    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.2k Posts 583 Posters 9.2m Views 585 Watching
    • V
      virolan
      After LibFredo6 v12.4a, many fredo plugins no longer work at all (FredoSpline, FredoScale, JointPushPull, etc.). When I click the plugin icon, nothing happens anymore. When I reinstall the old version (12.4a) back, everything works greate.
      I have licenses for these plugins, so what happened to these LibFredo6 updates? I'm still using sketchup version 2019 because it worked fine for me so far. What could be the problem?
        Anne O Grady
        After more than ten years of free distribution, some of Fredo's plugins have become paid extensions.
        Precisely, these are:
        RoundCorner
        JointPushPull
        Curviloft
        FredoScale
        ToolsOnSurface
        TopoShaper
        Curvizard
        VisuHole
        The transition will take place as of March 1st, 2022.
        After a 30-day free-trial period, these extensions will require a Sketchucation license.
        Price is USD 12 per plugin, or USD 40 for the bundle of all 8 plugins. Sketchucation Premium members have a significant discount on this pricing.
        IMPORTANT: You need to install or upgrade to Sketchucation Extension Store v4.2.4 or above.
        This is the original post on 27th Feb 2022
        http://sketchucation.com/forums/viewtopic.php?p=677933#p677933
        • V
          virolan
          Oh... My Sketchucation Extension Store seemed to be old version, so I upgraded it, then plugins started working again. I thought this update would show up in that Sketchup Extension Manager as well, but no.
          Thank you!
            The SketchUp Extension Manager only shows available updates for extensions from the SketchUp Extensions Warehouse.
            • fredo6F
              NEW RELEASE: LibFredo6 v12.8a - 17 Mar 22
              LibFredo6 12.8a tentatively corrects problems related to the creation of menus for my plugins. Some users experience an error preventing the plugins to load correctly. Since I am not able to reproduce, I made some changes 'blindly', hoping this would improve the situation.
              • qwertyasQ
                qwertyas
                all fredo6 plugins stopped to work after last fredo6 lib update. Sketchup 2020.
                To test if the problem is related to other plugins, I removed all my plugins from the plugin folder, and installed only sketchucation. From sketchucation plugin I installed fredo cuviloft and fredo6 lib (newest = 12.8a) and restarted Sketchup. Curviloft does not work. You can click on any of the icons but the tool does not initialize (standard cursor and prompt still visible)
                https://ibb.co/QN3Dyb0
                  What operating system? I'm not seeing any problems with amy of Fredo6's extensions after the latest update.
                  • fredo6F
                    Could you open the Ruby Console before lunching Curviloft
                    • qwertyasQ
                      qwertyas
                      is there a place where I can download previous versions of the plugins (and not the very old ones - for 2017 and earlier)? Thanks
                      • qwertyasQ
                        qwertyas
                        Windows 10 Home 21H1
                        • qwertyasQ
                          qwertyas
                          yes, here you are:
                          Error: #<NoMethodError: undefined method visual_version' for SCFLicense:Module> c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1733:in tem_context'
                          c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1709:in tem_launcher' c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:119:in launch_action'
                          c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:244:in launch_action' c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_curviloft/bootstrap_curviloft.rbe:76:in launch_action'
                          c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_curviloft/bootstrap_curviloft.rbe:93:in block in startup' c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1460:in command_invoke'
                          c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1441:in block (2 levels) in build_config_commands' c:/users/adam/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1378:in block in add_command'
                          fredo6-console hosted at ImgBB
                          Image fredo6-console hosted on ImgBB
                          ImgBB (ibb.co)
                          • fredo6F
                            @qwertyas
                            You need to upgrade to the latest version of Sketchucation ExtensionStore v4.2.4.
                            Apparently, you have an old version.
                              @qwertyas said:
                              Windows 10 Home
                              Please complete your profile with that and the SketchUp version after you update the Sketchucation Extension Store as Fredo6 directed.
                              • qwertyasQ
                                qwertyas
                                @dave r said:
                                @qwertyas said:
                                Windows 10 Home
                                done.
                                Curviloft plugin is working now. Thanks!
                                • qwertyasQ
                                  qwertyas
                                  @fredo6 said:
                                  @qwertyas
                                  I updated the plugin and reinstalled both Fredo6 Lib and Curviloft. It is working now. Thank you!
                                    @qwertyas said:
                                    It is working now.
                                    Excellent! And thank you for completing your profile.
                                      jose_w650
                                      NO ES UN PLUGIN GRATUITO, SOLO FUNCIONA UNA TEMPORADA.
                                      PERO PARECE UTIL, GRACIAS
                                        Translated by Google:
                                        @jose_w650 said:
                                        IT IS NOT A FREE PLUGIN, IT ONLY WORKS FOR ONE SEASON.
                                        BUT IT SEEMS USEFUL, THANK YOU
                                        LibFredo6 is available at no charge. A few of Fredo6's extensions are no longer free after their trial periods expire.
                                        What version of SketchUp are you using? Your profile says 2021 Free/Make but there is no such version.
                                          Scozzarella
                                          New LibFredo6?
                                          when it will be available?
                                          • fredo6F
                                            NEW RELEASE: LibFredo6 v12.9a - 13 May 22
                                            LibFredo6 12.9a includes:
                                            • Various fixes for my plugins
                                            • Support for LOTT v2.1a
                                            • 89
                                            • 90
                                            • 91
                                            • 92
                                            • 93
                                            • 112
                                            • 113
                                            • 91 / 113
