    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.0m Views 28 Watching
    • gullfoG
      gullfo
      any thoughts on exterior parging / waterproofing like a partial thin surface (stucco, poly, etc) added on the exterior side above grade and below grade contact? fancy would be terrain following (approximated) versus a set level per wall.
      e.g.
      https://www.amvicsystem.com/products/icf/waterproofing-and-parging/
      https://www.parge.ca/services/
      https://solidacon.com/parging-over-icf/
      Glenn
      http://www.runnel.com
      • medeekM
        medeek
        Version 3.1.0 - 01.11.2023
        • Enabled layer control integration with the Medeek Project extension.
        • Moved the Medeek Estimating module to the Medeek Project extension.
        • Moved the Medeek Documents module to the Medeek Project extension.
        Nathaniel P. Wilkerson PE
        Medeek Engineering Inc
        design.medeek.com
        • medeekM
          medeek
          Version 3.1.1 - 01.19.2023
          • Fixed a bug with ICF Walls.
          • Fixed a type in the HTML of the General tab of the Global Settings.
          Tutorial 32 - Auto-Dimensioning (9:31 min.)
          Tutorial 33 - ICF Walls (5:51 min.)
          design.medeek.com
          • medeekM
            medeek
            Tutorial 34 - Modifying Openings (7:19 min.)
            design.medeek.com
            • medeekM
              medeek
              Version 3.1.2 - 02.05.2023
              • Fixed a bug with metric templates that propagated from Version 3.0.8.
              • Fixed a specific bug with auto-loading wall presets.
              ! ATTENTION !
              Critical bug fix, especially for metric templates. I highly recommend upgrading to Version 3.1.2 if you have installed Version 3.0.8 or later.
              The auto-load bug has to do with enabling the auto-load preset option in the Global Settings and then subsequently deleting the preset that was selected as the default auto-load preset.
              design.medeek.com
              • medeekM
                medeek
                Version 3.1.2b - 02.07.2023
                • Fixed a minor bug with the Wall Selector Matrix (Gable, Shed and Hip walls).
                This bug was due to some consolidation and general house cleaning I did with the code a few cycles back. Even when a gable wall was selected it would automatically revert to a rectangular wall. I just noticed this yesterday but the bug probably has been around for at least a month.
                design.medeek.com
                • medeekM
                  medeek
                  Version 3.1.3 - 02.16.2023
                  • Fixed a bug with door presets within the Edit Door menu.
                  design.medeek.com
                  • medeekM
                    medeek
                    Version 3.1.4 - 03.12.2023
                    • Added the following door types: flat one panel (single and double).
                    http://design.medeek.com/resources/wallplugin/images5/wall_su688_800.jpg
                    http://design.medeek.com/resources/wallplugin/images5/wall_su689_800.jpg
                    This update per customer request.
                    design.medeek.com
                    • medeekM
                      medeek
                      Version 3.1.5 - 03.17.2023
                      • Added a fluting number parameter for classical columns.
                      http://design.medeek.com/resources/wallplugin/images5/wall_su690_800.jpg
                      Really wasn't wanting to dig into this right now but after a quick inspection of my code I realized it would only take me a few minutes to add in this additional parameter so that one could fine tune the look of the fluting of classical columns.
                      design.medeek.com
                      • medeekM
                        medeek
                        I thought I would circle back to inclined walls since I had some questions on shed dormers over the weekend.
                        I’ve updated the wall menus to include these new parameters now I just need to create the boolean logic to modify the wall geometry accordingly:
                        https://global.discourse-cdn.com/sketchup/original/3X/8/b/8be454deea2b952430a9d172ee1523e55a7b0112.jpeg
                        This feature should give the user the flexibility to modify rectangular, hip, shed or gable walls as needed when an inclined bottom plate is required.
                        design.medeek.com
                        • medeekM
                          medeek
                          Version 3.1.6 - 03.26.2023
                          • Added inclined walls for all wall types: rectangular, shed, gable and hip.
