    2.3k Posts 515 Posters 2.1m Views 520 Watching
      sincop
      Hello there, this is George from Beirut-Lebanon. I am trying to purchase the Fredo tools bundle (40usd) using my debit card, but the problem is that paypal doesn't exist in my country unfortunately so even the debit/credit card option (operated by paypal) won't work....is there a western union wire transfer option...because i really need the extensions for my workflow
      • Y Offline
        yoannaa
        Hi! I bought a Fredo RoundCorner perpetual plugin, but I have a message saying my trial is expired...can you help me with this please?
        Thank you 😄
          Have you received the license file ?
          Have you validated it in the extension's menu ?
          Do you have the latest versions of the extension, LibFredo and the SketchUcation toolset installed ?
          Restart SketchUp after installing all of them to ensure everything syncs...
          If you look in MyLicenses on this site what does it say ?
            Big_Boss
            @fredo6 said:
            This post explains how to license some extensions published on Sketchucation.
            Hello, Fredo6
            As you can understand from the posts under the topic; PAYPAL is not available in some countries. In this case, we cannot benefit from many plugins even though we are willing to pay for them.
            I request you to find a permanent solution to this situation. We request you and sketchucation.com admins and moderators to use another payment tool to help us reach and use Fredo6Bundle2022 - A bundle of 8 plugins.
            We have been waiting for four or five months with the hope of a solution. Except for PAYPAL, if necessary, give me an IBAN number and we can transfer the plugins to it. See; We can easily get SUbD and Vertex Tools from https://evilsoftwareempire.com/. I'm looking forward to a solution similar to this and at least a promising response to this post. We hope to get back to these plugins that we have been using for years. Take care of yourselves.
              paddyclown
              Hi, I'm not sure if this is the correct place for this post, so apologies in advance if this needs moving.
              Despite having been able to use various of Fredo6's superb tools in the past, including after having bought a licence on both SU2021 & 22, I am currently experiencing problems...
              I check my licence status, let's say for Joint push pull, & it says i'm ok, but wen I try to use the tool, nothing works.
              & Yes, I've updated to the latest versions of both plugin & LibFredo, plus my SketchUcation plugin is also the latest version. I've tried on both 21 & 22, to no avail.
              This is also true for Curviloft and Tools on surface etc...
              Anyone have any ideas (BTW, the old free version of Joint PP works for some reason)
              Thanks in advance.
              PT
              • Rich O BrienR Online
                Open the ruby console and see if there's any messages when you try JPP.
                If JPP, LibFredo and Sketchucation Tools are all up to date you should have no issues.
                  paddyclown
                  Hi, thanks for the tip:
                  here is what appears in the Ruby Console:
                  "LAUNCHER TEM 9198259913.961182
                  Error: #<NameError: undefined method notify_by_otpicker' for class Traductor::FaceSelector'>
                  c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6faceselector.rbe:66:in method' c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6faceselector.rbe:66:in initialize__'
                  c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6faceselector.rbe:35:in initialize' c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe:409:in new'
                  c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe:409:in init_face_selector' c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe:151:in initialize'
                  c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe:85:in new' c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe:85:in action__mapping'
                  c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:143:in call' c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:143:in launch_action'
                  c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:240:in launch_action' c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/bootstrap_jointpushpull.rbe:87:in launch_action'
                  c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/bootstrap_jointpushpull.rbe:135:in block in declare_command' c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1464:in command_invoke'
                  c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1444:in block (2 levels) in build_config_commands' c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1385:in block in add_command'
                  c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/!!fredo6_lordofthetoolbars/controller_lordofthetoolbars.rbe:133:in `block in new'
                  I hope somebody understands what that error #<NameError: ... is all about
                    paddyclown
                    ...and when I try one of the curviloft tools, I get this error:
                    "Error: #<NameError: undefined local variable or method accept_current_selection' for #<Traductor::EdgePicker:0x00000234dc314418> Did you mean? validate_current_selection> c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe:397:in analyze_initial_selection'
                    c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe:388:in check_initial_selection' c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:332:in activate'
                    c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:67:in select_tool' c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:67:in launch_loft'
                    c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:59:in action__mapping' c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:143:in call'
                    c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:143:in launch_action' c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:240:in launch_action'
                    c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/bootstrap_curviloft.rbe:76:in launch_action' c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/bootstrap_curviloft.rbe:93:in block in startup'
                    c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1464:in command_invoke' c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1444:in block (2 levels) in build_config_commands'
                    c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1385:in block in add_command' c:/users/vivarchi 2/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/!!fredo6_lordofthetoolbars/controller_lordofthetoolbars.rbe:133:in block in new'
                    It's a bit frustrating as these tools have worked well in the past and are such help, hence I had no issues about buying a licence when that became necessary...
                      paddyclown
                      oh, & just now on launch of SU 2021 I got this bizarre message popped up in a window:
                      "Incorrect installation of LibFredo6 - Remove rb files" with an "ok" button that i did not press !
