    [Plugin] FredoTools::ThruPaint - v1.3a - 20 Oct 16
    331 Posts 102 Posters 634.0k Views 102 Watching
      If you are experiencing Unzip Error in the ExtensionStore try clearing the Edge Cache
        mtanure1234
        What happened with the link guys? when I try to download it never open, and the older version is not working on skp 21?
          SketchUp Plugins | PluginStore | SketchUcation
          SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
          (sketchucation.com)
          Works for me, I use it daily....
          • L
            Luciano castilho gomes
            @fredo6 said:
            For French users, here is a translation of this post in French (Many thanks to Jean Franco)
            [attachment=0:11ipa77a]<!-- ia0 -->ThurPaint QuickStart - v1.2a - 08 May 12.pdf<!-- ia0 -->[/attachment:11ipa77a]
            http://forums.sketchucation.com/download/file.php?id=49290
            ThruPaint is a standalone script which extends the native SU Paint tool with several functions:
            1. Painting across the boundaries of components and groups. You don’t need to open groups and components to paint their faces or edges.
            2. Click and Drag mode to paint progressively face by face, or surface by surface and to extend a surface already painted
              [attachment=11:11ipa77a]<!-- ia11 -->ThruPaint gif 2.gif<!-- ia11 -->[/attachment:11ipa77a]
            3. Explicit selections of faces: single face, surfaces, connected faces, adjacent faces with same materials. ThruPaint also supports painting of a preselection of faces or edges.
            4. Selection of edges by properties. Edges can also be painted automatically when painting their bordering faces.
            5. Painting on front face, back face or both, with an option to automatically orientate faces all in the same direction.
            6. Painting of component, groups as well as text labels and dimensions
              [attachment=1:11ipa77a]<!-- ia1 -->ThruPaint Container mode -small.gif<!-- ia1 -->[/attachment:11ipa77a]
            7. Sampling of material from any face within the model, including if embedded in component.
            8. Several Texturing options (but this is NOT UV mapping):
            • Natural UV: Ensure texture continuity with NO distortion. UV are propagated from the initial face painted via their common edges. Adapted to quasi-planar shapes and regular surfaces
            • Projected UV with various choices of the projection plan: initial face, view camera plane, custom face, local and model axes
            • QuadMesh, which requires that the faces you paint are nicely arranged as pseudo-quads in a rather regular mesh. Useful for arch, spheres or shapes generated by TIG Extrusion, Curviloft. I use the convention for diagonals introduced by Thomthom (edge property "Cast shadow" is set to false), but the script tries to reconstruct the mesh on the fly if not guided by diagonals. ThruPaint embeds a tool to mark / unmark edges as diagonal, which may help ThruPaint to build the mesh correctly. Due to limitation of the SU, which performs texture distortion by perspective instead of bilinear mapping, you may not get the desired effect and the continuity between cells may not be perfect.
              [attachment=9:11ipa77a]<!-- ia9 -->ThruPaint gif 6.gif<!-- ia9 -->[/attachment:11ipa77a]
              [attachment=8:11ipa77a]<!-- ia8 -->ThruPaint gif 4.gif<!-- ia8 -->[/attachment:11ipa77a]
              [attachment=12:11ipa77a]<!-- ia12 -->ThruPaint gif 1.gif<!-- ia12 -->[/attachment:11ipa77a]
            • You have also a Transfer UV mode (the colored brush icon), where you just substitute a texture by another without changing the UV.
              For each texturing mode, you need to select the U axis and V direction by hovering over the edges of the first face to paint.
            1. Edition of Textured faces, with the following transformations: translation, rotation, scaling (uniform and non-uniform), mirroring, tiling and reset.
              These transformations are performed by modifying the UV map on the faces, not by modifying the material. So the same material can be used to texture faces with different transformations.
              For texture Transformation, you can use:
            • The arrows (you can keep them pressed to progressively perform the transformation)
              [attachment=7:11ipa77a]<!-- ia7 -->ThruPaint gif 3.gif<!-- ia7 -->[/attachment:11ipa77a]
            • the VCB, where you can indicate the exact values of transformations parameters
            • A Visual Editor(click when you have the Red/Green cross)
              For the shortcuts and VCB syntax, the best is to call the built-in Help by pressing F10 or via the contextual menu. And more generally, check out the tooltips and contextual menu.
              [attachment=10:11ipa77a]<!-- ia10 -->ThruPaint gif 7.gif<!-- ia10 -->[/attachment:11ipa77a]
              Texturing modes and transformations are persistent across Sketchup sessions. So you can edit textured faces at any further point in time.
              Finally, you can freely use CTRL-Z or Escape as well as Ctrl-Y to undo / redo from within the plugin.
              BIG WARNING to MAC Users
              On Windows, you can freely use the native Material Selector.
              HOWEVER, on Mac, you CANNOT, because the Ruby API does not see the current material until it is applied with the native SU Paint tool. So you need to cycle through the model materials using the small arrows in the palette or TAB / Shift TAB. You can also sample the material from the model. I may have to build a custom selector in a next version.
            http://forums.sketchucation.com/download/file.php?id=49285
            ThruPaint is installed as part of FredoTools..
