    Fredo Plugins Error
    extensions
    26 Posts 15 Posters 7.0k Views 15 Watching
      angusweb
      I am having exactly the same issue with a new install on Sketchup 2022. None of the Fredo6 extensions seem to bring up the secondary menus so are basically unusable.
      Did anyone find a resolution? trying to get toposhaper to work primarily, but also not working for jointpushpull or toolsonsurface etc.
        angusweb
        I am having the same issue and wondered if anyone had found a solution yet?
        Basically trying to get toposhaper to work on SketchUp 2022, but as per the original poster I am unable to get the fredo6 secondary menus to open up on toposhaper, jointpushpull, or toolsonsurface - so basically all the fredo extensions that I have installed.
        I do have other extensions installed which may be interfering but I am not sure? See attached image
        Thanks in advance
        Sketchup plugins folder image
        • fredo6F Offline
          For those having a problem at startup with the error
          Error starting up plugin (creating menus and icons) undefined method `add_item´form nil:NilClass
          I suggest that you install LibFredo6 v12.6a, just published.
          If the error is encountered, it opens the Ruby console and displays traces before the error.
          I am interested in these traces, as I have a hard time to détermine the origin of this problem.
          Thanks to all
            ruralaccent
            I'm having an issue with Fredo plugins too, although not entirely the same (although perhaps it's related). I was prompted to update Fredo Lib yesterday (I'd not used sketchup for a few weeks). All seemed to work, then this morning I get a message saying Sketchucation plugin is out of date (even though it's not - it's the latest version) and none of the Fredo plugins that need a licence will work. I have paid licences for all Fredo plugins, but none of the paid ones now work because they're all demanding the latest Sketchucation plugin, even though that is installed. Is this related or a seperate issue?
              The latest version of the SketchUcation toolset is here...
              https://sketchucation.com/pluginstore?pln=SketchUcationTools
              Get it from the PluginStore [linked].
              It contains the newest licensing software, needed by many of Fredo's extensions.
              Restart SketchUp after installing it... then report back...
                angusweb
                Thanks all - it seemed that not having the latest sketchucation toolset was my issue. Updated now and all fredo's plugins now seem to be working as intended, thanks for the help!
                  archzag
                  TIG is right. You need to download the latest version of the SKU. This is how Fredo's plugins work.
                  Archzag
                    SpicolisDad
                    Similar problem to others here with Fredo Plugins - All licensed up (glad Fredo is getting some dough!)
                    Symptoms:
                    Get the "trial license expired" message - go to validate - navigate to where I stored my license files- The License files are invisible.(though actually there)
                    So ...no validation is possible...
                    The Answers:
                    Yes I searched before asking. 😄
                    Yes - I had to repair my SU install after a nasty fight with Vray's latest version.
                    Yes- IIRC everything worked before that though Im not 100% sure.
                    Followed several similar threads with various fixes suggested there-
                    So far I tried:
                    Deleting the C:/user data fredo folder,
                    Uninstalling Sketchucation tools.
                    Reinstalling Sketchucation Tools to latest
                    Ran Fredo Updater - everything green and "up to date"
                    Obviously a path or permissions issue somewhere....checker can't/won't/doesn't see the licenses -
                    any help on getting it pointed correctly?
                    Fear we're headed to a "gut it/scorched earth" situation here...a lengthy process
                    Thanks for all you do!
                      https://i.imgur.com/HSlz8qv.png
                      The license won't show if it is not the correct name.
                      https://i.imgur.com/ZeFQFJa.png
                      If you set All Files what do you see?
                        SpicolisDad
                        Thank you for your assistance:
                        As usual- the problem was down to user error.
                        I became confused by a similarly named but now deprecated older plug in.
                        In process of creating detailed screen shots documenting the loop I was in...
                        I finally realized my mistake.
                        you see my Skethucation friends....apparently I'm afflicted with what they call, in todays vernacular, "the big dumb"
                        But, I draw well, and have good grooming habits..so I've got that going for me which is nice....
                        Anyway...please disregard my prior post. All is well.
                        The plugins now function as expected - (as they will do when installed correctly and not fighting with other plug ins)
                        I couldn't be happier.
                        Once again thanks I'm very grateful for the prompt support offered by this forum.
                        you guys are great.
                        -Spicoli's Dad
                          You'll fit right in around here with those credentials 👍
                            janvin
                            Not to bring this error up once again in 2023, but I'm experiencing it as well with SU 2021, FredoGhost v2.0a, FredoLib 13.7b, and Sketchucation Toolset v4.3.
                            After getting the error and restarting SU, the toolbar appears but when trying to open the Studio tool or activating the other limited tools that are available with the trial version, nothing happens, no messages or anything.