                          http://design.medeek.com/resources/wallplugin/images5/wall_su693_800.jpg
                          http://design.medeek.com/resources/wallplugin/images5/wall_su694_800.jpg
                          http://design.medeek.com/resources/wallplugin/images5/wall_su695_800.jpg
                          http://design.medeek.com/resources/wallplugin/images5/wall_su696_800.jpg
                          This new feature can also be used on CMU, ICF and CMU CORE walls.
                          design.medeek.com
                          • medeekM
                            medeek
                            Version 3.1.7 - 06.12.2023
                            • Reorganized the window draw and edit menus to include an annotations section.
                            http://design.medeek.com/resources/wallplugin/images5/wall_su697_800.jpg
                            This is a fairly minor update however I felt it necessary so that consistency is maintained with the Door menus.
                            design.medeek.com
                            • medeekM
                              medeek
                              Version 1.3.4b - 06.15.2023
                              • Enabled all other electrical fixtures for "component" walls.
                              design.medeek.com
                              • medeekM
                                medeek
                                Tutorial 35 - Inclined Walls (15:10 min.)
                                The model used in the tutorial can be found here:
                                3D Warehouse
                                (3dwarehouse.sketchup.com)
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Version 3.1.8 - 06.27.2023
                                  • Enabled FIS notation for framing (elevation view) dimensions for rectangular walls.
                                  • Enabled FIS notation for plan view dimensions for all walls.
                                  http://design.medeek.com/resources/wallplugin/images5/wall_su700_800.jpg
                                  http://design.medeek.com/resources/wallplugin/images5/wall_su699_800.jpg
                                  FIS stands for Feet-Inches-Sixteenths, a common notation method used in the truss industry. This update per customer request.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Version 3.1.9 - 07.12.2023
                                    • Added an "Edit Dimension" tool to the Medeek Wall Tools toolbar (editing of plan dimension only).
                                    • Enabled editing of plan dimensions for all wall types (door, window, garage, wall length).
                                    • Fixed a bug with plan dimensions (in 2D Mode).
                                    Note that this new tool can only be used to edit "plan" dimensions. Framing dimensions are currently not editable. This update was per customer request.
                                    http://design.medeek.com/resources/wallplugin/images5/wall_su704_800.jpg
                                    http://design.medeek.com/resources/images/wall_tools_su_menu_active.jpg
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Tutorial 36 - Editing Dimensions (7:55 min.)
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Version 3.2.0 - 07.15.2023
                                        • Enabled editing of plan dimensions for tee intersections of all wall types.
                                        http://design.medeek.com/resources/wallplugin/images5/wall_su705_800.jpg
                                        When you modify the dimension of a tee intersection it actually invokes the plugin's "move wall" tool behind the scenes, which then moves the target wall as well as adjusts any connected walls and finally it regens the primary wall. A lot going on here.
                                        Larry Belk specifically requested this feature, and I was considering it once I began making the dimensions interactive for windows and doors. To be perfectly honest I knew it would make things a bit more complicated and involved with dimensions and their editing, however I'm glad I've managed to check this box and it seems to be working as it should.
                                        This is actually a fairly substantial upgrade to the plugin and a increase in functionality and efficiency, I will probably make a new tutorial video explaining the details shortly.
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Tutorial 37 - Moving Walls (16:03 min.)
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Here is a todo list for the Wall Plugin, some ideas that I am currently floating:
                                            1.) Global Settings Import/Export
                                            2.) Wall Numbering Tool
                                            3.) Wall Corner Tool
                                            4.) Adding more dimensions and additional details to the framing dimension option.
                                            5.) Max. wall panel length option
                                            This list is not in any particular order. The wall numbering tool would be quite easy to implement and quite useful in my opinion. Currently one can change the wall numbers/labels however it is a bit laborious since the edit menu must be accessed for each wall panel that needs updating.
                                            design.medeek.com
                                            • 62
                                            • 63
                                            • 64
                                            • 65
                                            • 66
                                            • 80
                                            • 81
                                            • 64 / 81