            See the main post for this plugin for Installation of FredoTools
            http://forums.sketchucation.com/download/file.php?id=49286
            No user manual (see section Quick Start and Videos below)
            • SU Versions: SU6, SU7, SU8 – works better with SU8 M1 and above
            • Platforms: Windows and Mac (with limitation of Material selector)
            • Languages: English, French, Spanish Spain (by Oxer), Spanish Latin America (by Defisto), Chinese (by guanjin)
            • Menus: by default, ThruPaint is installed in Tools > FredoTools. It does NOT appear in the Contextual menu.
            • Icon toolbar: Fredo6 Tools. There is only a single icon. By default, it is not shown. You need to go to the Default Parameters… dialog of FredoTools to enable the icon.
            • The plugin is free, for private and commercial usage.
            http://forums.sketchucation.com/download/file.php?id=49284
            ThruPaint Overview
            There is a very comprehensive tutorial by TutorialsUp (Ahmed00007).
            http://forums.sketchucation.com/download/file.php?id=49288
            Selecting the Current Material
            [attachment=4:11ipa77a]<!-- ia4 -->ThruPaint - Material.png<!-- ia4 -->[/attachment:11ipa77a]
            • On Windows, you can use the Material selector, whether for materials in the Model or in libraries.
              WARNING: On Mac, the Material selector cannot be used, due to a bug in the API. When you click on a material thumbnail, the Ruby API does not see it.
            • Sampling material from the model: hover faces in the model and press Return. You have also 2 small icons in the button palette to perform this operation, either just for the material or for both the material and UV mode. When you hover on a textured face, you can also press any arrow to switch to its material and UV mode (and then start edition)
            • Cycling through the materials in the model. Use the small arrows in the palette button or the TAB / Shift-TAB keys
            • You can set the current material to Default Material for Unpainting by clicking on the small icon.
            Basic Painting of faces
            [attachment=5:11ipa77a]<!-- ia5 -->ThruPaint Faces.png<!-- ia5 -->[/attachment:11ipa77a]
            • Choose the Faces Selection in the palette: single face, surface, all connected faces, adjacent faces with same color, adjacent faces with same color and UV mode.
            • Choose the Face side. Visible face (default), Front, Back, Front+Back. By default the auto-flip mode is On.
            • For Colors, mouse over the first face to paint and Click.
              For Texturing, mouse over to choose the U axis (in Red) and V axis (in green) from an edge of the face.
            • Click & Drag painting: This is to extend the painting from a face already painted. The extended faces depends on the Face Selection parameter. Useful to paint face by face, or to fill an area after painting its contour.
            Texturing Modes
            [attachment=2:11ipa77a]<!-- ia2 -->ThruPaint UV modes.png<!-- ia2 -->[/attachment:11ipa77a]
            • Choose the UV Mode, depending on the shape you have, then pick the U and V directions by hovering on face edges, then click on a face.
            • Texturing is always generated from the first face painted.
            • In Natural mode, texture continuity is propagated from the first face
            • In Projected mode, the default plane is the plane of the initial face. So it does matter which one you choose. Try to start from a face defining an average plane.
            • In QuadMesh mode, only faces with 3 or 4 edges are painted. The first face fixes width and height references, which are then propagated to the neighbor faces. So you don’t get the same result depending on where you start from. Try also to avoid starting from a spike face. After painting, the quad mesh is shown in red and green. In this mode, you may have faces which cannot be painted (in Red if this is critical), in yellow if they can be just ignored. Usually, this is a problem with the construction of the Mesh. You can guide ThruPaint to better construct the mesh by using the diagonal tool to mark edge as diagonal, which are ignored in the mesh.
            • For the Transfer UV mode, just select a new textured material and click on a textured area (anywhere). The UV mapping and UV mode are preserved and the texture is substituted (there may be adjustments if you edit it afterward, as the new texture may have a different ratio Height / Width).
            Transforming textures
            • ThruPaint provides 3 ways to transform texturing
            • VCB: you can set the exact value of parameters (like “30d” to rotate by 30 degrees or “3x” to scale by a factor 3 uniformly).
            • Arrows: straight arrows are for Translation, Shift-Arrows for Scaling along U and along V, Ctrl-Arrows Left / Right for Rotation, Ctrl-Arrows Up / Down for Uniform scaling.
            • Visual Editor. This is a small referential allowing to interactively perform translation, scaling and rotation. The small handles works in Click & Drag mode as well as in Click – Release – Drag – Click mode. Inference for Rotation, Scaling and Translation along axes can be deactivated via the small floating palette, which also features other transformations.
              For the syntax of VCB and Arrows, use the embedded help by pressing F10 or calling the help from the contextual menu.