                            Disabled all plugins including Sketchucation v4.3 but except for Fredolib 13.7bb.
                            Uninstalled FredoGhost.
                            Started up SU 2021 - installed FredoGhost - got the regular Restart SU message.
                            Restart SU 2021.
                            FredoGhost toolbar appears - click on Studio tool and the Studio window opens as it should = baseline.
                            Open Extension Manager - one by one enabling plugins followed immediately by clicking on the Studio tool.
                            Enabled Sketchucation v4.3 - click FredoGhost Studio tool - no Studio window opens.
                            Immed. disable Sketchucation v4.3 - click on FredoGhost Studio tool - no Studio window opens.
                            Restart SU 2021.
                            FredoGhost toolbar appears - click on Studio tool and the Studio window opens as it should.
                            I continued through the list of plugins to see if any others prevented FredoGhost Studio from opening, all good except for Sketchucation is still disabled. I'll leave it disabled for now as I trial Ghost and hopefully if all works well, I will get that Ghost license and a new version Sketchucation will be released that doesn't cause this conflict.
                            • fredo6F Offline
                              Before launching FredoGHost, could you open the Ruby Console and check if there are errors.
                                chrissfcs
                                I am getting a similar error on the tools on surface plug in. I uninstalled all plugins and started fresh with the latest libfredo and tools on surface plug in so that no others would interfere. Still the same error. Other plugins from fredo 6 are working correctly.
                                using 2022. the error messages are attached.
                                Thanks.
                                  arhimas Newcomers
                                  Hello everybody!. I'm having some issues trying to round some corners and edges. This is the output:
                                  Date: 15-Jun-23 16:56:28
                                  An error occurred in FredoCorner
                                  An error occured in the Ruby code
                                  undefined method `[]' for nil:NilClass
                                  fredocorneralgo.rbe: 2316 -- brane_free_chemin
                                  fredocorneralgo.rbe: 2061 -- block in catena_process_branes_protected
                                  fredocorneralgo.rbe: 2047 -- each
                                  fredocorneralgo.rbe: 2047 -- catena_process_branes_protected
                                  fredocorneralgo.rbe: 2009 -- block in catena_process_branes
                                  fredocorneralgo.rbe: 2008 -- catch
                                  fredocorneralgo.rbe: 2008 -- catena_process_branes
                                  fredocorneralgo.rbe: 965 -- block in solid_construct_branes
                                  fredocorneralgo.rbe: 964 -- each
                                  fredocorneralgo.rbe: 964 -- solid_construct_branes
                                  fredocorneralgo.rbe: 919 -- block in solid_reconstruction
                                  fredocorneralgo.rbe: 918 -- each
                                  fredocorneralgo.rbe: 918 -- solid_reconstruction
                                  fredocorneralgo.rbe: 883 -- solid_add_remove_edges
                                  fredocornertool.rbe: 1840 -- selection_change
                                  fredocornertool.rbe: 1828 -- selection_add_remove_edges
                                  fredocornertool.rbe: 1868 -- selection_mouse_up
                                  fredocornertool.rbe: 2300 -- onLButtonUp
                                  Any ideas?
                                  • fredo6F Offline
                                    Any ideas?
                                    Difficult to tell without seeing the model.
                                    It is likely related to an offset which is too large compared with the size of the edges you try to perform the rounding on.
                                      Dyllanolv
                                      please help! Freddo asks me to validate licenses again when he had previously validated them and they worked correctly. Now when I try to validate the licences again I get this error...
                                      Error in the License Validation
                                      Request to Sketchucation: ERROR AOC
                                      Computer name mismatch - It is advised to erase the Signature file and revalidate
                                      Do you want to open the folder containing the Signature file?
                                      [/img]C:\Users\Usuario\Downloads\Captura.PNGq.PNG[/img]
                                      • fredo6F Offline
                                        Please just do what is suggested in the dialog box.
                                        M 1 Reply Last reply Reply Quote 0
                                          mrwick @fredo6
                                          @fredo6 Hey how am i supposed to do it please I paid a lot of money to buy 8 plugins just tell me how to revalidate and where
                                            Rich O Brien Moderator @mrwick
                                            @mrwick https://downloads.sketchucation.com/licensing/SCFLicense-Instructions_to_Users.pdf
                                            Licenses are at https://sketchucation.com/webshop/my-licences.php
                                            You need latest releases of all extensions installed including Sketchucation Tools
                                            https://sketchucation.com/plugin/696-sketchucationtools
                                            ...and Libfredo
                                            https://sketchucation.com/pluginstore?pln=LibFredo6
