    2.2k Posts 487 Posters 931.4k Views 492 Watching
      paddyclown
      Hi, I'm not sure if this is the correct place for this post, so apologies in advance if this needs moving.
      Despite having been able to use various of Fredo6's superb tools in the past, including after having bought a licence on both SU2021 & 22, I am currently experiencing problems...
      I check my licence status, let's say for Joint push pull, & it says i'm ok, but wen I try to use the tool, nothing works.
      & Yes, I've updated to the latest versions of both plugin & LibFredo, plus my SketchUcation plugin is also the latest version. I've tried on both 21 & 22, to no avail.
      This is also true for Curviloft and Tools on surface etc...
      Anyone have any ideas (BTW, the old free version of Joint PP works for some reason)
      Thanks in advance.
      PT
        Open the ruby console and see if there's any messages when you try JPP.
        If JPP, LibFredo and Sketchucation Tools are all up to date you should have no issues.
          paddyclown
          Hi, thanks for the tip:
          here is what appears in the Ruby Console:
          "LAUNCHER TEM 9198259913.961182
          Error: #<NameError: undefined method notify_by_otpicker' for class Traductor::FaceSelector'>
          c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6faceselector.rbe:66:in method' c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6faceselector.rbe:66:in initialize__'
          c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6faceselector.rbe:35:in initialize' c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe:409:in new'
          c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe:409:in init_face_selector' c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe:151:in initialize'
          c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe:85:in new' c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe:85:in action__mapping'
          c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:143:in call' c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:143:in launch_action'
          c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:240:in launch_action' c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/bootstrap_jointpushpull.rbe:87:in launch_action'
          c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/bootstrap_jointpushpull.rbe:135:in block in declare_command' c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1464:in command_invoke'
          c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1444:in block (2 levels) in build_config_commands' c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1385:in block in add_command'
          c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/!!fredo6_lordofthetoolbars/controller_lordofthetoolbars.rbe:133:in `block in new'
          I hope somebody understands what that error #<NameError: ... is all about
            paddyclown
            ...and when I try one of the curviloft tools, I get this error:
            "Error: #<NameError: undefined local variable or method accept_current_selection' for #<Traductor::EdgePicker:0x00000234dc314418> Did you mean? validate_current_selection> c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe:397:in analyze_initial_selection'
            c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe:388:in check_initial_selection' c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:332:in activate'
            c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:67:in select_tool' c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:67:in launch_loft'
            c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:59:in action__mapping' c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:143:in call'
            c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:143:in launch_action' c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:240:in launch_action'
            c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/bootstrap_curviloft.rbe:76:in launch_action' c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/bootstrap_curviloft.rbe:93:in block in startup'
            c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1464:in command_invoke' c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1444:in block (2 levels) in build_config_commands'
            c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1385:in block in add_command' c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/!!fredo6_lordofthetoolbars/controller_lordofthetoolbars.rbe:133:in block in new'
            It's a bit frustrating as these tools have worked well in the past and are such help, hence I had no issues about buying a licence when that became necessary...
              paddyclown
              oh, & just now on launch of SU 2021 I got this bizarre message popped up in a window:
              "Incorrect installation of LibFredo6 - Remove rb files" with an "ok" button that i did not press !
              This is bizarre as I had correctly installed the rbz...
              Luckily on the SU2022 launch I have not had this window
              curiouser und curiouser
                Please ensure that you have installed the newest versions of these extensions, LibFredo [helper] and the SketchUcation toolset [for licensing set up] - v4.2.9
                After the installation restart SketchUp to sync everything...
                Retry the tools...
                If this fails to improve things...
                Note that if SketchUp is not installed by using 'Run as administrator' from the right-click context-menu on the installer's exe file [in Downloads] you can get unpredictable and often weird permission issues - running the installer properly usually fixes these issue with a 'Repair' - there is no need to uninstall and any already installed extensions etc are left unaffected...
                Some of Fredo's support files stored away from the main Plugins folder can become inaccessible with very messed up permissions... these can be deleted and when SketchUp restarts they get remade - this time properly... We have already posted details of this previously...
                  paddyclown
                  TIG thank you for your reply.
                  I did all of that on my SU2022 install and now have the same awful popup window as I mentioned before.
