    [Plugin][$] ThruPaint - v2.8d - 13 May 25
    187 Posts 53 Posters 26.6k Views 53 Watching
    • fredo6F Offline
      @jql said:
      When I try to paint a texture continually on surfaces I can't see the red/green axis anymore, as I used to be able with Thrupaint 1.
      With ThruPaint 2, the axes are now triggered when you are close to an edge. Otherwise, if you are in the middle of a face, the direction of axes is the one that the Paint Bucket would take.
      • JQLJ Offline
        JQL
        Even so, this is also very random. Sometimes I see it, but most of the times I don't. Do you think this might be related to dpi?
        www.casca.pt
        Visit us on facebook!
        • fredo6F Offline
          Can you keep the Ruby console opened to check for errors.
          • JQLJ Offline
            JQL
            I will.
            www.casca.pt
            • JQLJ Offline
              JQL
              I got one but things were actually working:
              Error; #<TypeError; nil can't be coerced into Integer>
              c;/users/joao/appdata/roaming/sketchup/sketchup 2023/sketchup/plugins/fredo6_thrupaint/thrupainttool.rbe;1336;in `-'
              c;/users/joao/appdata/roaming/sketchup/sketchup 2023/sketchup/plugins/fredo6_thrupaint/thrupainttool.rbe;1336;in `handle_move'
              c;/users/joao/appdata/roaming/sketchup/sketchup 2023/sketchup/plugins/fredo6_thrupaint/thrupainttool.rbe;4200;in `onMouseMove'
              www.casca.pt
              • JQLJ Offline
                JQL
                Hi Fredo, I'd like that the axis, that show up when you want to repaint a texture, would appear as they used to be in Thrupaint 1. Many times it's really difficult to paint a face by making the mouse pointer close to the correct edge. It might be hidden or in a position where it's hard to get right and Thrupaint one was perfect in this regard.
                Do you think that would be possible to revert? Maybe give us the option again?
                www.casca.pt
                • fredo6F Offline
                  The No-Axis option allows painting with UV direction taken from model axes (as the Paint Bucket tool), which is not possible with the old ThruPaint.
                  I can certainly introduce a Default Parameter setting to disable this behavior.
                  However, I don't understand why you have difficulty getting close to edges.
                  • JQLJ Offline
                    JQL
                    It requires more accuracy and some times the edge is hidden. Before I would simply point to a face and when the gizmo was closer to a corner than the others the red and green axis immediately popped up. It was much faster and predictable.
                    www.casca.pt
                      jejo303
                      @jkoll66 said:
                      I'm having an issue where the Paint Face toolbar won't load. I've attached a screenshot and the console log. Thanks in advance for any help.
                      Same problem for me. Any solution?
                      • fredo6F Offline
                        Could you check that you have installed LibFredo6 v13.6.
                          jejo303
                          After rebooting it works! Thanks.
                            rajab0v
                            How to buy this plugin as im not able to use it now and I cant find the page for buying it
                              al2430 Newcomers
                              Hello,
                              i cant Purchase License, have anybody the same issue?
                              iam using the link in Sketchup while installed Thrupaint:
                              SketchUcation | Cart
                              (sketchucation.com)
                              thanks.
                                al2430 Newcomers
                                @rajab0v said:
                                How to buy this plugin as im not able to use it now and I can't find the page for buying it, when I go to obtain license, it says on page: ERROR: Unknown plugin identifyer.
                                I have the same issue. Please Help.
                                • fredo6F Offline
                                  ThruPaint is free for the time being. NO license needed.
                                  However, make sure you upgrade to the latest version of LibFredo6.
                                    al2430 Newcomers
                                    i have upgradet LibFredo6 and Thrupaint. It seems that they changed it and now it cost money. Her a picture with the License. But however it doesnt work with Purchase License..
                                    • fredo6F Offline
                                      Could you migrate to LibFredo6 v13.8a.
                                      I normally fixed the problem.
                                      Sorry for inconvenience.
                                        km1035
                                        Hello
                                        When I press the buy button, I get this link
                                        is the link correct?
                                        https://sketchucation.com/purchase-smart.php?plugin=ThruPaint
                                        • fredo6F Offline
                                          @km1035 said:
                                          Hello
                                          Could you upgrade to LibFredo6 v13.9a. This has been fixed.
                                            djo
                                            I need help quick. I need to purchase a thrupaint 2 license but I can't find where to purchase it! Can please point me out where. Thank you.
                                            • 7 / 10
