    Custom Stone Veneer Texture
    17 Posts 7 Posters 9.7k Views 7 Watching
    • Gus RG
      Gus R
      Sure do.
      www.instagram.com/gusrobatto/
      www.facebook.com/gusrobatto
        Did you search Castle on textures.com
        • Gus RG
          Gus R
          I didn't but I'll look later. Might be too rustic. I've been using a material from poliigon.com which I thought was close enough but apparently there's someone at the homeowner's association with nothing better to do.
            I have a Substance Designer file that is close[ish]....
            https://i.imgur.com/14T1ql4.png
            • Gus RG
              Gus R
              Thanks Rich. They want an exact match which is rather unusual especially for something like stone. The material I use now is Brick Old 04 from Poligon. Some clients seem to think you can create assets at the press of a button.
                Over here that's called Dressed Fieldstone and it's common enough. That might help with your searching.
                I'll keep browsing what I have....
                • pbacotP
                  Is something like this helpful. It looks a lot like Napa wall stone that we use around here but usually there's no lichen.
                  • jujuJ
                    juju
                    Quote them for the asset creation, make it worth it as it won't be simple. See how serious they are about needing an exact match.
                      Kinda close...
                      https://i.imgur.com/cyjpVXS.png
                      Have you a wider photo with more stone in view?
                      • gullfoG
                        gullfo
                        @gus r said:
                        ... apparently there's someone at the homeowner's association with nothing better to do.
                        as i just moved into a neighborhood with an HOA - they want: the plat map, landscape plan, house elevations, topology map, and the actual stone samples (sent or brought to ARC meeting). so i can replace 50ft of crappy plastic edging with actual block... i'd hate to see what they want if i have to add a shrubbery!
                        this is a site i've been using lately: https://www.sketchuptextureclub.com/
                        Glenn
                        http://www.runnel.com
                        • L
                          For Council any "reasonable representation" of materials should suffice. Any of the suggested materials will work. Unless it is a heritage issue, In which case you would render with a "reasonable facsimile" Put the image you posted on the document, with the note "this is a detail of the stone finish represented on the 3D render"
                          • Gus RG
                            Gus R
                            Thanks everyone! We've sidelined this texture for the project for the time being.
                            • gullfoG
                              gullfo
                              agreed, but that assumes rational people in the council... not always a given, and incumbency has its advantages when it comes to making a change of people composing the ruling group...
                              Glenn
                                Arengu
                                If you had a bigger picture of more stones I could make it seamless for you (make it a repeatable texture)...
                                Here's a seamless version of the picture you sent earlier, perhaps that would work for you? With a bigger picture it would be better quality.
                                • Gus RG
                                  Gus R
                                  Thanks Arengu. I requested the client to get a large image of the stone veneer to no resolve. I ended up getting a texture from someone else that resolved the issue.
                                  Thanks to everyone else that chimed in.
