    Fredo6
    16 Posts 4 Posters 6.0k Views 4 Watching
      Scozzarella
      Thank you for answer but in Mac version the path is different.
      Then Round Corner doesn't work and appear message SU20016, Why
        Your profiles says v2021 - so why are you now talking about v2016 ?
        Fredo's extensions are normally for >= v2017 !
        As is the SketchUcation Toolset v4.2.5 and the newer Lib Fredo !
        These are needed for the licensing to work.
        The Tools menu items are the same on PC & MAC...
        Folder/File paths might vary slightly but are essentially the same ??
        Please correct you reply and confirm the problems again...
          There are two versions of Round Corner, one of them is for SketchUp 2016 and earlier. It sounds like you've installed that one instead of the version for 2017 and newer.
            Scozzarella
            Thank you very much. Now all works
              @scozzarella said:
              Now all works
              What did you do to fix it?
                You need the now somewhat old legacy versions of Fredo's extensions and the legacy Lib Fredo if you have an older version of SketchUp (< v2017), but I don't think the SketchUcation Toolset or its SCF licensing system will work on such old versions of extensions anyway !
                  Scozzarella
                  But FredoCorner is not with Bundle
                    No. It's not included in the bundle. You can get that license separately.
                    As TIG has asked you several times, please verify the version of SketchUp you are using. Your profile indicates 2021 Free/Make but there is no such version.
                      FredoCorner is licensed separately from the bundle...
                      But you need v2017 or newer to have the correct installations to license FredoCorner [or any other extensions] !
                      So please clarify what SketchUp version you are using...
                        Scozzarella
                        SU 2022
