    2.3k Posts 515 Posters 2.1m Views 520 Watching
      Fredo can probably reset your over-used licenses if you PM him the full details...
        sumitisah
        Ok sure . Thanks!
          sumitisah
          @sumitisah said:
          Ok sure . Thanks!
          Seems like I can't pm @fredo6 . Message is stuck in outbox.
            That just means he hasn't looked at it yet. Be patient.
            • fredo6F Offline
              Seat release done.
                sumitisah
                @fredo6 said:
                Seat release done.
                Thanks fredo!!! Much appreciated for such a quick response.
                  giacomospiazzi
                  @rich o brien said:
                  @giacomospiazzi said:
                  How can this be possible if I downloaded this today, 06 May 2022?
                  Are you a time traveller? 😛
                  What version of Sketchucation Tools and LidFredo are you running?
                  I have following:
                  SketchUcation v4.2.6
                  Fredo6 LibFredo6 v12.8a
                  Fredo6 TopoShaper v2.6a
                  All was installed this morning, so 7 or 8 hours ago
                  Thanks in advance for your support
                  Giacomo
                    danygico
                    hi
                    I have
                    Fredo6 Bundle 2022
                    after released the licenses to install SU2022 (I understood it after that it was not needed) now I find RoundCorner that I have 3 Seats used even if I am only on 2 computers, moreover the other plugins I had installed work even if they do not appear in "Global status of plugins under SCF License " as seen in the image
                    how can i solve?
                    thank you
                      cygnussphere
                      Screenshot 2022-05-09 113122.pngI switched computers and am trying to validate my FredoCorner license but, I keep getting this Error message. Help please.
                        @cygnussphere said:
                        I switched computers...
                        Is the time/date correct on the new computer?
                          cygnussphere
                          Yes they are.
                            A0B error code is:
                            File time, created time, hardware ID time mismatch in signature...
                            So something is up...
                              cygnussphere
                              @tig said:
                              A0B error code is:
                              I had to Uninstall/Reinstall Sketchup to get it to finally work.
                              Thanks for your help
                                When you reinstalled did you do so correctly? That requires right clicking on the downloaded installer and choosing Run as administrator.
                                  I think self-release of license seats is in the pipe-line...
                                  Perhaps Fredo or Gábor will chip in with some news...
                                  • dereiD Offline
                                    derei
                                    It would be useful to have the possibility to release a license seat from the website.
                                    I just noticed that one of my license has all 3 seats taken, however I am only using one. So, the other two must be licenses from other versions or machines, that are not in use anymore.
                                    Any thoughts on this one?
                                    DESIGNER AND ARTIST DEREI.UK
                                      sukrawee
                                      I change my computer name and the Licence become Inactivate.
                                      I delete the "SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt" and uninstall the all plugin and reinstall.
                                      I do not release the previous seats.
                                      I complete reactivate all plugins and it's work.
                                      But the seats taken is two for all plugin
                                      How can I release the previous seats?
                                      • fredo6F Offline
                                        This is done.
                                          antonio.calvo
                                          @tig said:
                                          If the PayPal info is not sufficient, then you can email support and give the details needed, and a separate invoice can be issue to you...
                                          Hi, I have the same issue with getting a proper invoice but can't find support email contact anywhere. Do you mind sending it to me?
                                            Email to support[at]sketchucation.com
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 115
                                            • 116
                                            • 16 / 116
