    2.3k Posts 517 Posters 3.0m Views 522 Watching
    • HornOxxH
      HornOxx
      ... wunderbar! your help and your great "headache" term explanation 😄 and of course the current discount 😄 Thanks a lot and everything worked fine!
      never trust a skinny cook
      • W
        Wantao
        Why request to Sketchucation = ERROR_A04?
        • G
          Gábor
          @wantao said:
          [attachment=0:3p16vflg]<!-- ia0 -->20220405100951.png<!-- ia0 -->[/attachment:3p16vflg]
          Hi Wantao,
          Could you please erase your signature file at C:\Users\username\AppData\Local\SCF Licenses\SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt and retry the activation? If you still get the same error message, please PM me your signature file for further investigation.
          • O
            OhhPao
            @tig said:
            Have you installed the latest versions of Lib Fredo and the SketchUcation toolset ?
            Have you restarted SketchUp afterwards ?
            This is needed to properly sync the set up...
            As Rich says, also check that your firewall set up 'whitelists' SketchUcation.com etc...
            Hello, do you have a detailed explanation for this manipulation? On my side nothing seems to block and I do not see where whitelist sketcheducation on my Mac or on ski directly. Thanks
            • fredo6F
              Could you try to do a check for updates for my plugins (menu entry: Windows > LibFredo6 Settings... > Check Plugins for Update).
                millerjx
                Love your extensions. A Fan!
                Glad to pay for them.
                I cannot seem to get Scale to validate.
                I have SketchUcation 4.1.3
                I went into My user/app data/to delete the text file indicated above.
                I bought it about an hour ago. Do I need to wait longer?
                  You need to update the Sketchucation Extension Store. The current version is 4.2.5. Use the existing version to install the update. Then close SketchUp and restart.
                    millerjx
                    Thanks, Dave
                    That worked
                      diablohk1972
                      The license file is not working at all.
                        The license version [5.3] reported in that dialog [top-left] is not the current one [5.4].
                        Install the latest version of the SketchUcation toolset from the PluginStore/ExtensionStore³ [>= v4.2.5].
                        Restart SketchUp to sync everything...
                        • C
                          cubiya
                          Please provide an other payment method asap other than PayPal since we cant use it in our country.
                          Thank you
                            @simplesketch said:
                            I'm using the latest available Sketchucation Manager 4.2.5
                            What version of SketchUp? What operating system? Please complete your profile.
                              simplesketch
                              Hello, I just purchased the Freedo6 perpetual license bundle. But when I try to install the license for RoundCorner, I get the same error message
                              msg_validation_error
                              Request to Sketchucation = ERROR_F07
                              I read this entire forum and followed the steps to delete the
                              file in the AppData/ Local / SCF Licenses folder and then repeated the validate license procedure. Still same error.
                              If this cannot be resolved I would have to request a refund.
                              I am using Sketchup Make 2017
                              Windows 11 64 bit
                              I was able to run RoundCorner (latest version) during the free trial period if that helps.
                                As well as having the latest version of the SketchUcation Toolset, you also need to have the latest version of Lib Fredo installed, and of course the newest version of each relevant Fredo's extension installed...
                                Can you checked this...
                                Also, have you restarted SketchUp after the installation[s], to ensure everything syncs ?
                                  simplesketch
                                  I updated my profile, I am using
                                  Sketchup Make 2017
                                  Windows 11 64-bit operating system
                                  I have Freedo6 library version 12.5a (21 Feb 22) installed
                                  I have RoundCorner installed
                                  latest version of Sketchucation
                                    See
                                    https://sketchucation.com/pluginstore?pln=LibFredo6
                                    The latest version is 12.8a 17-03-2022 - yours is out of date...
                                    Try installing that etc...
                                      simplesketch
                                      @tig said:
                                      See
                                      The latest version is 12.8a 17-03-2022...
                                      I now uninstalled all Freedo6 plugins and LibFredo6. I deleted the SCF file. Then I restarted sketchup, reinstalled the LibFredo6 (latest version 12.8) and RoundCorner using the Sketchucation plugin. Restarted sketchup again. Tried to validate license, same error.
                                        Error A02 is related to your signature file. Please send your scflicense file and signature file to support[at]sketchucation.com so we can examine them. Thanks
                                          Jenkus
                                          We purchased the bundle for Fredo and followed the descriptions.
                                          When trying to validate the license it says
                                          'msg_validation_error ..... ERROR_07'
                                          Sketchucation is up to date.
                                          The licenses don't show up in 'Global status of plugins under SCF License'.
                                          What to do?
                                            What to do?
                                            Screenshot the error message. We have no ERROR_07 message But we do have A07, B07 etc....
                                            • 11
                                            • 12
                                            • 115
                                            • 116
                                            • 10 / 116