                      This is bizarre as I had correctly installed the rbz...
                      Luckily on the SU2022 launch I have not had this window
                      curiouser und curiouser
                        Please ensure that you have installed the newest versions of these extensions, LibFredo [helper] and the SketchUcation toolset [for licensing set up] - v4.2.9
                        After the installation restart SketchUp to sync everything...
                        Retry the tools...
                        If this fails to improve things...
                        Note that if SketchUp is not installed by using 'Run as administrator' from the right-click context-menu on the installer's exe file [in Downloads] you can get unpredictable and often weird permission issues - running the installer properly usually fixes these issue with a 'Repair' - there is no need to uninstall and any already installed extensions etc are left unaffected...
                        Some of Fredo's support files stored away from the main Plugins folder can become inaccessible with very messed up permissions... these can be deleted and when SketchUp restarts they get remade - this time properly... We have already posted details of this previously...
                          paddyclown
                          TIG thank you for your reply.
                          I did all of that on my SU2022 install and now have the same awful popup window as I mentioned before.
                          I again tried to reinstall the LibFredo package using both approved methods, and, in desperation, by copying the files from the .rbz to the plugin folder, but on all three attempts, on restarting SU, this damn window pops up saying that "LibFredo is incorrectly installed, remove, <OK>"
                          I can't think what has recently changed in order for the whole thing to act this way...
                          Maybe it's the version of windows ? it's Win11 Pro 22H2, build 22621.819
                            paddyclown
                            Oh, & for good mesure, I tried what you suggested on another thread...
                            "If the error persists, then try [re]deleting the C:/Users/YOUR_USER_NAME/AppData/Local/LIBFREDO6_DATA_Dir directory - because it might have incorrect permissions from any earlier incorrect installation of SketchUp..."
                            & sadly that did not fix the issue.
                              I'm on the same Windows build as you and no issues.
                              You're renaming the pluginName.rbz to pluginName.zip and unzipping it and placing the contents into the plugins folder at C:\Users\SomeName\AppData\Roaming\SketchUp\SketchUp 2022\SketchUp\Plugins ???
                              Something is not right with install structure for LibFredo to spit out its dummy.
                              As a last resort you could rename your Plugins folder to #plugins to prevent it loading. Then fresh install Sketchucation Tools. Use that to install LibFredo and JPP and validate your license.
                              Then see if it works. If it does then you know there's something else at play...
                                paddyclown
                                OK, good news folks I fixed the problem:
                                I got radical and deleted ALL Fredo6 related folders and files from everywhere, then reinstalled all, starting by LibFredo via the SketchUcation toolbar... despite verious error messages, once I restarted SU22 they reworked.
                                Fingers crossed that it holds.
                                Anyway, thanks all & hope this helps someone sometime.
                                  Astrid Findreng
                                  Hi How do I Purchase License for Curviloft
                                  astrid_findreng@yahoo.no
                                    Install the trial using SketchUcation Tools 4.2.9
                                    https://sketchucation.com/plugin/696-sketchucationtools
                                    Then under the Tools > Fredo Collection > Curivloft > License you can buy a license.
                                    Or visit https://sketchucation.com/plugin-list.php and purchase it there.
                                    You will still need to install Sketchucation Tools 4.2.9 and LibFredo though.
                                    https://sketchucation.com/pluginstore?pln=LibFredo6
                                      Digdaman
                                      license seats exceeded.I bought Fredo6Bundle2022 - A bundle of 8 plugin , and validated RoundCorner license.
                                      It worked right after I validate it.
                                      But,next time I launch SketchUp, The message"Trial Period Expired: RoundCorner" was displayde and it didn't work.
                                      I Re-validated Same license. but, it never worked again.
                                      I tried various ideas. uninstall, rebooted system and so on.
                                      The problem was not resolved. and all license sheats exceeded,
                                      though I try at same computer.
                                      Please tell me what to do.
                                        Visit https://sketchucation.com/webshop/my-licences.php and release seats
                                        • Z Offline
                                          Zuman Newcomers
                                          I am trying to purchase Round Corner Plugin, while paying by PayPal after giving necessary info it doesn't proceed.
                                            mahsa1995
                                            I need Help please. im getting ERROR_09
                                            I purchased my license a while ago but suddenly it said that its ran out but I have purchased the unlimited one.
                                            I downloaded the file to validate it again but it keeps opening with wordpad and sketchup wont read it
                                            how can i fix this
                                            • 62
                                            • 63
                                            • 64
                                            • 65
                                            • 66
                                            • 115
                                            • 116
                                            • 64 / 116
