    Catamaran
    156 Posts 12 Posters 22.3k Views 12 Watching
    • marked001M Offline
      marked001
      Nice..this is coming along!
      http://www.revision21vis.com
      instagram: revi21on
      • Bryan KB Offline
        Thanks marked001.
        I've been a little under the weather, so I've just been doing easy renders. Can't focus on the hard stuff right now.
        The weather swings in my region are making me... groggy? We are seeing 40F swings in very short periods.
        • ntxdaveN Offline
          ntxdave
          Yep, one day you need a parka and the next you need a t-shirt πŸ˜„
          Press F1...thank me later
          • tuna1957T Offline
            tuna1957
            Excellent progress πŸ‘ πŸ‘
            Side note…. I get the feel bads from the weather swings also. It’s been jumping around pretty bad lately here in north Texas
            • Bryan KB Offline
              Thanks tuna. πŸ‘
              Yeah, it's too much for me.
              Anyway, roughing in the lower central deck hull. Next step will be to rough-in the aft deck.
              • Bryan KB Offline
                Roughing in the aft deck. I will be taking some liberties with the aft deck as I do not have very good references of it.
                  Looking great Bryan, nice progress. πŸ‘
                  • Bryan KB Offline
                    Thanks Mike!
                    • Bryan KB Offline
                      I had to rebuild all of the middle cabin deck. The end points did line up with the hull contact points on the first build. Why, I have no idea. But it is all tight and correct now.
                      I also had the lower deck profile wrong. Now fixed as well.
                      I have a better handle on the aft deck as well.
                      The windows on the front were not easy, even with tools on surface. It took me several hours figuring out how to get the curve to line up with the side windows.
                      This is proving as challenging as the Nadesico. Still going faster, though. Much fiddling and cursing, but going faster. πŸ˜†
                      • Bryan KB Offline
                        Experimenting with the aft deck cover. It's close but not right.
                        • Bryan KB Offline
                          Close enough. Lots of Curviloft and Tools On Surface and Joint Push Pull. ...and fiddling and cursing
                          JPP mangled some of the inside geometry, but I'm going with it as you can't really see it on the underside of the roof except as slightly thick lines and not at all if I turns lines off. I'll do better on the next one.
                            I was watching a travel documentry the other day and I saw a craft that looked very familiar to me. It was the craft you are building. A beutifull craft indeed πŸ‘
                            • Bryan KB Offline
                              Thanks L I am.
                              I'm still not quite satisfied with with the aft deck cover and thinking about the geometry tells me it really is not right yet.
                              • Bryan KB Offline
                                Here we go. Far better and the geometry agrees as well.
                                • Bryan KB Offline
                                  Checking the form with lines temporarily off and shadows on and background set to context.
                                  • ntxdaveN Offline
                                    ntxdave
                                    Coming along….looking forward to where you take it. πŸ‘
                                      Agreed. Do you still have the face for the profiles in the hulls? I found deleting them can clean up the hull forms considerably. I like, a lot. πŸ‘ πŸ‘
                                      • Bryan KB Offline
                                        Thanks ntxdave!
                                        Thanks Mike!
                                        Yes, the profiles of still there. I have not committed to exploding the Curviloft objects yet. The last post was to confirm to me that the shape was good before I commit. Because once exploded, there is no going back.
                                        It will most likely be the very last thing I do. I still need to add add many other parts.
                                        • Bryan KB Offline
                                          Roughing in the aft deck. Push/Pull and line Move. Joint Push/Pull on sides sweeps.
                                          • Bryan KB Offline
                                            Roughing in mast and boom and captain's chair. Simple captains' chair from the warehouse, slightly modified.
                                            I had to explode and merge the upper deck Curviloft sections. So that part is committed at this point. Still kept as half-side component.
                                            • 3 / 8