                  I again tried to reinstall the LibFredo package using both approved methods, and, in desperation, by copying the files from the .rbz to the plugin folder, but on all three attempts, on restarting SU, this damn window pops up saying that "LibFredo is incorrectly installed, remove, <OK>"
                  I can't think what has recently changed in order for the whole thing to act this way...
                  Maybe it's the version of windows ? it's Win11 Pro 22H2, build 22621.819
                    paddyclown
                    Oh, & for good mesure, I tried what you suggested on another thread...
                    "If the error persists, then try [re]deleting the C:/Users/YOUR_USER_NAME/AppData/Local/LIBFREDO6_DATA_Dir directory - because it might have incorrect permissions from any earlier incorrect installation of SketchUp..."
                    & sadly that did not fix the issue.
                      I'm on the same Windows build as you and no issues.
                      You're renaming the pluginName.rbz to pluginName.zip and unzipping it and placing the contents into the plugins folder at C:\Users\SomeName\AppData\Roaming\SketchUp\SketchUp 2022\SketchUp\Plugins ???
                      Something is not right with install structure for LibFredo to spit out its dummy.
                      As a last resort you could rename your Plugins folder to #plugins to prevent it loading. Then fresh install Sketchucation Tools. Use that to install LibFredo and JPP and validate your license.
                      Then see if it works. If it does then you know there's something else at play...
                        paddyclown
                        OK, good news folks I fixed the problem:
                        I got radical and deleted ALL Fredo6 related folders and files from everywhere, then reinstalled all, starting by LibFredo via the SketchUcation toolbar... despite verious error messages, once I restarted SU22 they reworked.
                        Fingers crossed that it holds.
                        Anyway, thanks all & hope this helps someone sometime.
                          Astrid Findreng
                          Hi How do I Purchase License for Curviloft
                          astrid_findreng@yahoo.no
                            Install the trial using SketchUcation Tools 4.2.9
                            Sketchucation Tools | SketchUcation
                            (sketchucation.com)
                            Then under the Tools > Fredo Collection > Curivloft > License you can buy a license.
                            Or visit https://sketchucation.com/plugin-list.php and purchase it there.
                            You will still need to install Sketchucation Tools 4.2.9 and LibFredo though.
                            SketchUp Plugins | PluginStore | SketchUcation
                            SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
                            (sketchucation.com)
                              Digdaman
                              license seats exceeded.I bought Fredo6Bundle2022 - A bundle of 8 plugin , and validated RoundCorner license.
                              It worked right after I validate it.
                              But,next time I launch SketchUp, The message"Trial Period Expired: RoundCorner" was displayde and it didn't work.
                              Iใ€€Re-validated Same license.ใ€€but, it never worked again.
                              I tried various ideas. uninstall, rebooted system and so on.
                              Theใ€€problem was not resolved. and all license sheats exceeded,
                              thoughใ€€I try at same computer.
                              Please tell me what to do.
                                Visit https://sketchucation.com/webshop/my-licences.php and release seats
                                • Z Offline
                                  Zuman Newcomers
                                  I am trying to purchase Round Corner Plugin, while paying by PayPal after giving necessary info it doesn't proceed.
                                    mahsa1995
                                    I need Help please. im getting ERROR_09
                                    I purchased my license a while ago but suddenly it said that its ran out but I have purchased the unlimited one.
                                    I downloaded the file to validate it again but it keeps opening with wordpad and sketchup wont read it
                                    how can i fix this
                                      Update Sketchucation Tools
                                      (sketchucation.com)
                                      Update LibFredo
                                      (sketchucation.com)
                                      • E Offline
                                        emsargeant
                                        I'm getting a validation error on my RoundCorner License. Message: 'request to sketchucation = Error_F09'.
                                        When I check my license page on SketchUcation it says 0/3 seats...does that mean 0 available? Doesn't seem to allow 'releasing' seats. How can I resolve? Thx.
                                          It looks like you're trying to validate FredoCorner and not RoundCorner from that screenshot.
                                            mahsa1995
                                            can i upgrade from Perpetual license to bundle ( its only been a few days since i got the license)
                                            • 54
                                            • 55
                                            • 56
                                            • 57
                                            • 58
                                            • 109
                                            • 110
                                            • 56 / 110
