    Custom Stone Veneer Texture
    17 Posts 7 Posters 8.5k Views 7 Watching
    • Gus RG Offline
      Gus R
      I didn't know where to post this but I'm looking from someone to create a more accurate stone veneer texture for a rendering I'm working on for home owner's association. Is there a website or someone on here that would be able to assist me in this matter?
      www.instagram.com/gusrobatto/
      www.facebook.com/gusrobatto
      • Rich O BrienR Online
        It's a texture you looking for? Have you any reference?
        • Gus RG Offline
          Gus R
          Sure do.
            Did you search Castle on textures.com
            • Gus RG Offline
              Gus R
              I didn't but I'll look later. Might be too rustic. I've been using a material from poliigon.com which I thought was close enough but apparently there's someone at the homeowner's association with nothing better to do.
                I have a Substance Designer file that is close[ish]....
                https://i.imgur.com/14T1ql4.png
                • Gus RG Offline
                  Gus R
                  Thanks Rich. They want an exact match which is rather unusual especially for something like stone. The material I use now is Brick Old 04 from Poligon. Some clients seem to think you can create assets at the press of a button.
                    Over here that's called Dressed Fieldstone and it's common enough. That might help with your searching.
                    I'll keep browsing what I have....
                    • pbacotP Offline
                      Is something like this helpful. It looks a lot like Napa wall stone that we use around here but usually there's no lichen.
                      • jujuJ Offline
                        juju
                        Quote them for the asset creation, make it worth it as it won't be simple. See how serious they are about needing an exact match.
                          Kinda close...
                          https://i.imgur.com/cyjpVXS.png
                          Have you a wider photo with more stone in view?
                          • gullfoG Offline
                            gullfo
                            @gus r said:
                            ... apparently there's someone at the homeowner's association with nothing better to do.
                            as i just moved into a neighborhood with an HOA - they want: the plat map, landscape plan, house elevations, topology map, and the actual stone samples (sent or brought to ARC meeting). so i can replace 50ft of crappy plastic edging with actual block... i'd hate to see what they want if i have to add a shrubbery!
                            this is a site i've been using lately: https://www.sketchuptextureclub.com/
                            Glenn
                            http://www.runnel.com
                            • L Online
                              For Council any "reasonable representation" of materials should suffice. Any of the suggested materials will work. Unless it is a heritage issue, In which case you would render with a "reasonable facsimile" Put the image you posted on the document, with the note "this is a detail of the stone finish represented on the 3D render"
                              • Gus RG Offline
                                Gus R
                                Thanks everyone! We've sidelined this texture for the project for the time being.
                                • gullfoG Offline
                                  gullfo
                                  agreed, but that assumes rational people in the council... not always a given, and incumbency has its advantages when it comes to making a change of people composing the ruling group...
                                  Glenn
                                    Arengu
                                    If you had a bigger picture of more stones I could make it seamless for you (make it a repeatable texture)...
                                    Here's a seamless version of the picture you sent earlier, perhaps that would work for you? With a bigger picture it would be better quality.
                                    • Gus RG Offline
                                      Gus R
                                      Thanks Arengu. I requested the client to get a large image of the stone veneer to no resolve. I ended up getting a texture from someone else that resolved the issue.
                                      Thanks to everyone else that chimed in.
