    2.2k Posts 482 Posters 857.6k Views 487 Watching
      Anne O Grady @cjfdyd727
      @cjfdyd727
      I have replied to your email from our support inbox. I can continue to help you from there. Regards Anne
        Rémi Gaming Newcomers
        Hello, error codes B03 and A04 keep appearing. I'll also send you the plugin version logs. Thank you for your help.
        Fredo6 Plugins Information on 2025-05-14 20:13:47 +0200
        • Platform: x64-mswin64_140 - Ruby: 2.7.7
        • Sketchup: 23.1.340
        • LibFredo6: v15.4a
        • LibFredo6 Binary loaded
        • Sketchucation ExtensionStore: 4.4.1
        • SCFLicense: v6.4a - 74
        • Fredo6 Plugins
          JointPushPull v4.9a
          Signature File: 2025-05-14 20:12:47 +0200
        • Rich O BrienR Online
          Rich O Brien Moderator @Rémi Gaming
          @Rémi-Gaming said in SCFLicense: Extension Licensing on Sketchucation:
          Are you using the license for JPP at https://sketchucation.com/webshop/my-licences.php to activate?
          If your device name uses special characters please change it to use alphanumeric characters only.
            Yes, I bought the license on the site https://sketchucation.com. I also tried to change the name of my computer to Rémi8Gaming, but it didn't work.
              Rémi8Gaming
              Ă© is a special character
                Great, thank you very much, it works.
                Best regards
                  mlt27 Newcomers
                  hola, me acabo de descargar el plugin curviloft como activo la licencia gratuita de 30 dias?
                  Hi, I just downloaded the curviloft plugin. How do I activate the free 30-day license?
                    It is active from installation. You need to buy a license after the trial expires.
                      kimbh527
                      After switching to a new PC, I'm unable to activate my license. Could you please advise me on how to resolve this issue?
                      • fredo6F Offline
                        This is normal since licenses are attached to computers. Did you follow the instructions?
                          laiswehner
                          Hello,
                          I’ve been a customer of yours for years and already own several plugin licenses. Recently, however, I’ve been experiencing an issue with the JointPushPull extension. My license seems to have a problem—whenever I try to use or manage it, I receive the following error message:
                          ERROR_A04
                          Wrong Signature File – You may have changed the computer name
                          It is advised to erase the Signature file and revalidate.
                          I’m not sure how to fix this. Could you please help me resolve it?
                            @laiswehner
                            Click OK in the popup alert. This will open the location of the signature file.
                            Delete the file named SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt
                            Restart SketchUp
                            Activate license
                              cheolpal
                              Recipient: Dear Manager
                              1. I purchased a license for Round Corner Ruby on 23/04/2024...
                                I forgot about the purchase and purchased another license. Please confirm if I can cancel the payment I made today.
                                Rich O Brien Moderator @cheolpal
                                @cheolpal please email support@sketchucation.com with details
                                  rodrigo18ba Newcomers @fredo6
                                  @fredo6 said in SCFLicense: Extension Licensing on Sketchucation:
                                  plica como licenciar algumas extensões publicadas no Sketc
                                  QUERO TER ACESSO
                                  COMO TENHO ACESSO
                                  I WANT TO HAVE ACCESS
                                  HOW DO I GET ACCESS
                                    LEADERFIT3D Newcomers
                                    Bonjour, j'ai changé d'ordinateur et ceci semble poser probleme. que dois faire ?
                                    Hello, I changed my computer and this seems to be causing problems. What should I do?
                                      Rich O Brien Moderator @LEADERFIT3D
                                      @LEADERFIT3D
                                      Share the problem message.
                                      Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                                        chirusa
                                        Hello,
                                        I have a FredoScale license with 3 activations. Currently, only 2 are in use, but I need to release one activation or reset my license. Can you please help me reset or release a license slot? My SketchUcation username is: Igor , and my license code is: [REDACTED].
                                        Thank you!
                                          chirusa
                                          Hello,
                                          I have purchased a Perpetual License for FredoScale, but I am now receiving a message that I have reached the activation limit (“number of created reached” or similar) and I can no longer activate the plugin on my computer.
                                          I have used the license on several devices and/or reinstalled my system a few times, which may have caused this issue.
                                          Could you please help me reset or extend the activations for my license?
                                            chirusa
                                            • 101
                                            • 102
                                            • 103
                                            • 104
                                            • 105
                                            • 109
                                            • 110
                                            • 103 / 110
