    2.2k Posts 487 Posters 929.8k Views 492 Watching
      Jenkus
      @rich o brien said:
      @jenkus said:
      We purchased the bundle for Fredo and followed the descriptions.
      When trying to validate the license it says
      'msg_validation_error ..... ERROR_07'
      Sketchucation is up to date.
      The licenses don't show up in 'Global status of plugins under SCF License'.
      What to do?
      Screenshot the error message. We have no ERROR_07 message But we do have A07, B07 etc....
        carus
        Hi!
        I just purchased the plug in bundle but the validation of the licence file gives me some troubles.
        Somebody there that can help with this issue..?
          @carus said:
          ...but the validation of the licence file gives me some troubles.
          As has been indicated repeatedly in this thread, update the Sketchucation Extension Store and then restart SketchUp.
          Please complete your profile with SketchUp version and operating system.
            For ERROR_F07 I would follow TIG's instructions....
            https://sketchucation.com/forums/viewtopic.php?p=679135#p679135
            For deletion of signature files you need to go to your \AppData\Local\SCF Licenses and delete the file named...
            SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt
            • TIGT Online
              This is the issue raised by some earlier posts...
              Please read those in detail for more info...
              BUT from the dialog you posted it's clear that you have not installed the latest SketchUcation toolset and consequently you do not have the latest SCF licensing tool installed...
              Also ensure that you have latest versions of the Fredo-extensions installed.
              Restart SketchUp after installations to ensure everything is synced...
                OK, so after some backend probing 😳 we have pinpointed the F07 error that is appearing.
                It likely your .scflicense having no content. If it's 0kb in size then that's the issue.
                We are reverting back a few hours and reissuing license files which should fix these f07 errors.
                Sorry about that.
                • V Offline
                  vizz1999
                  Sorry about that.
                  Should we contact if our license files is 0KB, or later we will got a new file in email
                    Sorry about that.
                    We will email out new license files shortly. We can see which ones are empty so expect a proper license file soon
                      simplesketch
                      Hello, yes I thought it was strange that all my license files were 0kb empty files. I just received emails with new licenses that are about 600 bytes in size. I just tried to validate the RoundCorner license with the new license file and it worked. Thank you
                        No, thank you for your patience.
                        • John SBJ Offline
                          John SB
                          Hi any and all.
                          I have followed TIG's directions but I'm still getting ERROR_F07. I'm using SU Pro 2022 on a PC. I have used TIG's directions - launched the exe as admin - and repaired my install. I have version 4.2.5 of the plugin store installed. I have version 12.8a of LibFredo6 installed. I have installed, closed and reopened SU and all the toolbars are visible. But I cannot get the validation to work.
                            @john sb said:
                            Hi any and all.
                            Hi John,
                            Earlier today we had a problem with the license files we sent out. If your license file size is 0kb it is one of the problem licenses.
                            We reissued emails in the evening with the correct license file. Did you get those?
                            • John SBJ Offline
                              John SB
                              Hi Rich
                              Yes actually that is the case. I only just noticed they had 0kb. And I didn't know what was up with the, I thought, duplicate emails. I'll try using the latest email versions.
                              Thank you.
                                Report back if there's success or failure. I hope success πŸ‘
                                • John SBJ Offline
                                  John SB
                                  Success!
                                  Hi Rich
                                  That was the trick. Thanks again.
                                  • N Offline
                                    numerobis
                                    @moonsrfr said:
                                    Ok. I bought Fredo's bundle, got 8 emails, each with a licensing file in it
                                    So it's 8 individual licenses and not one bundle license? And all licenses need to be checked every few days? (5 days? 7 days?). So there must be a permanent connection to the internet?
                                      Yes
                                      The license does ping occasionally. Unsure of the time frame though. Fredo would know more.
                                      Not really. Tools will work offline if you validated while online.
                                      • TIGT Online
                                        Have you installed the latest version of Lib Fredo and restarted SketchUp ?
                                        • fredo6F Offline
                                          Normally, LibFredo6 v12.8a should solve this problem.
                                          • ely862meE Offline
                                            ely862me
                                            Yes, latest LibFredo installed trough the Extension Store 4.2.5.
                                            The other license extensions are working fine. Actually I just activated Curvizard and it worked once and then it said the same as the scale. They work only once after startup, then the Trial Period Expired window appear.
                                            So it is something that started today. Both of these licenses I inserted today!
                                            Elisei (sketchupper)
                                            Come and See EliseiDesign
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 109
                                            • 110
                                            • 12 / 110
