new parameters now I just need to create the boolean logic to modify the wall geometry accordingly:
                                          https://global.discourse-cdn.com/sketchup/original/3X/8/b/8be454deea2b952430a9d172ee1523e55a7b0112.jpeg
                                          This feature should give the user the flexibility to modify rectangular, hip, shed or gable walls as needed when an inclined bottom plate is required.
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Version 3.1.6 - 03.26.2023
                                            • Added inclined walls for all wall types: rectangular, shed, gable and hip.
                                            http://design.medeek.com/resources/wallplugin/images5/wall_su693_800.jpg
                                            http://design.medeek.com/resources/wallplugin/images5/wall_su694_800.jpg
                                            http://design.medeek.com/resources/wallplugin/images5/wall_su695_800.jpg
                                            http://design.medeek.com/resources/wallplugin/images5/wall_su696_800.jpg
                                            This new feature can also be used on CMU, ICF and CMU CORE walls.
                                            design.medeek.com
                                            • 62
                                            • 63
                                            • 64
                                            • 65
                                            • 66
                                            • 80
                                            • 81
                                            • 64 / 81
