    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.0m Views 28 Watching
    • medeekM
      medeek
      Version 3.0.5 - 12.15.2022
      • Enabled auto-dimensioning for plan views of all wall panels.
      • Added the "Dimension Offset 2" and "Plan Dimensions" parameters to the General tab of the global settings.
      • Updated the Add Material and Edit Material HTML menus so that commas cannot be used in Custom Material names.
      http://design.medeek.com/resources/wallplugin/images4/wall_su671_800.jpg
      http://design.medeek.com/resources/wallplugin/images4/wall_su672_800.jpg
      Note that framing dimensions (elevations) and plan dimensions (plan view) can be turned on and off independent of each other in the global settings. Also the additional offset parameters allows one to adjust both offsets independently as well. However both dimensions are placed on the same layer (at least for now).
      Currently the plan view dimension option will assign an overall dimension for the wall length and then separate dimensions for windows, doors and garage doors. I do not have it inserting dimensions for more custom features like Simpson Strong Walls or in-wall columns.
      This new feature is per customer request.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Version 3.0.6 - 12.28.2022
        • Added a "Jamb Interior" parameter into the Draw and Edit menus for doors.
        • Enabled this parameter for both rectangular and arched doors.
        • Added this parameter to the Doors tab of the Global Settings.
        http://design.medeek.com/resources/wallplugin/images4/wall_su675_800.jpg
        http://design.medeek.com/resources/wallplugin/images4/wall_su676_800.jpg
        This update was per my previous notes and per customer request.
        design.medeek.com
        • medeekM
          medeek
          Just cleaning up some loose ends before the start of the New Year.
          One issue that is sometimes encountered is when a custom material is defined in the Material Library and then after using it in a Wall Preset it is subsequently deleted.
          When this happens and that particular Wall Preset is loaded the plugin tries to assign that custom material in the Draw or Edit wall menu. If you try this you will quickly notice the drop down box for the material is blank and no valid material is selected. This inevitably leads to an error either being thrown within the plugin code itself or within the javascript of the HTML menu pages (not sure which at this point).
          I need to devise some error checking in the HTML/Javascript to detect this problem if it pops up and gracefully resolve it rather than locking up the plugin. If I can fix this it will not only save the end user from annoying headaches but also eliminate unnecessary support calls and emails for myself.
          design.medeek.com
          • gullfoG
            gullfo
            some thoughts -- unless the custom material is saved as an SKM, it has the potential to be purged from the memory space and thus not readily available again (unless some other means of caching it - e.g. a persisted JSON of custom materials containing the RGB values - presumably if images are involved, then saving it as an SKM would seem the better option + may be more compatible in terms of management compared to the built-in materials).
            (as a note -- i stopped using materials in my own DC because of the purging etc -- so i just got better at organizing the SKM content. some DC have basic color "materials" applied and then i replace them later, most are default material so i can paint them all quickly)
            Glenn
            http://www.runnel.com
            • medeekM
              medeek
              Version 3.0.7 - 12.30.2022
              • Added error checking code into various HTML menus to detect non-existent custom materials used within wall, door and window presets.
              • Updated the Wall Stretch tool with an improved wireframe preview.
              • Changed the default value for the header extension parameter to zero for doors, windows and garage doors.
              http://design.medeek.com/resources/wallplugin/images4/wall_su678_800.jpg
              http://design.medeek.com/resources/wallplugin/images4/wall_su677_800.jpg
              The third item in this list was per customer request.
              design.medeek.com
              • medeekM
                medeek
                I've had quite a few requests for ICF walls in the past few months. Apparently this method of construction has some popularity even though it may not be as common as traditional framing. I may consider adding this as an additional option for the Wall plugin.
                From a programming standpoint it really isn't too different from the CMU option, the only real complication may arise when dealing with t-intersections with other ICF walls, but I'm sure I can program my way around that one.
                https://pbs.twimg.com/media/E6LLxSMWQAEEETC.jpg
                The corner configurations are a bit more complicated than CMU or NO FRAMING however it is essentially the same from a coding and geometric standpoint.
                Doors and windows involve cutting through three solids (insul - conc - insul) instead of one.
                My only concern is whether or not to make the concrete and insulation thickness configurable at a global level or at a wall level. I supposed there could be situations where different ICF sizes could be used on a single project? Thoughts?
                design.medeek.com
                • gullfoG
                  gullfo
                  make it configurable at a wall level but based off a global set as a default. some CMU also have metalized surfaces as part of insulation or protection.so might be worthwhile to consider several levels in a given unit - again wall configurable but defaults to a global setting. then if there are specific products to be applied / supplied, modeling those should/would become simpler later on.
