    2.2k Posts 484 Posters 872.5k Views 489 Watching
      @sumitisah said:
      Licenses of all installed plugins from fredo 6 bundle (combo of 😎 are showing expired on my system and I cant re validate as its showing seats are occupied.
      Licenses have no expiration date. The only limit on licenses is the number of devices that can be used.
      Make sure you have the latest releases of Sketchucation Tools and LibFredo installed.
        @giacomospiazzi said:
        How can this be possible if I downloaded this today, 06 May 2022?
        Are you a time traveller? πŸ˜›
        What version of Sketchucation Tools and LidFredo are you running?
          sumitisah
          @tig said:
          Do you have the latest version of Lib Fredo and the SketchUcation Toolset installed [v4.2.6] ?
          This uses the latest licensing code.
          If so, then Fredo might respond with some practical advice...
          Thanks, seems like my sketchucation tool is not updated..the last upgrade was on 28th april and my licenses were showing expired from that day. Let me update it and check if problem is resolved.
            sumitisah
            Ok, so now that I updated my Sketchucation tools on validating my extensions its taking a new seat if available. For my curviloft extension 3 seats were already occupied (one on my current sysytem) so can't validate the license.
              Fredo can probably reset your over-used licenses if you PM him the full details...
                sumitisah
                Ok sure . Thanks!
                  sumitisah
                  @sumitisah said:
                  Ok sure . Thanks!
                  Seems like I can't pm @fredo6 . Message is stuck in outbox.
                    That just means he hasn't looked at it yet. Be patient.
                    • fredo6F Offline
                      Seat release done.
                        sumitisah
                        @fredo6 said:
                        Seat release done.
                        Thanks fredo!!! Much appreciated for such a quick response.
                          giacomospiazzi
                          I have following:
                          SketchUcation v4.2.6
                          Fredo6 LibFredo6 v12.8a
                          Fredo6 TopoShaper v2.6a
                          All was installed this morning, so 7 or 8 hours ago
                          Thanks in advance for your support
                          Giacomo
                            danygico
                            hi
                            I have
                            Fredo6 Bundle 2022
                            after released the licenses to install SU2022 (I understood it after that it was not needed) now I find RoundCorner that I have 3 Seats used even if I am only on 2 computers, moreover the other plugins I had installed work even if they do not appear in "Global status of plugins under SCF License " as seen in the image
                            how can i solve?
                            thank you
                              cygnussphere
                              Screenshot 2022-05-09 113122.pngI switched computers and am trying to validate my FredoCorner license but, I keep getting this Error message. Help please.
                                @cygnussphere said:
                                I switched computers...
                                Is the time/date correct on the new computer?
                                  cygnussphere
                                  Yes they are.
                                    A0B error code is:
                                    File time, created time, hardware ID time mismatch in signature...
                                    So something is up...
                                      cygnussphere
                                      @tig said:
                                      A0B error code is:
                                      I had to Uninstall/Reinstall Sketchup to get it to finally work.
                                      Thanks for your help
                                        When you reinstalled did you do so correctly? That requires right clicking on the downloaded installer and choosing Run as administrator.
                                          I think self-release of license seats is in the pipe-line...
                                          Perhaps Fredo or GΓ‘bor will chip in with some news...
                                          • dereiD Offline
                                            derei
                                            It would be useful to have the possibility to release a license seat from the website.
                                            I just noticed that one of my license has all 3 seats taken, however I am only using one. So, the other two must be licenses from other versions or machines, that are not in use anymore.
                                            Any thoughts on this one?
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 109
                                            • 110
                                            • 16 / 110
