    Import he NCS color system from .ase-file in SU
    13 Posts 5 Posters 3.2k Views 5 Watching
    • tuna1957T
      tuna1957
      Curiosity got the better of me…. Looked up .ase (Adobe Swatch Exchange) . My first suggestion would be look in the
      3D Warehouse and see if someone might have already created a collection of these colors as .skm files. I know you can find collections of various paint companies whose colors have been converted for SU. It’s worth a look.
      If someone hasn’t already done the work for you, you’ll need to search for ways to convert the .ase files to .jpeg files. Then there are SU plugins that will convert the .jpeg’s to .skm files that could be saved as a collection in your materials folders.
      All that said I not a guru on this type of thing and I’m sure one of the top bananas will be along with further advice.
        I know of no way to read in a swatch file and convert to material colour in SketchUp.
        But if you can track down the equivalent NCS in .txt format with RGB values then you could use FredoTools to import it.
        https://i.imgur.com/Lokq4gN.png
        It would need to be in particular format which you can see here...
        ..\AppData\Roaming\SketchUp\SketchUp 2022\SketchUp\Plugins\Fredo6_!LibFredo6\Ancillary
        • gullfoG
          gullfo
          there are sources for the NCS colors and there are also online and github converters to get to rgb or hex which as Rich has pointed out could be imported from a text file.
          e.g. source https://www.paintcolourchart.com/ncs-colors (which shows corresponding rgb, hex)
          e.g. https://github.com/m90/ncs-color
          ncs_color_converted.csv
          Glenn
          http://www.runnel.com
            @gullfo said:
            ...and there are also online and github converters to get to rgb or hex...
            Did you happen to find anything that would convert all of the colors to RGB or HEX in one go? I could only find converters for single colors.
            • gullfoG
              gullfo
              i dumped the color list into a spreadsheet and ran the convert code to create the csv i attached to my original message.
              Glenn
              • gullfoG
                gullfo
                i created a color file which can be imported by Fredo's Color Paint tool. colors are sorted in name order. since rgb leads in the file, sorting on rgb would be easy enough in case you want to see in color order vs name order...
                ncs_color.txt
                Glenn
                  https://i.imgur.com/uXyldPC.png
                  1700+ Colours
                  ncs_color_converted-[rich].txt
                  If your feeling completely nuts here's my Colornerd library of 3900+ named colours...
                  https://i.imgur.com/828elnt.png
                  colournerd.txt
                  • gullfoG
                    gullfo
                    what tool are you using for the color import? color paint? what version?
                    Glenn
                      I see that after my post.
                      And you beat me to the .txt file. I was just making one myself. Thanks for uploading it, though.
                        A pre-alpha build of ThruPaint 2 that has Color Paint type interface.
                          Is that build available?
                            Unlikely, I'm just helping out with the testing. Its a handsome update.
