    The Nadesico A
    194 Posts 10 Posters 60.6k Views 10 Watching
    • Bryan KB Offline
      First block-out.
      • Bryan KB Offline
        πŸ˜† πŸ˜† πŸ˜†
        Yeah, this one is going to take a while.
        • Bryan KB Offline
          I dunno. It's close, but not quite there.
          It looks more curved in the anime, but the model reference shows it as more angular. I'm going to go with the angular and ditch this curving modeling.
          • Bryan KB Offline
            I've almost got head wrapped around this.
              I generally am not so interested in anything other than Architecture or Landscape. But I am looking forward to seeing the progress on this project πŸ˜„
              • Bryan KB Offline
                Finally some real progress. Not much to look at, but the overall profile of the nacelle is good.
                  Nice mate, on a roll. πŸ‘
                  • Bryan KB Offline
                    Started with this shape.
                    Then +Push/Pull and resized each face along the profiles. Now need to do the indents. Still needs some tweaking on the shape. I see one profile out of alignment.
                    • Bryan KB Offline
                      Thanks Mike!
                      Same technique for rear half of the front nacelles. Started with the same shape, +Push/Pull following the profile working backwards. Make component, then mirror the copies.
                      Tweaked the front a bit more. Will stop here and and reference the images and tweak before building more shapes.
                      The issue I'm seeing is the drawings are just slightly different from the actual model kit, so I'm going to end up with a hybrid because each reference offers details the other doesn't. The shape and scale will be exact, but minor detail like curves and angles are going to differ. So I'm going to have to find a middle ground. But I'm going to default to the drawing and anime references when in doubt. Hence, the nose is more rounded than the model kit, yet more angular than the drawing.
                      LOL. No wonder I've only seen one CG model of this ship and references were hard to find. It's a crazy design!
                      • Bryan KB Offline
                        Coming along.
                        I tweaked the nose some more. Slightly flattened the curve and made it slightly wider again toward the point.
                        I +Push/Pull'd the vertical profile through the component and then intersected (Selection ONLY). Had to erase a LOT of hidden lines after. Then copy and cut the lines I wanted and pasted into nacelle component and then closed some small gaps, but this worked out as I wanted.
                        • tuna1957T Offline
                          tuna1957
                          Great progress πŸ‘
                            ^ Agreed mate, he knocks out great product. πŸ‘
                            • Bryan KB Offline
                              Thanks tuna. Thanks Mike. πŸ‘
                              • Bryan KB Offline
                                Overview to date.
                                • Bryan KB Offline
                                  2 more views. And one of the geometry. The crazy, crazy geometry.
                                  • Bryan KB Offline
                                    Some minor tweaking and detail left and the forward nacelles are done.
                                    • Bryan KB Offline
                                      Details completed. I'm happy with it.
                                      I had to fiddle with the vertex lines, swapping one point to point for the reverse to flip the triangles and smoothing out other faces as best as possible.
                                      Also had to make the rear section with the holes a unique component as the other three quarter sections do not have those holes. Drew the holes with Tools on Surface, then indented push/push with Joint Push/Pull tool.
                                      • HornOxxH Offline
                                        HornOxx
                                        Bryan, these kind of procedural stories are your brand here and I love them! πŸ‘
                                        never trust a skinny cook
                                        • Bryan KB Offline
                                          Again, not much to look at, but the details are tough on this one.
                                          Rounded the leading face of the crest/ridge. This took days to figure out because it's narrow at the top and wide at the bottom AND the profile has a slight curve. WHEW!
                                          Changed the nose detail. There were several different versions, but this was the most common one used.
                                          Now for the issue that will NOT be fixed. The outer edges of all the main shapes have a slight beveled/rounded edge to them. This will not be included. I cannot be done on this model due to many of the faces having 3 vertex points. I will still do edge breaks where possible.
                                          The reason for the 3 vertices on a single point is the old "twisted trapezoid" shape so many designers like to use. Take a trapezoid, then slightly twist one edge. This causes triangle faces to be created to fill in the outline with a face. This prevents ANY type of "follow me" or edge modifications without a ridiculous number of more lines and connecting vertices. Which of course, makes the model bigger and does not guarantee a better look at the smaller scales.
                                          So I'm skipping it unless absolutely necessary. It should still look good. After all, this is a hybrid model to begin with and will make the fifth version in existence.
                                          • Bryan KB Offline
                                            Thanks L i am! Sorry I didn't reply earlier. I was busy with my new job and my spring time allergies have been kicking my but. Sorry I missed your post.
                                            • 1 / 10
