    Fredo6
    16 Posts 4 Posters 5.8k Views 4 Watching
      Scozzarella
      Thank you very much
        Scozzarella
        I purchased a bundle Fredo6 but I can't find in Sketchup the Extension License panel for validating
          Go to Tools > Fredo Collection > [Extension Name] > License
            To expand on what Rich said...
            You need to have installed the latest versions of the SketchUcation Toolset [v4.2.5] and Lib Fredo [giving the SCF-license dialog as v5.4]
            You need to install each of the bundled extensions...
            Restart SketchUp after all of the installations to ensure every thing syncs...
            The extensions will each have an entry in the Tools > Fredo Collection submenu.
            In each extension's submenu it will have a 'License...' item.
            Click on this to open the License dialog [which should show v5.4 top-left], which can then be used to validate that extension by connecting it to the saved SCF-license files which you have saved on your computer previously...
            After all are processed you should be good-to-go...
              Scozzarella
              Thank you for answer but in Mac version the path is different.
              Then Round Corner doesn't work and appear message SU20016, Why
                Your profiles says v2021 - so why are you now talking about v2016 ?
                Fredo's extensions are normally for >= v2017 !
                As is the SketchUcation Toolset v4.2.5 and the newer Lib Fredo !
                These are needed for the licensing to work.
                The Tools menu items are the same on PC & MAC...
                Folder/File paths might vary slightly but are essentially the same ??
                Please correct you reply and confirm the problems again...
                  There are two versions of Round Corner, one of them is for SketchUp 2016 and earlier. It sounds like you've installed that one instead of the version for 2017 and newer.
                    Scozzarella
                    Thank you very much. Now all works
                      @scozzarella said:
                      Now all works
                      What did you do to fix it?
                        You need the now somewhat old legacy versions of Fredo's extensions and the legacy Lib Fredo if you have an older version of SketchUp (< v2017), but I don't think the SketchUcation Toolset or its SCF licensing system will work on such old versions of extensions anyway !
                          Scozzarella
                          But FredoCorner is not with Bundle
                            No. It's not included in the bundle. You can get that license separately.
                            As TIG has asked you several times, please verify the version of SketchUp you are using. Your profile indicates 2021 Free/Make but there is no such version.
                              FredoCorner is licensed separately from the bundle...
                              But you need v2017 or newer to have the correct installations to license FredoCorner [or any other extensions] !
                              So please clarify what SketchUp version you are using...
                                Scozzarella
                                SU 2022
