    [Plugin Library] LibFredo6 - v16.3b - 21 Oct 26
    2.3k Posts 592 Posters 13.7m Views 594 Watching
    • qwertyasQ
      qwertyas
      is there a place where I can download previous versions of the plugins (and not the very old ones - for 2017 and earlier)? Thanks
      • qwertyasQ
        qwertyas
        @dave r said:
        @qwertyas said:
        all fredo6 plugins stopped to work after last fredo6 lib update.
        What operating system? I'm not seeing any problems with amy of Fredo6's extensions after the latest update.
        Windows 10 Home 21H1
        • qwertyasQ
          qwertyas
          @fredo6 said:
          @qwertyas said:
          all fredo6 plugins stopped to work after last fredo6 lib update. Sketchup 2020.
          To test if the problem is related to other plugins, I removed all my plugins from the plugin folder, and installed only sketchucation. From sketchucation plugin I installed fredo cuviloft and fredo6 lib (newest = 12.8a) and restarted Sketchup. Curviloft does not work. You can click on any of the icons but the tool does not initialize (standard cursor and prompt still visible)
          https://ibb.co/QN3Dyb0
          Could you open the Ruby Console before lunching Curviloft
          yes, here you are:
          Error: #<NoMethodError: undefined method visual_version' for SCFLicense:Module> c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1733:in tem_context'
          c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1709:in tem_launcher' c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:119:in launch_action'
          c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:244:in launch_action' c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_curviloft/bootstrap_curviloft.rbe:76:in launch_action'
          c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_curviloft/bootstrap_curviloft.rbe:93:in block in startup' c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1460:in command_invoke'
          c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1441:in block (2 levels) in build_config_commands' c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1378:in block in add_command'
          fredo6-console hosted at ImgBB
          Image fredo6-console hosted on ImgBB
          ImgBB (ibb.co)
          • fredo6F
            @qwertyas
            You need to upgrade to the latest version of Sketchucation ExtensionStore v4.2.4.
            Apparently, you have an old version.
              @qwertyas said:
              Windows 10 Home
              Please complete your profile with that and the SketchUp version after you update the Sketchucation Extension Store as Fredo6 directed.
              • qwertyasQ
                qwertyas
                @dave r said:
                @qwertyas said:
                Windows 10 Home
                done.
                Curviloft plugin is working now. Thanks!
                • qwertyasQ
                  qwertyas
                  @fredo6 said:
                  @qwertyas
                  I updated the plugin and reinstalled both Fredo6 Lib and Curviloft. It is working now. Thank you!
                    @qwertyas said:
                    It is working now.
                    Excellent! And thank you for completing your profile.
                      jose_w650
                      NO ES UN PLUGIN GRATUITO, SOLO FUNCIONA UNA TEMPORADA.
                      PERO PARECE UTIL, GRACIAS
                        Translated by Google:
                        @jose_w650 said:
                        IT IS NOT A FREE PLUGIN, IT ONLY WORKS FOR ONE SEASON.
                        BUT IT SEEMS USEFUL, THANK YOU
                        LibFredo6 is available at no charge. A few of Fredo6's extensions are no longer free after their trial periods expire.
                        What version of SketchUp are you using? Your profile says 2021 Free/Make but there is no such version.
                          Scozzarella
                          New LibFredo6?
                          when it will be available?
                          • fredo6F
                            NEW RELEASE: LibFredo6 v12.9a - 13 May 22
                            LibFredo6 12.9a includes:
                            • Various fixes for my plugins
                            • Support for LOTT v2.1a
                              Scozzarella
                              Thank you It works perfectly!
                              • T
                                thortoist
                                Hi I Have been a fun of your works and using it for a few years. time has past that I am in need to try a new version of plugins and sketchup.
                                From that day of reinstalling everything I have been spending days figuring out how to make your plugins work.
                                I have tried installing and reinstalling versions of libFredo from 7 to 12, but still I am getting the error of [please install LibFredo 6.9 or above].
                                I have tried degrading my sketchup version. trying installing different libFredo version. but nothing works.
                                Hope to get an answer soon to this problem. I am really in need of using curviloft.
                                Thank you in advanced. Have a great day.
                                • fredo6F
                                  It looks like a problem of installation.
                                  First can you confirm which version of Sketchup you run (SU2018?)?
                                  Second, go to the Plugin folder of Sketchup and erase Fredo6_!LibFredo6.rb and Fredo6_!LibFredo6 subfolder. Same for Fredo6_Curviloft.rb and Fredo6_Curviloft subfolder.
                                  Then, download and install fresh copy from the Sketchucation web site, or better, Use the Sketchucation ExtensionStore to install the plugins in one click.
                                    adrianavitor
                                    Is this plugin not free anymore? Can't use anything and keeps asking for a licence.
                                      @adrianavitor said:
                                      LibFredo6 is still available at no charge but some of the extensions that rely on it are no longer free as of a few months ago.
                                      See: https://sketchucation.com/forums/viewtopic.php?f=323&t=74668
                                      • K
                                        karimtabbara
                                        fredo_error_plugin_license.jpgHello
                                        I read all, but still cannot find the answer to my problem.
                                        I have saved all my licenses file into a personal folder.
                                        When I click on "Validate a License" and choose the proper file, I get an error message "ERROR_F09".
                                        I have already used correctly those licenses.
                                        But last time there registration must have been "lost"
                                        I haven't been able t use these plugins for a long time because I found no way to validate them...
                                        As I really need them, It's now time for me to use them again.
                                        Could you please help?
                                        Print screen
                                          Your screenshot of the license window for FredoCorner shows an old, outdated version of the license manager. The current version is 5.7a - 50. Update the Sketchucation Extension Store and restart SketchUp.
                                          • K
                                            karimtabbara
                                            Hello
                                            Thank you for your answer but still the same problem even after updating ALL.
                                            I even downloaded my license again, though I had kept a copy of the file.
                                            More of all the dialog box searches for a "FredoCorner.scflicense" so called file.
                                            But the file name is SCF_Purchased_License_RoundCorner_NORMAL_20220417.scflicense
                                            Please see screen copy.
                                            I've been spending quite some time trying.
                                            I'm I the only one to be frustrated ?
                                            I have been using Fredo Corner for years for free with no problem.
                                            I'm happy to contribute.
                                            But now that I have (contributed), won't work...
                                            Many thanks for some help
                                            • 90
                                            • 91
                                            • 92
                                            • 93
                                            • 94
                                            • 115
                                            • 116
                                            • 92 / 116
