    [Plugin] FredoTools::ThruPaint - v1.3a - 20 Oct 16
    331 Posts 102 Posters 602.7k Views 102 Watching
    • H Offline
      Htrehearn Newcomers
      I love this tool, but recently when i use it within sketchup the toolbar pops up but all the buttons are blank. Only way to fix it is to uninstall and reinstall, which is a bit annoying to do every time i open sketchup- can anyone help please?
        This suggests to me that SketchUp was not installed correctly so Windows didn't grant some needed permissions. Close SketchUp, find the downloaded installer or download it again. Right click on the installer, choose Run as administrator, and then, if prompted, choose Repair. After that completes, do a cold reboot of your computer. Reinstall ThruPaint via the Sketchucation ExtensionStore tool.
        • H Offline
          Htrehearn Newcomers
          I've tried reinstalling sketchup 22 and rebooting as the tool loads but the buttons are blank, previously i could install and re-install on extension manager and it would work, now I cant get it to work at all- any other suggestions?
            @htrehearn said:
            I've tried reinstalling sketchup 22 and rebooting as the tool loads but the buttons are blank...
            Did you update LibFredo6? Do that as well as the Sketchucation Tool, then quit and restart SketchUp.
            • H Offline
              Htrehearn Newcomers
              Sketchucation and Fredo6 don't say they needs updating in extension manager, but I also tried the newer V2 of thru paint and having the exact same issue 😞
              • fredo6F Offline
                Could you upgrade to LibFredo6 v13.6a. It will likely solve the problem.
                Note that the Extension Manager does not show the need for upgrade because my plugins are published on Sketchucation.
                • Sketchucation ExtensionStore will tell you accurately
                • There is also a menu entryWindow > LibFredo6 Settings...> Check Plugins for update
                • H Offline
                  Htrehearn Newcomers
                  Ah amazing! that has worked, just got to get to grips with the new version of the tool now. Thanks all!
                    Bongard
                    Bonjour, je souhaite repasser en version 1.3a de thrupaint qui me paraissait plus simple d'utilisation, mais je ne parviens pas à retrouver le lien. Auriez vous une solution à m'apporter? Merci
                    • fredo6F Offline
                      Just uninstall ThruPaint 2.0. If you have FredoTools already installed, it will reappear. Otherwise, install FredoTools.
                        backy7727 Newcomers
                        That’s such a useful plugin. I think I’ll be using it a lot. Amazing!
                        • 13
                        • 14
                        • 15
                        • 16
                        • 17
                        • 17 / 17
