    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.2m Views 28 Watching
    • medeekM
      medeek
      Version 3.0.8 - 01.03.2023
      • Added ICF options in to the Insulation tab of the Global Settings.
      • Added an ICF wall framing option for all wall types.
      • Added four additional ICF parameters into the wall Draw and Edit menus.
      • Fixed a bug with the plan view auto-dimensioning module.
      • Enabled trim, ext. wainscoting and quoins for CMU Core and ICF wall types.
      http://design.medeek.com/resources/wallplugin/images4/wall_su680_800.jpg
      http://design.medeek.com/resources/wallplugin/images4/wall_su681_800.jpg
      ALERT! - CRITICAL BUG FIX
      The bug associated with the upgrade that brought you plan view dimensions will cause the plugin to abort during regeneration when installing garage doors into a wall. It is highly recommended that you install this latest update which addresses this bug and a couple more minor bugs with the plan view dimension feature.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Version 3.0.8b - 01.03.2023
        • Added a "Concrete" layer to the Layers tab of the Global Settings.
        design.medeek.com
        • medeekM
          medeek
          Well this is interesting:
          https://global.discourse-cdn.com/sketchup/original/3X/7/6/76f0a4f5824b52ca231af5d30b8d137076df899c.jpeg
          These versions they have hacked are quite old so I'm not too worried but it is interesting that my plugins are useful enough to warrant hacking by someone.
          design.medeek.com
          • medeekM
            medeek
            Version 3.0.9 - 01.05.2023
            • Enabled beam pockets (in-wall columns) for CMU, CMU Core and ICF walls.
            • Fixed a bug within the plan view auto-dimensioning module having to do with in-wall columns.
            • Fixed a minor typo in the Draw menu for in-wall columns.
            http://design.medeek.com/resources/wallplugin/images5/wall_su683_800.jpg
            design.medeek.com
            • gullfoG
              gullfo
              any thoughts on exterior parging / waterproofing like a partial thin surface (stucco, poly, etc) added on the exterior side above grade and below grade contact? fancy would be terrain following (approximated) versus a set level per wall.
              e.g.
              https://www.amvicsystem.com/products/icf/waterproofing-and-parging/
              https://www.parge.ca/services/
              https://solidacon.com/parging-over-icf/
              Glenn
              http://www.runnel.com
              • medeekM
                medeek
                Version 3.1.0 - 01.11.2023
                • Enabled layer control integration with the Medeek Project extension.
                • Moved the Medeek Estimating module to the Medeek Project extension.
                • Moved the Medeek Documents module to the Medeek Project extension.
                design.medeek.com
                • medeekM
                  medeek
                  Version 3.1.1 - 01.19.2023
                  • Fixed a bug with ICF Walls.
                  • Fixed a type in the HTML of the General tab of the Global Settings.
                  Tutorial 32 - Auto-Dimensioning (9:31 min.)
                  Tutorial 33 - ICF Walls (5:51 min.)
                  design.medeek.com
                  • medeekM
                    medeek
                    Tutorial 34 - Modifying Openings (7:19 min.)
                    design.medeek.com
                    • medeekM
                      medeek
                      Version 3.1.2 - 02.05.2023
                      • Fixed a bug with metric templates that propagated from Version 3.0.8.
                      • Fixed a specific bug with auto-loading wall presets.
                      ! ATTENTION !
                      Critical bug fix, especially for metric templates. I highly recommend upgrading to Version 3.1.2 if you have installed Version 3.0.8 or later.
                      The auto-load bug has to do with enabling the auto-load preset option in the Global Settings and then subsequently deleting the preset that was selected as the default auto-load preset.
                      design.medeek.com
                      • medeekM
                        medeek
                        Version 3.1.2b - 02.07.2023
                        • Fixed a minor bug with the Wall Selector Matrix (Gable, Shed and Hip walls).
                        This bug was due to some consolidation and general house cleaning I did with the code a few cycles back. Even when a gable wall was selected it would automatically revert to a rectangular wall. I just noticed this yesterday but the bug probably has been around for at least a month.
