    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 916.9k Views 155 Watching
      dacsol
      Borders' option in the Joint Push Pull plugin missing please fix it by tomorrow. il be checking out. I have a customer who waits and now I'm stuck with that error
        It exists in the current version of Joint Push/Pull.
        You can fix it yourself.
        Click on the More options button second from the left.
        Do you have the current version of both Joint Push/Pull and LibFredo6 installed?
        Please fix your profile. It says you are using SketchUp 2018 Free/Make but there has never been such a version.
          @andrew01 said:
          ...downloaded this extension but it says that license is over...
          Did you also install the required Sketchucation Extension Store and did you use it to install Joint Push/Pull?
          BTW, please correct your profile. There is no Free/Make version of SketchUp 2022. It would be Pro.
          • fredo6F Offline
            NEW RELEASE: JointPushPull Interactive v4.6a - 12 Sep 22
            JointPushPull 4.6a requires LibFredo6 13.1a or above
            JointPushPull Interactive 4.6a is a major release including 3 main features (see videos):
            • Fix for texture orientation
            • Incremental PushPull
            • PushPull to Target Plane
            Texture continuity
            There is also a summary video by TutorialsUp
            See plugin home page of JointPushPull for Download of JointPushPull.
            Main Post of the JointPushPull thread on this forum
              samfisher11111
              Please Help! I am using SU2021 Pro. I just brought Fredo6 Bundle. And installed latest version of Fredo6 (v13.1a) & related plugins with license. But no response when I click on joint push pull icon (v4.6a) and Curvizard icon (v2.4b) (see attaced).
              Thank you!
                @samfisher11111 said:
                But no response when I click on joint push pull icon (v4.6a) and Curvizard icon (v2.4b).
                Quit and restart SketchUp. Then try again.
                Did you install SketchUp 2021 correctly? That requires right clicking on the downloaded installer and choosing Run as administrator.
                BTW your profile says you are still using a pre-2013 version. Please update that information as it helps us help you.
                  samfisher11111
                  Thank you for fast response Dave!!! It works now, thank you again πŸ˜„
                  FYI, my profile updated~
                    JohnGilles
                    Can't get incremental push pull to work on my Mac...
                    No alt key, and neither option noe control; seem to allow the incremental function to show up on the VCB
                      No alt key
                      What about trying Command?
                      What version of SketchUp are you using? Which Mac OS version? Please complete your profile.
                        JohnGilles
                        @dave r said:
                        No alt key
                        I did update my profile, thanks for reminding me
                        I am working on a 15" 2016 MacBook Pro
                        SketchUp Pro 2020
                        And. no. the Command key doesn't toggle the Increment function either.
                        • fredo6F Offline
                          This is normal that it does not work, because I had to rollback to the old version, pending the resolution of a problem with Mac M1 platforms.
                          It is now solved, so I will soon republish JPP v4.6a, with Incremental PushPull.
                          • fredo6F Offline
                            JointPushPull v4.6a just republished on the ExtensionStore, with
                            • Texture contnuity
                            It requires LibFredo6 v13.2a.
                            TutorialsUp has published a nice video summarizing the new features.
                              tonytony321
                              Hi Fredo, thank you for the contribution to the community.
                              My JPP doesn't start properly. It has no response when I click all of the icon from the toolbar.
                              • I am using SKP 2022 on window 10. All fredo plugins are up to date.
                              • I have already purchased the plugin bundle and activated the license for those plugins that I am using.
                              • Fredo scale/ tools on surface/ round corner are all working properly.
                              • Lib Fredo settings in tab - Window also not working except for set peferred languages.
                              Hope you can solve my problem, thank you.
                              Any chance I can use a previous version for now?
                              • fredo6F Offline
                                When you upgrade to LibFredo6 v13.2a, it is important you restart all instances of Sketchup.
                                In the worse case, could you you restart your computer and it should make it.
                                • I Offline
                                  igorassis
                                  im having the same problem, i tried restarting, reinstalling and this is still happening,
                                  Error; #<NameError; undefined method `notify_by_otpicker' for class `Traductor;;FaceSelector'>
                                  c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6faceselector.rbe;66;in `method'
                                  c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6faceselector.rbe;66;in `initialize__'
                                  c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6faceselector.rbe;35;in `initialize'
                                  c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe;409;in `new'
                                  c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe;409;in `init_face_selector'
                                  c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe;151;in `initialize'
                                  c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe;85;in `new'
                                  c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe;85;in `action__mapping'
                                  c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;143;in `call'
                                  c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;143;in `launch_action'
                                  c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;240;in `launch_action'
                                  c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/bootstrap_jointpushpull.rbe;87;in `launch_action'
                                  c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/bootstrap_jointpushpull.rbe;135;in `block in declare_command'
                                  c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;1464;in `command_invoke'
                                  c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;1444;in `block (2 levels) in build_config_commands'
                                  c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe;1385;in `block in add_command'
                                    antonblam
                                    Hey Fredo, I've ran into a problem.
                                    I duplicated a group a several times and tried to PudhPull them from the outside, as the extension allows. The problem is that the extension sees them as components and treats them accordingly.
                                    Do you have the solution for that?
                                      @igorassis
                                      Do you have the latest version of LibFredo installed ?
                                      Do you have the latest version of the SketchUcation toolset installed [v4.2.9] which has the up to date SCF licensing system ?
                                      Both are available from the PluginStore - restart SketchUp after installation to sync everything
                                      • fredo6F Offline
                                        That's a known issue: Freshly copied groups behave like components. I may fix it for JPP.
                                        In the meantime, just enter (double-click) each group to make them unique.
                                          rv1974
                                          I wish Follow Push Pull will be able to remove geometry nicely a-la 3ds max (like shown on attached picture)
                                          • fredo6F Offline
                                            JPP currently does not delete faces. So, no holes and no clear. This would be complex to do, essentially because JPP is multi-face.
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 27 / 31
