    2.3k Posts 515 Posters 2.1m Views 520 Watching
    • N Offline
      niso
      @tig said:
      @niso
      Have you downloaded and installed the very latest versions of the following [and restarted SketchUp to sync everything] ?
      The Extension itself
      LibeFredo [for support]
      SketchUcation toolset [for licensing]
      Thanks TIG!
      OOps I should have checked my updates.
        lionking_114
        @dave r said:
        @lionking_114 said:
        how I can buy a license per 1 seat
        Install the desired extension along with LibFredo6 (assuming you want one of Fredo6's extensions) and SketchUcation toolset. Find the extension in the menu, click on License and then Obtain license.
        Which version of SketchUp are you using? There is no SketchUp 202 Free/Make as your profile indicates.
        I use version 2021
        I see button obtain license but minimum is 3 seats. not option for 1 seat, 3 seats is too much for me.
        • TIGT Online
          You are buying one license - this allows you to use the licensed extension on up to three computers.
          For example, some users have a desktop PC and a laptop...
          You are not being sold three licenses, rather it's one license with ability to use it on one, two or three computers...
            sybaricat
            I purchased a three-seat license for FredoCorner a while back, and I've migrated over a couple machines since then, from a Legion 15ARH05, to a Surface Pro 7, and now to a Surface Laptop Studio. I (re?)activated the license on my current machine because even though I could have sworn I had used it before on here, it wasn't activated and wouldn't let me do anything. (I actually thought there was something wrong and restarted a couple times because there was no indication it was a licensing issue, it just "didn't work." It could do with a "check your license or buy one" message if you try to use a tool without a license.)
            While doing this, I saw that the number of seats taken was 3, leaving 0. It was then that I remembered that I never specifically released the license on my old machines before decommissioning (including formatting the drives and reinstalling Windows) them and moving on. After having some flashbacks of the similarly dreadful iTunes seat limit DRM, I figured there's probably a way to release old machines online. I found the license management page after a lot of hunting around the site, and found the seat release menu, but ironically the only license it will let me release is the one I just activated 10 minutes ago.
            Is there some way I can get the old seats released considering those machines are not even under my ownership anymore? I would hope there was a way to release the seats, considering the DRM probably does a phone-home every time you launch it anyways. Even if it were theoretically still activated, it could just invalidate the seat when it next connected.
            Maybe it's just me, but unless there's something physical to unplug from the machine like an old-school hardware key, I absolutely never remember I have to go through some process to release the license on an outgoing machine. I just stop using it and license the new machine whenever I start needing to use it on the new machine.
            • N Offline
              NEO197545_
              Hola, compre una licencia de round corner y no puedo activarla. Necesito ayuda. Gracias.
                Update https://sketchucation.com/pluginstore?pln=LibFredo6 and https://sketchucation.com/plugin/696-sketchucationtools
                  @sybaricat said:
                  Is there some way I can get the old seats released considering those machines are not even under my ownership anymore?.............
                  Send an email to support@sketchucation.com
                  Also on your current devices make sure LibFredo and Sketchucation Tools are updated
                  • N Offline
                    NEO197545_
                    he actualizado la version de fredo6 y sigo sin poder licenciar roun corner. Ayuda!
                      Can you share more info? Your image shows that you are not up to date...
                      https://i.imgur.com/dfcSCkb.png
                      It should be 5.7
                        Sandropino
                        Hello,
                        I bought 8 licenses for Fredoscale Pluginns today, installed them via extention store.
                        Two problems have arisen in the process:
                        1. the dialog box of Global Status of Plugins under SCF License showed me only the plugin Roundcorner, all other 7 are not present, so I can not activate the license either.
                        2. when using the plugins, the tools in which you can select the parameters are completely empty, so that the plugin is unusable.
                        Attached a few screenshots with the issues raised, the Sketchup license and the plugin licenses I bought today.
                        Can they help me further, because I need these plugins urgently.
                        Thanks a lot! [/size]
                        • fredo6F Offline
                          You should first upgrade to LibFredo6 13.6a. This should solve the problem of empty palettes.
                            You need to license each extensions via IT'S license dialog.
                            For Round Corner its Tools > Fredo Collection > Round Corner > License
                            For FredoScale its Tools > Fredo Collection > FredoScale > License
                            etc...
                            Also make sure bot Sketchucation Tools and LibFredo are up to date
                            Restart SketchUp after installing extensions to be sure installation process is complete and correct.
                              Gray Gardner
                              Round corner license error.jpgMy Fredo corner license isn't validating. I get an error.
                                You don't have Fredo Corner at https://sketchucation.com/webshop/my-licences.php
                                You have Round Corner which is a different extension.
                                  @gray gardner said:
                                  [attachment=0:3pn1sddh]<!-- ia0 -->Round corner license error.jpg<!-- ia0 -->[/attachment:3pn1sddh]My Fredo corner license isn't validating. I get an error.
                                  You titled the image as "Round corner license." Which extension do you have a license for? FredoCorner or Round Corner? They are different and require different licenses. The license for Round Corner is included with Fredo6's bundle. FredoCorner is available separately.
                                    lapx
                                    Why isn't SketchUp paying you guy's to make these scripts to run their software which is virtually worthless in a business environment with out them. Buying these scripts on top of the basic program cost is starting to reach an inflection point for a lot of users of being too costly. Wow! at his rate we won't own anything. My generation was use to getting a program that it worked for years and you owned it.
                                      @lapx said:
                                      Why isn't SketchUp paying you guy's to make these scripts...
                                      You should as that question of Trimble.
                                      • F Offline
                                        Fifunio123 Newcomers
                                        Hi Fredo,
                                        I have just bought a license and the payment went through, however I sent the amount twice by accident, how can a get a refund for 1 licensce? Regards Michal
                                        • F Offline
                                          @fredo6 said:
                                          @zeichner said:
                                          how long does it take to receive the license via mail
                                          just purchased clothworks and got confirmation by paypal but no mail yet?
                                          also not in spam...
                                          thank you
                                          p
                                          It should be a few seconds after payment.
                                          Could you send a mail to Clothworks@sketcucation.com. The author (Anton S) will check the status.
                                          I Have also sent a message requesting some help. Thanks
                                            cyoung411
                                            I installed a few plugins today, our office purchased licenses last year for a handful of the Fredo6 plugins. Some of the plugins automatically prompted me to validate the license because the trial period was already expired.
                                            Some of the other plugins (toposhaper, fredoscale, curvizard) are working but I was not prompted to validate the licenses, is this because I am in the free trial period? How do I get to the pop-up window to validate the license for these plugins now without waiting for the trial period to expire?
                                            • 67
                                            • 68
                                            • 69
                                            • 70
                                            • 71
                                            • 115
                                            • 116
                                            • 69 / 116
