    Import he NCS color system from .ase-file in SU
    13 Posts 5 Posters 3.0k Views 5 Watching
    • gullfoG
      gullfo
      there are sources for the NCS colors and there are also online and github converters to get to rgb or hex which as Rich has pointed out could be imported from a text file.
      e.g. source https://www.paintcolourchart.com/ncs-colors (which shows corresponding rgb, hex)
      e.g. https://github.com/m90/ncs-color
      ncs_color_converted.csv
      Glenn
      http://www.runnel.com
        @gullfo said:
        ...and there are also online and github converters to get to rgb or hex...
        Did you happen to find anything that would convert all of the colors to RGB or HEX in one go? I could only find converters for single colors.
        • gullfoG
          gullfo
          i dumped the color list into a spreadsheet and ran the convert code to create the csv i attached to my original message.
          Glenn
          • gullfoG
            gullfo
            i created a color file which can be imported by Fredo's Color Paint tool. colors are sorted in name order. since rgb leads in the file, sorting on rgb would be easy enough in case you want to see in color order vs name order...
            ncs_color.txt
            Glenn
              https://i.imgur.com/uXyldPC.png
              1700+ Colours
              ncs_color_converted-[rich].txt
              If your feeling completely nuts here's my Colornerd library of 3900+ named colours...
              https://i.imgur.com/828elnt.png
              colournerd.txt
              • gullfoG
                gullfo
                what tool are you using for the color import? color paint? what version?
                Glenn
                  I see that after my post.
                  And you beat me to the .txt file. I was just making one myself. Thanks for uploading it, though.
                    A pre-alpha build of ThruPaint 2 that has Color Paint type interface.
                      Is that build available?
                        Unlikely, I'm just helping out with the testing. Its a handsome update.
