[Plugin Library] LibFredo6 - v14.5b - 24 May 24
After more than ten years of free distribution, some of Fredo's plugins have become paid extensions.
Precisely, these are:
RoundCorner
JointPushPull
Curviloft
FredoScale
ToolsOnSurface
TopoShaper
Curvizard
VisuHole
The transition will take place as of March 1st, 2022.After a 30-day free-trial period, these extensions will require a Sketchucation license.
Price is USD 12 per plugin, or USD 40 for the bundle of all 8 plugins. Sketchucation Premium members have a significant discount on this pricing.IMPORTANT: You need to install or upgrade to Sketchucation Extension Store v4.2.4 or above.
This is the original post on 27th Feb 2022
http://sketchucation.com/forums/viewtopic.php?p=677933#p677933 -
Oh... My Sketchucation Extension Store seemed to be old version, so I upgraded it, then plugins started working again. I thought this update would show up in that Sketchup Extension Manager as well, but no.
Thank you!
The SketchUp Extension Manager only shows available updates for extensions from the SketchUp Extensions Warehouse.
NEW RELEASE: LibFredo6 v12.8a - 17 Mar 22
LibFredo6 12.8a tentatively corrects problems related to the creation of menus for my plugins. Some users experience an error preventing the plugins to load correctly. Since I am not able to reproduce, I made some changes 'blindly', hoping this would improve the situation.
all fredo6 plugins stopped to work after last fredo6 lib update. Sketchup 2020.
To test if the problem is related to other plugins, I removed all my plugins from the plugin folder, and installed only sketchucation. From sketchucation plugin I installed fredo cuviloft and fredo6 lib (newest = 12.8a) and restarted Sketchup. Curviloft does not work. You can click on any of the icons but the tool does not initialize (standard cursor and prompt still visible)
What operating system? I'm not seeing any problems with amy of Fredo6's extensions after the latest update.
Could you open the Ruby Console before lunching Curviloft
is there a place where I can download previous versions of the plugins (and not the very old ones - for 2017 and earlier)? Thanks
yes, here you are:
Error: #<NoMethodError: undefined methodvisual_version' for SCFLicense:Module> c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1733:in
tem_context'
c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1709:intem_launcher' c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:119:in
launch_action'
c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:244:inlaunch_action' c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_curviloft/bootstrap_curviloft.rbe:76:in
launch_action'
c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_curviloft/bootstrap_curviloft.rbe:93:inblock in startup' c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1460:in
command_invoke'
c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1441:inblock (2 levels) in build_config_commands' c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1378:in
block in add_command' -
You need to upgrade to the latest version of Sketchucation ExtensionStore v4.2.4.
Apparently, you have an old version.
@qwertyas said:
Windows 10 Home
Please complete your profile with that and the SketchUp version after you update the Sketchucation Extension Store as Fredo6 directed.
I updated the plugin and reinstalled both Fredo6 Lib and Curviloft. It is working now. Thank you!
NO ES UN PLUGIN GRATUITO, SOLO FUNCIONA UNA TEMPORADA.
PERO PARECE UTIL, GRACIAS -
Translated by Google:
@jose_w650 said:
IT IS NOT A FREE PLUGIN, IT ONLY WORKS FOR ONE SEASON.
BUT IT SEEMS USEFUL, THANK YOULibFredo6 is available at no charge. A few of Fredo6's extensions are no longer free after their trial periods expire.
What version of SketchUp are you using? Your profile says 2021 Free/Make but there is no such version.
New LibFredo6?
when it will be available?
NEW RELEASE: LibFredo6 v12.9a - 13 May 22
LibFredo6 12.9a includes:
- Various fixes for my plugins
- Support for LOTT v2.1a
Thank you It works perfectly!