            • For Rotation, Scaling and Mirroring, the transformation is always performed about the cursor point or the Visual Editor origin. So check where you mouse-over the cursor. Note also that
              • Rotation is clock-wise (green toward red axis)
              • Translation is by reference to the UV axis, not the screen viewport (so check the direction of axes when using arrows).
                Transformations supported are:
            • Translation in U and V
            • Scaling, Uniform and non Uniform (except for Natural mode)
            • Rotation
            • Tiling, 1x1 by default, or choosing the factors in U and V
            • Mirroring, about the cursor point, the U axis and the V axis
            • If the Current Material in the material selector and current UV mode are the same as the textured material and UV mode on a face, then the cursor should appear as a small cross red / green / black. In this case, you can
              • use the arrows
              • use the VCB
              • Click to activate the Visual Editor
            • If the Current Material in the material selector and current UV mode are NOT the same as the textured material and UV mode on a face, then you are in Painting mode. You can however:
              • use the arrows
              • use the VCB
                This will switch the current material and UV mode to the selected face, so that you can further activate the Visual Editor
            • Most transformations functions are available from the Contextual menu
            • When the textured area has a lot of faces, only a small number of faces (1000 by default) are interactively transformed. The other faces are transformed when you finish the interactive edition. You can change this number in the Default Parameters.
            Painting Edges
            [attachment=6:11ipa77a]<!-- ia6 -->ThruPaint Edges.png<!-- ia6 -->[/attachment:11ipa77a]
            • You can Paint just edges by disabling the Paint Faces option
            • You have the choice for selection edges: edge by edge, curve, Follow, All connected
            • Hover over the edges and click to paint them
            Other Functions
            [attachment=3:11ipa77a]<!-- ia3 -->ThruPaint Others.png<!-- ia3 -->[/attachment:11ipa77a]
            • You can toggle the visibility of hidden edges
            • There is a tool to mark diagonal
            • You can call the native SU Paint tool
            • You can set the option to have ThruPaint activated whenever you call the native SU Paint tool.
            http://forums.sketchucation.com/download/file.php?id=49289
            ThruPaint 1.3a - 20 Oct 16: Introduction of Purge. See this post for details.
            ThruPaint 1.2a - 08 May 12: Painting of components, groups, text labels and dimensions. See this post for details.
            ThruPaint 1.0n - 21 Apr 12: Small functional evolutions:
            • ThruPaint keeps track of the last scaling and rotation parameters by Material. Sampling in model also copy the scaling and rotation parameters
            • Painting of a preselection of Faces or Edges
              See Release Notes for details
            ThruPaint 1.0m - 14 Apr 12: Update to fix a few problems and to integrate the Translation in Spanish and Chinese
            ThruPaint 1.0j - 11 Apr 12: initial public release
            • H
              Htrehearn Newcomers
              I love this tool, but recently when i use it within sketchup the toolbar pops up but all the buttons are blank. Only way to fix it is to uninstall and reinstall, which is a bit annoying to do every time i open sketchup- can anyone help please?
                This suggests to me that SketchUp was not installed correctly so Windows didn't grant some needed permissions. Close SketchUp, find the downloaded installer or download it again. Right click on the installer, choose Run as administrator, and then, if prompted, choose Repair. After that completes, do a cold reboot of your computer. Reinstall ThruPaint via the Sketchucation ExtensionStore tool.
                • H
                  Htrehearn Newcomers
                  I've tried reinstalling sketchup 22 and rebooting as the tool loads but the buttons are blank, previously i could install and re-install on extension manager and it would work, now I cant get it to work at all- any other suggestions?
                    @htrehearn said:
                    I've tried reinstalling sketchup 22 and rebooting as the tool loads but the buttons are blank...
                    Did you update LibFredo6? Do that as well as the Sketchucation Tool, then quit and restart SketchUp.
                    • H
                      Htrehearn Newcomers
                      Sketchucation and Fredo6 don't say they needs updating in extension manager, but I also tried the newer V2 of thru paint and having the exact same issue 😞
                      • fredo6F
                        Could you upgrade to LibFredo6 v13.6a. It will likely solve the problem.
                        Note that the Extension Manager does not show the need for upgrade because my plugins are published on Sketchucation.
                        • Sketchucation ExtensionStore will tell you accurately
                        • There is also a menu entryWindow > LibFredo6 Settings...> Check Plugins for update
                        • H
                          Htrehearn Newcomers
                          Ah amazing! that has worked, just got to get to grips with the new version of the tool now. Thanks all!
                          • B
                            Bongard
                            Bonjour, je souhaite repasser en version 1.3a de thrupaint qui me paraissait plus simple d'utilisation, mais je ne parviens pas à retrouver le lien. Auriez vous une solution à m'apporter? Merci
                            • fredo6F
                              Just uninstall ThruPaint 2.0. If you have FredoTools already installed, it will reappear. Otherwise, install FredoTools.
                              • B
                                backy7727 Newcomers
                                That’s such a useful plugin. I think I’ll be using it a lot. Amazing!
                                • 13
                                • 14
                                • 15
                                • 16
                                • 17
                                • 17 / 17
