    2.2k Posts 487 Posters 931.6k Views 492 Watching
      Install the latest version of the desired Extension [and any related Lib - e.g. for LibFredo]
      You also need to install the newest version of the SketchUcation toolset...
      Restart SketchUp.
      With Fredo's tools you can then use the Tools > Fredo6 Collection > "ExtensionName" > License... item to check/obtain[aka 'buy']/validate the appropriate SCF-License...
      • fredo6F Offline
        @beresniak said:
        Hello,
        I made a big mess while upgrading the hardware and reconfiguring the network.
        In short: I am asking you to release seats - licenses no.: 34491, 34492, 34493, 34494, 34498 (ie 34491 - 34494 and 34498).
        Thank you in advance.
        All seats released.
        • Y Offline
          yeouldesign
          λΌμ΄μ„Όμ„œλ₯Ό κ΅¬λ§€ν–ˆμœΌλ‚˜, μ €μž₯이 λ˜μ§€ μ•–μŠ΅λ‹ˆλ‹€.
          메일을 보내도 응닡이 μ—†μŠ΅λ‹ˆλ‹€.
          I purchased a license, but it is not saved.
          Even if I send an email, there is no response.
            Who did you send mail to? support@sketchucation.com is our support address
            For license files and info visit https://sketchucation.com/webshop/my-licences.php
              cristinamaiz
              cant find where to buy the license nothing on the shop tab or on the round corner page
                SketchUcation | List of Plugin Licences
                (sketchucation.com)
                Or from the License dialog from the particular extension in SketchUp
                Extensions > Clothworks > License
                Or
                Tools > Fredo Collection > RoundCorner > License
                In the dialog click Obtain License to go straight to the license purchasing page for that Extension
                • N Offline
                  niso
                  Perpetual license issue.
                  Fredo Spline says trial expired.
                  Validate license but then it comes back with trial issue.
                  Perpetual license purchased and used.
                  Nick
                  Great plugin.
                    @niso
                    Have you downloaded and installed the very latest versions of the following [and restarted SketchUp to sync everything] ?
                    The Extension itself
                    LibeFredo [for support]
                    SketchUcation toolset [for licensing]
                      lionking_114
                      I just have one pc.
                      how I can buy a license per 1 seat
                      thanks!
                        Install the desired extension along with LibFredo6 (assuming you want one of Fredo6's extensions) and SketchUcation toolset. Find the extension in the menu, click on License and then Obtain license.
                        Which version of SketchUp are you using? There is no SketchUp 202 Free/Make as your profile indicates.
                        • N Offline
                          niso
                          @tig said:
                          @niso
                          Thanks TIG!
                          OOps I should have checked my updates.
                            lionking_114
                            I use version 2021
                            I see button obtain license but minimum is 3 seats. not option for 1 seat, 3 seats is too much for me.
                              You are buying one license - this allows you to use the licensed extension on up to three computers.
                              For example, some users have a desktop PC and a laptop...
                              You are not being sold three licenses, rather it's one license with ability to use it on one, two or three computers...
                                sybaricat
                                I purchased a three-seat license for FredoCorner a while back, and I've migrated over a couple machines since then, from a Legion 15ARH05, to a Surface Pro 7, and now to a Surface Laptop Studio. I (re?)activated the license on my current machine because even though I could have sworn I had used it before on here, it wasn't activated and wouldn't let me do anything. (I actually thought there was something wrong and restarted a couple times because there was no indication it was a licensing issue, it just "didn't work." It could do with a "check your license or buy one" message if you try to use a tool without a license.)
                                While doing this, I saw that the number of seats taken was 3, leaving 0. It was then that I remembered that I never specifically released the license on my old machines before decommissioning (including formatting the drives and reinstalling Windows) them and moving on. After having some flashbacks of the similarly dreadful iTunes seat limit DRM, I figured there's probably a way to release old machines online. I found the license management page after a lot of hunting around the site, and found the seat release menu, but ironically the only license it will let me release is the one I just activated 10 minutes ago.
                                Is there some way I can get the old seats released considering those machines are not even under my ownership anymore? I would hope there was a way to release the seats, considering the DRM probably does a phone-home every time you launch it anyways. Even if it were theoretically still activated, it could just invalidate the seat when it next connected.
                                Maybe it's just me, but unless there's something physical to unplug from the machine like an old-school hardware key, I absolutely never remember I have to go through some process to release the license on an outgoing machine. I just stop using it and license the new machine whenever I start needing to use it on the new machine.
                                • N Offline
                                  NEO197545_
                                  Hola, compre una licencia de round corner y no puedo activarla. Necesito ayuda. Gracias.
                                    Update https://sketchucation.com/pluginstore?pln=LibFredo6 and https://sketchucation.com/plugin/696-sketchucationtools
                                      @sybaricat said:
                                      Is there some way I can get the old seats released considering those machines are not even under my ownership anymore?.............
                                      Send an email to support@sketchucation.com
                                      Also on your current devices make sure LibFredo and Sketchucation Tools are updated
                                      SketchUp Plugins | PluginStore | SketchUcation
                                      SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
                                      (sketchucation.com)
                                      Sketchucation Tools | SketchUcation
                                      (sketchucation.com)
                                      • N Offline
                                        NEO197545_
                                        he actualizado la version de fredo6 y sigo sin poder licenciar roun corner. Ayuda!
                                          Can you share more info? Your image shows that you are not up to date...
                                          https://i.imgur.com/dfcSCkb.png
                                          It should be 5.7
                                            Sandropino
                                            Hello,
                                            I bought 8 licenses for Fredoscale Pluginns today, installed them via extention store.
                                            Two problems have arisen in the process:
                                            1. the dialog box of Global Status of Plugins under SCF License showed me only the plugin Roundcorner, all other 7 are not present, so I can not activate the license either.
                                            2. when using the plugins, the tools in which you can select the parameters are completely empty, so that the plugin is unusable.
                                            Attached a few screenshots with the issues raised, the Sketchup license and the plugin licenses I bought today.
                                            Can they help me further, because I need these plugins urgently.
                                            Thanks a lot! [/size]
                                            • 61
                                            • 62
                                            • 63
                                            • 64
                                            • 65
                                            • 109
                                            • 110
                                            • 63 / 110