                        design.medeek.com
                        • medeekM
                          medeek
                          Version 3.1.3 - 02.16.2023
                          • Fixed a bug with door presets within the Edit Door menu.
                          design.medeek.com
                          • medeekM
                            medeek
                            Version 3.1.4 - 03.12.2023
                            • Added the following door types: flat one panel (single and double).
                            http://design.medeek.com/resources/wallplugin/images5/wall_su688_800.jpg
                            http://design.medeek.com/resources/wallplugin/images5/wall_su689_800.jpg
                            This update per customer request.
                            design.medeek.com
                            • medeekM
                              medeek
                              Version 3.1.5 - 03.17.2023
                              • Added a fluting number parameter for classical columns.
                              http://design.medeek.com/resources/wallplugin/images5/wall_su690_800.jpg
                              Really wasn't wanting to dig into this right now but after a quick inspection of my code I realized it would only take me a few minutes to add in this additional parameter so that one could fine tune the look of the fluting of classical columns.
                              design.medeek.com
                              • medeekM
                                medeek
                                I thought I would circle back to inclined walls since I had some questions on shed dormers over the weekend.
                                I’ve updated the wall menus to include these new parameters now I just need to create the boolean logic to modify the wall geometry accordingly:
                                https://global.discourse-cdn.com/sketchup/original/3X/8/b/8be454deea2b952430a9d172ee1523e55a7b0112.jpeg
                                This feature should give the user the flexibility to modify rectangular, hip, shed or gable walls as needed when an inclined bottom plate is required.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Version 3.1.6 - 03.26.2023
                                  • Added inclined walls for all wall types: rectangular, shed, gable and hip.
                                  http://design.medeek.com/resources/wallplugin/images5/wall_su693_800.jpg
                                  http://design.medeek.com/resources/wallplugin/images5/wall_su694_800.jpg
                                  http://design.medeek.com/resources/wallplugin/images5/wall_su695_800.jpg
                                  http://design.medeek.com/resources/wallplugin/images5/wall_su696_800.jpg
                                  This new feature can also be used on CMU, ICF and CMU CORE walls.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Version 3.1.7 - 06.12.2023
                                    • Reorganized the window draw and edit menus to include an annotations section.
                                    http://design.medeek.com/resources/wallplugin/images5/wall_su697_800.jpg
                                    This is a fairly minor update however I felt it necessary so that consistency is maintained with the Door menus.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Version 1.3.4b - 06.15.2023
                                      • Enabled all other electrical fixtures for "component" walls.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Tutorial 35 - Inclined Walls (15:10 min.)
                                        The model used in the tutorial can be found here:
                                        3D Warehouse
                                        (3dwarehouse.sketchup.com)
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Version 3.1.8 - 06.27.2023
                                          • Enabled FIS notation for framing (elevation view) dimensions for rectangular walls.
                                          • Enabled FIS notation for plan view dimensions for all walls.
                                          http://design.medeek.com/resources/wallplugin/images5/wall_su700_800.jpg
                                          http://design.medeek.com/resources/wallplugin/images5/wall_su699_800.jpg
                                          FIS stands for Feet-Inches-Sixteenths, a common notation method used in the truss industry. This update per customer request.
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Version 3.1.9 - 07.12.2023
                                            • Added an "Edit Dimension" tool to the Medeek Wall Tools toolbar (editing of plan dimension only).
                                            • Enabled editing of plan dimensions for all wall types (door, window, garage, wall length).
                                            • Fixed a bug with plan dimensions (in 2D Mode).
                                            Note that this new tool can only be used to edit "plan" dimensions. Framing dimensions are currently not editable. This update was per customer request.
                                            http://design.medeek.com/resources/wallplugin/images5/wall_su704_800.jpg
                                            http://design.medeek.com/resources/images/wall_tools_su_menu_active.jpg
                                            design.medeek.com
                                            • 62
                                            • 63
                                            • 64
                                            • 65
                                            • 66
                                            • 80
                                            • 81
                                            • 64 / 81
