    šŸ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    More Fredo6 plugins becoming paid extensions
    165 Posts 56 Posters 81.9k Views 56 Watching
      liberterre
      @rich o brien said:
      When I do that, nothing happens…What can I do ?
      Is there an error message?
      No, nothing appears…
        mavie
        I've got the same issue. I think you need to look for errors in the Ruby console. (See Fredo's comments to me above) "Could you open the Ruby console to see if there are error messages."
        You too have an older OS; I think that's where he was going in his trouble-shooting...
          mavie
          A link to great comments posted to his YouTube channel (TheSketchUpEssentials) last week by Justin Geis re: Fredo's indispensable tools! Thanks Justin, you're so right.
            liberterre
            Opening the Ruby console I obtain this message :
            Error; #<LoadError; dlopen(/Users/regis/Library/Application Support/SketchUp 2017/SketchUp/Plugins/SketchUcation/SCFLicense/Mac_22/SUEX_SCFLibrary.bundle, 9); no suitable image found.  Did find;
            	/Users/regis/Library/Application Support/SketchUp 2017/SketchUp/Plugins/SketchUcation/SCFLicense/Mac_22/SUEX_SCFLibrary.bundle; cannot load 'SUEX_SCFLibrary.bundle' (load command 0x80000034 is unknown)
            	/Users/regis/Library/Application Support/SketchUp 2017/SketchUp/Plugins/SketchUcation/SCFLicense/Mac_22/SUEX_SCFLibrary.bundle; cannot load 'SUEX_SCFLibrary.bundle' (load command 0x80000034 is unknown) - /Users/regis/Library/Application Support/SketchUp 2017/SketchUp/Plugins/SketchUcation/SCFLicense/Mac_22/SUEX_SCFLibrary.bundle>
            /Applications/SketchUp 2017/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.2/lib/ruby/2.2.0/rubygems/core_ext/kernel_require.rb;54;in `require'
            /users/regis/library/application support/sketchup 2017/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;156;in `load_binary'
            /users/regis/library/application support/sketchup 2017/sketchup/plugins/sketchucation/scflicense/scflicenseruby.rbe;43;in `license_dialog'
            /users/regis/library/application support/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;784;in `show_license'
            /users/regis/library/application support/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;369;in `block in populate_support_menu'
            /users/regis/library/application support/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe;1378;in `call'
            /users/regis/library/application support/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe;1378;in `block in add_command'
            /users/regis/library/application support/sketchup 2017/sketchup/plugins/!!fredo6_lordofthetoolbars/controller_lordofthetoolbars.rbe;133;in `call'
            /users/regis/library/application support/sketchup 2017/sketchup/plugins/!!fredo6_lordofthetoolbars/controller_lordofthetoolbars.rbe;133;in `block in new'
            SketchUp;1;in `call'
            I'm just a user of SketchUp and I dont understand…
              Try installing the latest version of the SketchUcation Toolset [v4.2.5] - publish recently...
              This has some tweaks to address issues with older MAC set ups...
                mavie
                You're the man, TIG. Thank you so much for this suggestion. It worked perfectly and Fredo's Collection of tools now work for me and are all validated.
                  andtopri77
                  Buenas tardes soy de Colombia, estoy interesado en adquirir el paquete de los 8 plugins y quisiera saber con respecto a los 3 asientos, a que se refiere?. gracias
                  [mod=:1wgsf6mz]Good afternoon I am from Colombia, I am interested in acquiring the package of the 8 plugins and I would like to know with respect to the 3 seats, what do you mean?. Thank you[/mod:1wgsf6mz]
                    3 dispositivos por licencia
                    Download the free D'oh Book for SketchUp šŸ“–
                      andtopri77
                      Gracias por la respuesta, esto quiere decir que los puedo instalar en 3 equipos y trabajar con los plugins mismo tiempo ya que tengo un equipo de trabajo de 3 personas? o hay que estar quitando al licencia en uno para trabajar en otro. es es mi duda. gracias
                        [mod=:3bcjsupr]Thanks for the answer, this means that I can install them on 3 computers and work with the plugins at the same time since I have a work team of 3 people? or you have to be taking away the license in one to work in another. it's my doubt. Thank you[/mod:3bcjsupr]
                        Yes, you can use at same time
                        SĆ­, puedes usarlo al mismo tiempo
                        • chonC Offline
                          chon
                          Hello,
                          And you can desactivate a license on one computer and activate it on a fourth one... šŸ˜‰
                          Y puedes desactivar una licencia en una computadora y activarla en una cuarta...
                          • Gus RG Offline
                            Gus R
                            I'm getting the following error when trying to install Fredo Corner.
                            This is from a regular install through Extensions Manager.
                            ` C:/Users/Z590-E/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/forwardable.rb:115: warning: already initialized constant Forwardable::VERSION
                            C:/Program Files/SketchUp/SketchUp 2022/Tools/RubyStdLib/forwardable/version.rb:3: warning: previous definition of VERSION was here
                            C:/Users/Z590-E/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/forwardable.rb:116: warning: already initialized constant Forwardable::FORWARDABLE_VERSION
                            C:/Program Files/SketchUp/SketchUp 2022/Tools/RubyStdLib/forwardable/version.rb:4: warning: previous definition of FORWARDABLE_VERSION was here
                            ***************ERROR LibFredo6 Menu **************
                            Sketchup = 22.0.354
                            Platform = x64-mswin64_140
                            title = Round
                            Ext =
                            @submenu =
                            @menu_name = FredoCorner
                            @su_menu_name =
                            C:/Users/Z590-E/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/set.rb:381: warning: already initialized constant Set
                            C:/Program Files/SketchUp/SketchUp 2022/Tools/RubyStdLib/set.rb:70: warning: previous definition of Set was here
                            File load error (C:/Users/Z590-E/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/set.rb):
                            Error: #<TypeError: superclass mismatch for class SortedSet>
                            C:/Users/Z590-E/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/set.rb:384:in <top (required)>'
                            www.instagram.com/gusrobatto/
                            www.facebook.com/gusrobatto
                            • Gus RG Offline
                              Gus R
                              After getting stuck in a rabbit hole using Sketchucation Tools it does load and work but then as I started I can't get it to validate the license that I purchased as SCF_Purchased_License_RoundCorner_NORMAL_20220401.scflicense.
                              It's looking for FredoCorner.scflicense
                              The rbz is FredoCorner_v2.5a.rbz which is the latest and the library is also the latest.
                              • chonC Offline
                                chon
                                Hello,
                                RoundCorner and FredoConer are two different plugins.
                                The licence of the first one can't be used for the second one. šŸ˜‰
                                • chonC Offline
                                  chon
                                  Hello,
                                  Is your LibFredo6 up to date ?
                                    Mariotalluto
                                    Thanks Fredo,
                                    Where can we get the bill after buying ? I baught the bundle
                                    • Gus RG Offline
                                      Gus R
                                      Everything is up to date.
                                      After fumbling around I'm all set now and everything is licensed. 😲
                                      @chon said:
                                      Hello,
                                      • pep75P Offline
                                        pep75
                                        Suddenly I get an error message about licensing...Everything seems to be fine but everytime I want to use the plugin I got the license message. After updating I get the same error message again. Please help! I updated all plugins and I'm running SU as an administrator.
                                          See this thread for the update details...
                                          https://sketchucation.com/forums/viewtopic.php?f=323&t=73325
                                            @higherwire said:
                                            I may have missed it...
                                            See the link in the post prior to yours.
                                            • 5 / 9
