    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 815.4k Views 155 Watching
      JohnGilles
      Can't get incremental push pull to work on my Mac...
      No alt key, and neither option noe control; seem to allow the incremental function to show up on the VCB
        No alt key
        What about trying Command?
        What version of SketchUp are you using? Which Mac OS version? Please complete your profile.
          JohnGilles
          @dave r said:
          No alt key
          I did update my profile, thanks for reminding me
          I am working on a 15" 2016 MacBook Pro
          SketchUp Pro 2020
          And. no. the Command key doesn't toggle the Increment function either.
          • fredo6F Offline
            This is normal that it does not work, because I had to rollback to the old version, pending the resolution of a problem with Mac M1 platforms.
            It is now solved, so I will soon republish JPP v4.6a, with Incremental PushPull.
            • fredo6F Offline
              JointPushPull v4.6a just republished on the ExtensionStore, with
              • Texture contnuity
              • Incremental PushPull
              • PushPull to Target Plane
              It requires LibFredo6 v13.2a.
              TutorialsUp has published a nice video summarizing the new features.
                tonytony321
                Hi Fredo, thank you for the contribution to the community.
                My JPP doesn't start properly. It has no response when I click all of the icon from the toolbar.
                • I am using SKP 2022 on window 10. All fredo plugins are up to date.
                • I have already purchased the plugin bundle and activated the license for those plugins that I am using.
                • Fredo scale/ tools on surface/ round corner are all working properly.
                • Lib Fredo settings in tab - Window also not working except for set peferred languages.
                Hope you can solve my problem, thank you.
                Any chance I can use a previous version for now?
                • fredo6F Offline
                  When you upgrade to LibFredo6 v13.2a, it is important you restart all instances of Sketchup.
                  In the worse case, could you you restart your computer and it should make it.
                  • I Offline
                    igorassis
                    im having the same problem, i tried restarting, reinstalling and this is still happening,
                    Error; #<NameError; undefined method `notify_by_otpicker' for class `Traductor;;FaceSelector'>
                    c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6faceselector.rbe;66;in `method'
                    c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6faceselector.rbe;66;in `initialize__'
                    c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6faceselector.rbe;35;in `initialize'
                    c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe;409;in `new'
                    c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe;409;in `init_face_selector'
                    c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe;151;in `initialize'
                    c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe;85;in `new'
                    c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe;85;in `action__mapping'
                    c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;143;in `call'
                    c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;143;in `launch_action'
                    c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;240;in `launch_action'
                    c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/bootstrap_jointpushpull.rbe;87;in `launch_action'
                    c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/bootstrap_jointpushpull.rbe;135;in `block in declare_command'
                    c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;1464;in `command_invoke'
                    c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;1444;in `block (2 levels) in build_config_commands'
                    c;/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe;1385;in `block in add_command'
                      antonblam
                      Hey Fredo, I've ran into a problem.
                      I duplicated a group a several times and tried to PudhPull them from the outside, as the extension allows. The problem is that the extension sees them as components and treats them accordingly.
                      Do you have the solution for that?
                        @igorassis
                        Do you have the latest version of LibFredo installed ?
                        Do you have the latest version of the SketchUcation toolset installed [v4.2.9] which has the up to date SCF licensing system ?
                        Both are available from the PluginStore - restart SketchUp after installation to sync everything
                        • fredo6F Offline
                          That's a known issue: Freshly copied groups behave like components. I may fix it for JPP.
                          In the meantime, just enter (double-click) each group to make them unique.
                            rv1974
                            I wish Follow Push Pull will be able to remove geometry nicely a-la 3ds max (like shown on attached picture)
                            • fredo6F Offline
                              JPP currently does not delete faces. So, no holes and no clear. This would be complex to do, essentially because JPP is multi-face.
                                cdurkin
                                Despite how awesome this plugin is. I'm wondering?? is there a way to further the functionality by allowing the push-pull options to push-pull only lines into planes and maybe even guide points into lines? Perhaps there is already, but I have studied the tools fairly extensively and don't see a way to do this. Adding these features would make these already game-changing tools even better!
                                Let me know if this is possible, in the works, or if not could it be possible to add it as a feature(s) in the near future updates of the tool?
                                  @cdurkin said:
                                  ... to push-pull only lines into planes ...
                                  There's a plugin that can extrude edges to faces already.
                                  What version of SketchUp are you using? Please complete your profile.
                                  • N Offline
                                    natia556
                                    Hı, I can't add it as a plugin to sketchup 2023 😳
                                      Why? What are you doing to install it? Did you also installed the required LibFredo6? Did you also install the required Sketchucation ExtensionStore tool?
                                      What version of SketchUp are you really using? Your profile indicates a nonexistant version.
                                        seasdes
                                        I noticed that JPP treats group copies as components. Is there a way to overcome this without having to enter each copy. I am running the latest version of JPP. and SU V21
                                        Using Sketchup Pro 2019
                                        • fredo6F Offline
                                          It's a change I need to make. No workaround for the time being, exect than to make the groups unique manually.
                                            seasdes
                                            Ok thanks
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 28 / 31