                  Glenn
                  • medeekM
                    medeek
                    I think you are right, I will set it up in the global settings so the global defaults can be set but also allow the user to change these values on a per wall basis.
                    Here is a preview of the global settings (Insulation tab) with the new parameters:
                    https://global.discourse-cdn.com/sketchup/optimized/3X/6/b/6b4361824447a638029bb210739ee0d90b8e772d_2_690x483.jpeg
                    design.medeek.com
                    • gullfoG
                      gullfo
                      bearing in mind that most ICF use rigid insulation 😄
                      Glenn
                      • medeekM
                        medeek
                        Version 3.0.8 - 01.03.2023
                        • Added ICF options in to the Insulation tab of the Global Settings.
                        • Added an ICF wall framing option for all wall types.
                        • Added four additional ICF parameters into the wall Draw and Edit menus.
                        • Fixed a bug with the plan view auto-dimensioning module.
                        • Enabled trim, ext. wainscoting and quoins for CMU Core and ICF wall types.
                        http://design.medeek.com/resources/wallplugin/images4/wall_su680_800.jpg
                        http://design.medeek.com/resources/wallplugin/images4/wall_su681_800.jpg
                        ALERT! - CRITICAL BUG FIX
                        The bug associated with the upgrade that brought you plan view dimensions will cause the plugin to abort during regeneration when installing garage doors into a wall. It is highly recommended that you install this latest update which addresses this bug and a couple more minor bugs with the plan view dimension feature.
                        design.medeek.com
                        • medeekM
                          medeek
                          Version 3.0.8b - 01.03.2023
                          • Added a "Concrete" layer to the Layers tab of the Global Settings.
                          design.medeek.com
                          • medeekM
                            medeek
                            Well this is interesting:
                            https://global.discourse-cdn.com/sketchup/original/3X/7/6/76f0a4f5824b52ca231af5d30b8d137076df899c.jpeg
                            These versions they have hacked are quite old so I'm not too worried but it is interesting that my plugins are useful enough to warrant hacking by someone.
                            design.medeek.com
                            • medeekM
                              medeek
                              Version 3.0.9 - 01.05.2023
                              • Enabled beam pockets (in-wall columns) for CMU, CMU Core and ICF walls.
                              • Fixed a bug within the plan view auto-dimensioning module having to do with in-wall columns.
                              • Fixed a minor typo in the Draw menu for in-wall columns.
                              http://design.medeek.com/resources/wallplugin/images5/wall_su683_800.jpg
                              design.medeek.com
                              • gullfoG
                                gullfo
                                any thoughts on exterior parging / waterproofing like a partial thin surface (stucco, poly, etc) added on the exterior side above grade and below grade contact? fancy would be terrain following (approximated) versus a set level per wall.
                                e.g.
                                https://www.amvicsystem.com/products/icf/waterproofing-and-parging/
                                https://www.parge.ca/services/
                                https://solidacon.com/parging-over-icf/
                                Glenn
                                • medeekM
                                  medeek
                                  Version 3.1.0 - 01.11.2023
                                  • Enabled layer control integration with the Medeek Project extension.
                                  • Moved the Medeek Estimating module to the Medeek Project extension.
                                  • Moved the Medeek Documents module to the Medeek Project extension.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Version 3.1.1 - 01.19.2023
                                    • Fixed a bug with ICF Walls.
                                    • Fixed a type in the HTML of the General tab of the Global Settings.
                                    Tutorial 32 - Auto-Dimensioning (9:31 min.)
                                    Tutorial 33 - ICF Walls (5:51 min.)
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Tutorial 34 - Modifying Openings (7:19 min.)
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Version 3.1.2 - 02.05.2023
                                        • Fixed a bug with metric templates that propagated from Version 3.0.8.
                                        • Fixed a specific bug with auto-loading wall presets.
                                        ! ATTENTION !
                                        Critical bug fix, especially for metric templates. I highly recommend upgrading to Version 3.1.2 if you have installed Version 3.0.8 or later.
                                        The auto-load bug has to do with enabling the auto-load preset option in the Global Settings and then subsequently deleting the preset that was selected as the default auto-load preset.
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Version 3.1.2b - 02.07.2023
                                          • Fixed a minor bug with the Wall Selector Matrix (Gable, Shed and Hip walls).
                                          This bug was due to some consolidation and general house cleaning I did with the code a few cycles back. Even when a gable wall was selected it would automatically revert to a rectangular wall. I just noticed this yesterday but the bug probably has been around for at least a month.
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Version 3.1.3 - 02.16.2023
                                            • Fixed a bug with door presets within the Edit Door menu.
                                            design.medeek.com
                                            • 61
                                            • 62
                                            • 63
                                            • 64
                                            • 65
                                            • 80
                                            • 81
                                            • 63 / 81
